Manjaro Deepin: Window Effects can no longer be enabled
I can't enable the Window effects anymore. My CPU is a AMD A10-9700 RADEON R7 and I have the open source graphic driver installed.
The error message is simple: Error activating window effects.
All I have done so far is:
> deepin-wm --replace
That didn't change anything, though. Can anyone point me in a direction where to look for the causes and a possible solution? Google didn't help much.
If you are using deepin-wm try deepin-kwin or vice versa.
Actually try this, open ~/.config/kwinrc
Check if OpenGLIsUnsafe=true, set it to false if it is set to true.
