Hello everyone,
I’m a new Manjaro User. I currently have an issue with Manjaro and Matlab. I want to use Matlab and after a while my system randomly freezes. At first I didn’t know what causes the issue but i realized it happend if I had Matlab opened with some figuers. The System will not respond on any keyboard input, the only thing i can do is to hard reset my computer. Do someone know why this issue happen? I already reinstalled the complete OS but nothing changes.
I use Matlab R2020b Update 2
System Info:
OS: Manjaro Linux x86_64
Kernel: 5.8.18-1-MANJARO
Shell: zsh 5.8
DE: GNOME 3.38.1
CPU: Intel i5-6600K (4) @ 3.900GHz
GPU: Intel HD Graphics 530
GPU: NVIDIA GeForce GTX 980
Memory: 5432MiB / 15873MiB
Fabby
28 November 2020 11:09
2
Welcome to Manjaro!
Please read this:
When asking questions in the forum, it would be most helpful to all members if you provide some basic information. When you provide info from the terminal, usually from your logs, you have to format it so the content is easy to read. First copy and...
Reading time: 6 mins 🕑
Likes: 133 ❤
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width
would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU you have, without you having to type it every single time…
Hello Fabby,
thank you for your response . Here is the terminal output of the command.
Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=903cd087-1917-478c-aab8-403d6cb1b9a4 rw quiet apparmor=1
Desktop: GNOME 3.38.1 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.38.2
Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: Z170-P D3 v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 0403 date: 08/19/2015
ID-1: hidpp_battery_0 charge: N/A condition: N/A volts: 4.1/N/A
model: Logitech G903 LIGHTSPEED Wireless Gaming Mouse w/ HERO type: N/A
serial: <filter> status: Discharging
RAM: total: 15.50 GiB used: 2.36 GiB (15.2%)
Info: Quad Core model: Intel Core i5-6600K bits: 64 type: MCP
arch: Skylake-S family: 6 model-id: 5E (94) stepping: 3 microcode: E2
L2 cache: 6144 KiB bogomips: 28009
Speed: 800 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
Device-1: Intel HD Graphics 530 vendor: ASUSTeK driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:1912
Device-2: NVIDIA GM204 [GeForce GTX 980] vendor: CardExpert driver: nvidia
v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:13c0
Display: x11 server: X.org 1.20.9 compositor: gnome-shell driver: nvidia
resolution: <xdpyinfo missing>
OpenGL: renderer: GeForce GTX 980/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a170
Device-2: NVIDIA GM204 High Definition Audio vendor: CardExpert
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0fbb
Device-3: SteelSeries ApS Arctis 7 wireless adapter type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-1:2 chip ID: 1038:1260
Device-4: Yamaha Steinberg CI1 type: USB driver: snd-usb-audio
bus ID: 1-10:9 chip ID: 0499:1501
Device-5: Native Instruments Maschine MK3 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-6.3.2:10
chip ID: 17cc:1600 serial: <filter>
Sound Server: ALSA v: k5.8.18-1-MANJARO
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus ID: 04:00.0
chip ID: 10ec:8168
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: SteelSeries ApS Arctis 7 wireless adapter type: USB
Local Storage: total: 1.15 TiB used: 64.74 GiB (5.5%)
ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 1B6Q scheme: GPT
ID-2: /dev/sdb vendor: Western Digital model: WD10EZEX-08M2NA0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: MBR
ID-3: /dev/sdc type: USB vendor: Generic model: Flash Disk size: 14.84 GiB
block size: physical: 512 B logical: 512 B serial: <filter> rev: 8.07
scheme: MBR
Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SH-224DB rev: SB01
dev-links: cdrom
ID-1: / raw size: 134.38 GiB size: 131.26 GiB (97.68%)
used: 60.11 GiB (45.8%) fs: ext4 dev: /dev/sdb5 label: N/A
uuid: 903cd087-1917-478c-aab8-403d6cb1b9a4
ID-2: /boot/efi raw size: 100.0 MiB size: 96.0 MiB (96.00%)
used: 31.6 MiB (32.9%) fs: vfat dev: /dev/sda2 label: N/A uuid: C2D3-1584
ID-3: /run/media/stefanm/ESD-USB raw size: 14.84 GiB
size: 14.83 GiB (99.89%) used: 4.59 GiB (31.0%) fs: vfat dev: /dev/sdc1
label: ESD-USB uuid: B0F5-4F8B
ID-1: /dev/sda1 size: 529.0 MiB fs: ntfs label: Wiederherstellung
uuid: 640CCEA50CCE721A
ID-2: /dev/sda3 size: 16.0 MiB fs: <superuser/root required> label: N/A
uuid: N/A
ID-3: /dev/sda4 size: 232.25 GiB fs: ntfs label: N/A uuid: F8C2D918C2D8DC46
ID-4: /dev/sdb1 size: 785.03 GiB fs: ntfs label: N/A uuid: 209CA32F9CA2FF02
ID-5: /dev/sdb2 size: 11.18 GiB fs: swap label: N/A
uuid: 4195517f-ec43-462f-a231-868d1da87a92
ID-6: /dev/sdb3 size: 954.0 MiB fs: vfat label: N/A uuid: D783-E114
ID-7: /dev/sdb4 size: 1 KiB fs: <superuser/root required> label: N/A
uuid: N/A
Hub: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 1-1:2 info: SteelSeries ApS Arctis 7 wireless adapter
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 6
rev: 1.1 speed: 12 Mb/s chip ID: 1038:1260
Device-2: 1-2:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
chip ID: 046d:c52b
Hub: 1-6:4 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip ID: 05e3:0610
Device-1: 1-6.2:6 info: Alcor Micro Flash Drive type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s
chip ID: 058f:6387 serial: <filter>
Hub: 1-6.3:8 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip ID: 05e3:0610
Device-1: 1-6.3.2:10 info: Native Instruments Maschine MK3 type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 7 rev: 2.0
speed: 480 Mb/s chip ID: 17cc:1600 serial: <filter>
Device-2: 1-7:5 info: Logitech USB Receiver type: Keyboard,Mouse,HID
chip ID: 046d:c539
Device-3: 1-8:7 info: Logitech Gaming Keyboard G810 type: Keyboard,HID
chip ID: 046d:c337 serial: <filter>
Device-4: 1-10:9 info: Yamaha Steinberg CI1 type: <vendor specific>
driver: snd-usb-audio interfaces: 3 rev: 2.0 speed: 12 Mb/s
chip ID: 0499:1501
Hub: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
Hub: 2-6:2 info: Genesys Logic Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip ID: 05e3:0612
Hub: 2-6.3:3 info: Genesys Logic Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip ID: 05e3:0612
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 37 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Processes: 209 Uptime: 41m Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: 1365 pacman: 1334 lib: 366 flatpak: 27 snap: 4 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.1.08
I hope this will help to analyze the problem.
Fabby
30 November 2020 10:51
4
StefanMaier:
Kernel 5.8 is EOL: upgrade to 5.9 or 5.4 LTS
No swap means that if your memory is full, the system freezes as the Kernel OOM killer cannot swap anything. Create a swap file SQRT(RAM) <= swap <= 2*RAM if that would be the case.
Running a watch --interval=3 "free --human"
is imperative to see if that’s the problem.
This steps can help you.
For further troubleshooting please search archwiki/matlab.
