Manjaro does not boot after fresh install
I’ve been trying to install manjaro for a while now and it failed like 6 times. The partition details are below
partition         size                                 flag
256 GB SSD
/dev/sda1      100mb   windows EFI
/dev/sda2      16mb     windows
/dev/sda3      196gb    ntfs
/dev/sda4      1G          /boot/efi                   boot
/dev/sda5      2g           swap
/dev/sda6      27G        /                            root
1TB HDD
/dev/sda1        500gb      ntfs
/dev/sda2        500gb     /home
after install it gets stuck at “acer” logo and does not display anything but the logo. I’ve tried to install it multiple times it does not work, i tried to install it with a previous version manjaro gnome 20.2 RC4, it had similar issues but it booted when i selected fallback mode in grub but the installation broke when i ran
sudo pacman-mirrors --fasttrack && sudo pacman -Syyu
After all of that i reinstalled the latest version, again with the same issue,
i tried the following after chrooring into install :
mkinintcpio -P
this still did not work, so i tried changing the nvidia drivers .
mhwd -r  pci video-linux
mhwd -i pci video-nvidia-450xx
when i tried to install nvidia driver it returns " video-nvidia-450xx not found" .
i’ve had the same setup a month ago and it worked like a charm, now it fails every time i install it. before installing manjaro i had ubuntu in the same setup (ive deleted all of ubuntu’s partition while first installing manjaro).
i also have nvidia 940mx graphics card in my laptop
Edit:
Looks like gdm does not start causing manjaro to be stuck on acer logo
Press ctl +alt +F3 to enter command line mode and then i switched to wayland instead of xorg. GDM was not starting up properly. but you can also issue startx to start gnome once you are in command line mode
can you provide
inxi -Fza
sudo mhwd -li
sudo mhwd-kernel -li
