Hallo,
the System of my son does not boot to KDE anymore.
Its not 100% sure what he did but most likely it was an update and/or using the off-switch because an installer on steam froze (no, he will not do this again).
By now I’ve tried quite a few things. Updated the system, installed newer Kernel, that actually helped but its still stuck at boot after “Finished TLP System …”. Despite of that I think narrowed it down to nvidia drivers because of an log-entry in journalctl:
Nov 25 18:24:00 user kernel: NVRM: The NVIDIA GeForce GTX 660 GPU installed in this system is
NVRM: supported through the NVIDIA 470.xx Legacy drivers. Please
NVRM: visit http://www.nvidia.com/object/unix.html for more
NVRM: information. The 495.44 NVIDIA driver will ignore
NVRM: this GPU. Continuing probe...
Nov 25 18:24:00 user kernel: NVRM: No NVIDIA GPU found.
Also
[user@user-1 ~]$ inxi -Gazy
Device-1: NVIDIA GK106 [GeForce GTX 660] vendor: ASUSTeK driver: N/A
alternate: nouveau, nvidia_drm, nvidia bus-ID: 01:00.0 chip-ID: 10de:11c0
class-ID: 0300
Display: server: X.org 1.21.1.1 driver: loaded: nvidia tty: 317x93
Message: Advanced graphics data unavailable in console. Try -G --display
[user@user ~]$ mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2021.11.04 false PCI
[user@user ~]$ sudo mhwd -a pci nonfree 0300
[sudo] password for user:
> Using config 'video-nvidia-470xx' for device: 0000:01:00.0 (0300:10de:11c0) Display controller nVidia Corporation GK106 [GeForce GTX 660]
Error: config 'video-nvidia-470xx' conflicts with config(s): video-nvidia
removing video-nvidia does not work, since it has tons of dependencies.
I would be grateful if anyone has an idea.
xfeldt
Kernel: 5.4.159-1-MANJARO (same problem with 5.15, 5.16 …)
CPU: AMD FX-8350 (8) @ 4.000GHz
GPU: NVIDIA GeForce GTX 660
