When I launch some random thing (for exp. Application Launcher, Edit Widget thing, etc) manjaro crashes, but witin 5-10 seconds it goes normally (but if I launch these things again, it will crash).
If you need, I will give you a video link to better understand my problem
My system info:
KDE version: 5.24.5
KDE Frameworks version: 5.93.0
Qt version: 5.15.3
Kernel version: 5.10.114-1-MANJARO (64-bit)
Graphics platform: X11
Video link:
https://youtu.be/H2k2oHbGFJ4
provide formated output from:
inxi -Fazy
logs:
journalctl --boot=0 --priority=3 --no-pager
inxi -Fazy
Kernel: 5.10.114-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=9b324e2a-fed1-4392-a442-9e58cb746cec rw quiet
resume=UUID=f92ed5b2-6435-4c5f-83f9-765017a12a64 udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 80XV v: Lenovo ideapad 320-15AST
serial: <superuser required> Chassis: type: 10 v: Lenovo ideapad 320-15AST
Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <superuser required>
UEFI: LENOVO v: 5PCN14WW date: 05/08/2017
ID-1: BAT0 charge: 14.3 Wh (100.0%) condition: 14.3/30.0 Wh (47.6%)
volts: 8.3 min: 7.5 model: SMP L16M2PB1 type: Li-poly serial: <filter>
status: full
Info: model: AMD E2-9000 RADEON R2 4 COMPUTE CORES 2C+2G bits: 64 type: MCP
arch: Excavator family: 0x15 (21) model-id: 0x70 (112) stepping: 0
microcode: 0x6006704
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 192 KiB
desc: d-2x32 KiB; i-2x64 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 1260 high: 1324 min/max: 1200/1800 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1197 2: 1324
bogomips: 7189
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling
Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics] vendor: Lenovo
driver: amdgpu v: kernel ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 00:01.0 chip-ID: 1002:98e4 class-ID: 0300
Device-2: IMC Networks EasyCamera type: USB driver: uvcvideo
bus-ID: 1-1.3:4 chip-ID: 13d3:5a02 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0675 built: 2015
res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1366x768 min: 640x480
OpenGL: renderer: AMD STONEY (LLVM 13.0.1 DRM 3.40 5.10.114-1-MANJARO)
v: 4.5 Mesa 22.0.3 direct render: Yes
Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:01.1
chip-ID: 1002:15b3 class-ID: 0403
Device-2: AMD Family 15h Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:09.2 chip-ID: 1022:157a class-ID: 0403
Sound Server-1: ALSA v: k5.10.114-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: no
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 01:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 1000
bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-1.2:3
chip-ID: 0cf3:e500 class-ID: e001
Local Storage: total: 465.76 GiB used: 8.81 GiB (1.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD5000LPCX-24VHAT0 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A02 scheme: GPT
ID-1: / raw-size: 458.35 GiB size: 450.08 GiB (98.20%) used: 8.7 GiB (1.9%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 7.12 GiB used: 113.2 MiB (1.6%)
priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 42.5 C mobo: N/A gpu: amdgpu temp: 42.0 C
Processes: 189 Uptime: 46m wakeups: 1 Memory: 3.24 GiB
used: 2.39 GiB (73.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1058 lib: 303 Shell: Zsh
v: 5.8.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.16
When I type journalctl --boot=0 --priority=3 --no-pager
there are too many lines and Konsole shows me only ~1000 (also the forum does not allow me to post that much lines, but I can paste all the text into the .txt
file)
edit your post, click this icon in editor: </>
and inside put the inxi output…
you have to many lines in journal? that doesnt look good… just copy the 20 last lines and post it here
Stack trace of thread 6024:
#0 0x00007f19f35e215a __futex_abstimed_wait_common (libc.so.6 + 0x8a15a)
#1 0x00007f19f35e4960 pthread_cond_wait@@GLIBC_2.3.2 (libc.so.6 + 0x8c960)
#2 0x00007f19f3a7bcfc _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt5Core.so.5 + 0xebcfc)
#3 0x00007f198e9866fb _ZN12ThreadWeaver6Weaver36takeFirstAvailableJobOrSuspendOrWaitEPNS_6ThreadEbbb (libKF5ThreadWeaver.so.5 + 0x1e6fb)
#4 0x00007f198e9869ef n/a (libKF5ThreadWeaver.so.5 + 0x1e9ef)
#5 0x00007f198e985327 _ZN12ThreadWeaver6Weaver12applyForWorkEPNS_6ThreadEb (libKF5ThreadWeaver.so.5 + 0x1d327)
