Manjaro Deepin ISO
Thank you for your clear and detailed response. I would be interested in giving any new iso you make - I’ll watch the github page.
Updated Manjaro Deepin 20040220.
  • Update Manjaro system to the latest
  • Fixed problem where the file manager required manual refreshing to display content.
Upload frequency changed
Unfortunately, my external hard drive is damaged and cannot be repaired. Due to limited space on my computer, I can only reduce the update frequency and may not synchronize the ISO image after every major update. A new image will not be released until the official release of Deepin23. The interval between releasing new images will be at least 3 months. However, if there are no big updates after 3 months (may be longer) of a particular image release, a new image will not be created. The new image will be released after a big update.
File name: manjaro-deepin-23.1.3-240220-linux65.iso
Github: https://github.com/wiwyil2tr/manjarodeepiniso/releases/tag/20240220
Updated Manjaro Deepin 20241005.
  • New Deepin Desktop Environment (Deepin 23)
  • Fixed problem where the launcher sometimes can’t display normally.
Notice
  • Due to DDE automatically mounting any new partition, the partitioning tool in the Calamares installer is not usable. Therefore, it is necessary to manually use GParted from the livecd to create partitions before installation, and then select the partitions to mount in the installer for installation.
  • The password of the live user “manjaro” is manjaro
Screenshot_2024-10-06_11-05-08
Screenshot_2024-10-06_11-04-06
Filename: manjaro-deepin-24.1.0-241005-linux66.iso
Github Release