#6 0x00007f198e986a67 n/a (libKF5ThreadWeaver.so.5 + 0x1ea67)
#7 0x00007f198e985327 _ZN12ThreadWeaver6Weaver12applyForWorkEPNS_6ThreadEb (libKF5ThreadWeaver.so.5 + 0x1d327)
#8 0x00007f198e986a67 n/a (libKF5ThreadWeaver.so.5 + 0x1ea67)
#9 0x00007f198e985327 _ZN12ThreadWeaver6Weaver12applyForWorkEPNS_6ThreadEb (libKF5ThreadWeaver.so.5 + 0x1d327)
#10 0x00007f198e986a67 n/a (libKF5ThreadWeaver.so.5 + 0x1ea67)
#11 0x00007f198e985327 _ZN12ThreadWeaver6Weaver12applyForWorkEPNS_6ThreadEb (libKF5ThreadWeaver.so.5 + 0x1d327)
#12 0x00007f198e986a67 n/a (libKF5ThreadWeaver.so.5 + 0x1ea67)
#13 0x00007f198e985327 _ZN12ThreadWeaver6Weaver12applyForWorkEPNS_6ThreadEb (libKF5ThreadWeaver.so.5 + 0x1d327)
#14 0x00007f198e982d39 _ZN12ThreadWeaver6Thread3runEv (libKF5ThreadWeaver.so.5 + 0x1ad39)
#15 0x00007f19f3a748cc n/a (libQt5Core.so.5 + 0xe48cc)
#16 0x00007f19f35e55c2 start_thread (libc.so.6 + 0x8d5c2)
#17 0x00007f19f366a584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 6081:
#2 0x00007f19e66302ac n/a (radeonsi_dri.so + 0xc02ac)
#3 0x00007f19e66298cc n/a (radeonsi_dri.so + 0xb98cc)
#4 0x00007f19f35e55c2 start_thread (libc.so.6 + 0x8d5c2)
#5 0x00007f19f366a584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 6416:
#0 0x00007f19f365e2af __poll (libc.so.6 + 0x1062af)
#1 0x00007f19b046402f n/a (libpulse.so.0 + 0x3402f)
#2 0x00007f19b044d751 pa_mainloop_poll (libpulse.so.0 + 0x1d751)
#3 0x00007f19b0457afd pa_mainloop_iterate (libpulse.so.0 + 0x27afd)
#4 0x00007f19b0457bb1 pa_mainloop_run (libpulse.so.0 + 0x27bb1)
#5 0x00007f19b0468322 n/a (libpulse.so.0 + 0x38322)
#6 0x00007f19b01cd1c7 n/a (libpulsecommon-15.0.so + 0x5d1c7)
#7 0x00007f19f35e55c2 start_thread (libc.so.6 + 0x8d5c2)
#8 0x00007f19f366a584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 6418:
#3 0x00007f19f54f0bef n/a (libQt5Quick.so.5 + 0x200bef)
#4 0x00007f19f3a748cc n/a (libQt5Core.so.5 + 0xe48cc)
#5 0x00007f19f35e55c2 start_thread (libc.so.6 + 0x8d5c2)
#6 0x00007f19f366a584 __clone (libc.so.6 + 0x112584)
Stack trace of thread 7213:
#1 0x00007f19f35e4c64 pthread_cond_timedwait@@GLIBC_2.3.2 (libc.so.6 + 0x8cc64)
#2 0x00007f19f3a7bc84 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt5Core.so.5 + 0xebc84)
#3 0x00007f19f3a78b47 n/a (libQt5Core.so.5 + 0xe8b47)
Most of the lines are like these ^
those looks like logs from dumped core… provide output from:
journalctl -b-0 | grep coredump
мая 22 15:44:50 nikmedv-80xv kernel: audit: type=1130 audit(1653223489.429:235): pid=1 uid=0 auid=4294967295
ses=4294967295 msg='unit=systemd-coredump@4-19196-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=?
addr=? terminal=? res=success'
мая 22 15:44:49 nikmedv-80xv audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=sys
temd-coredump@4-19196-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=succes
s'
мая 22 15:46:41 nikmedv-80xv systemd-coredump[19198]: Process 15491 (plasmashell) of user 1000 dumped core.
мая 22 15:46:43 nikmedv-80xv kernel: audit: type=1131 audit(1653223602.159:236): pid=1 uid=0 auid=4294967295
мая 22 15:46:42 nikmedv-80xv audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=syst
emd-coredump@4-19196-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success
мая 22 15:46:42 nikmedv-80xv systemd[1]: systemd-coredump@4-19196-0.service: Deactivated successfully.
мая 22 15:46:42 nikmedv-80xv systemd[1]: systemd-coredump@4-19196-0.service: Consumed 10.045s CPU time.
P.S “мая” is May
yes your plasmashell dumps cores… but who knows why…
create new user and test with it
I have just tested the new user. It works fine (but the problem on the main user is still remaining)
try this in the main user:
rm -rf ~/.cache/*
rm ~/.config/Trolltech.conf
kbuildsycoca5 --noincremental
then reboot and test with main user
Oh nvm, the same problem happens even with the new user
so if it happens also with the user, then thats bad…
install the 5.15 LTS kernel, reboot, select it in grub menu, and test with it
Ok, I’ll try it tomorrow (I have to go to sleep )
Well… the problem is still here… even with the 5.15 LTS kernel
try this:
kquitapp5 plasmashell && kstart5 plasmashell
and test
Now it “crashes” only when I choose Kickoff Application Launcher from the Alternative widgets menu
so it only happens with non native widgets?
Idk is it native or not, but it’s the third one
try to reinstall plasma:
sudo pacman -S plasma-desktop plasma-workspace
reboot and test
