Yeah, I did it like 15 times in a row and all worked perfectly. For sure i did like 10 today and it worked well again.
I guess it’s xfce or manjaro issue because as i wrote in firts post hibernation/suspend works well in Windows 10 so it seems to me it’s not hardware. And i didn’t touch any files and configs due the installation as i wrote i was just following steps, installer did everything for me…
Btw i removed pulse but i still got some messages on shutdown/reboot idk if it is related but anyway i took the picture
those are not related… one is for watchdog, and then again for the audio…
disable watchdog:
open this: sudo nano etc/default/grub
and in this line GRUB_CMDLINE_LINUX_DEFAULT inside the quotes, put the following kernel parameter: nowatchdog
dont remove anything from there, just add it to existing parameters, save the file with ctrl+x, and update grub: sudo update-grub
then create this file: sudo nano /etc/modprobe.d/blacklist.conf
and put there these lines:
blacklist iTCO_wdt
blacklist iTCO_vendor_support
save it with CTRL+X, and recreate initframs: sudo mkinitcpio -P
reboot and test, maybe it will help… if not provide again logs: journalctl -b-1 -p4 --no-pager
Dec 15 11:28:52 G4 kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Dec 15 11:28:52 G4 kernel: TAA CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/tsx_async_abort.html for more details.
Dec 15 11:28:52 G4 kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Dec 15 11:28:52 G4 kernel: #3
Dec 15 11:28:52 G4 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Dec 15 11:28:52 G4 kernel: hpet_acpi_add: no address or irqs in _CRS
Dec 15 11:28:52 G4 kernel: usb: port power management may be unreliable
Dec 15 11:28:52 G4 systemd-journald[226]: File /var/log/journal/0ccd20a3cc5c4a4da491b30d78a9ff2d/system.journal corrupted or uncleanly shut down, renaming and replacing.
Dec 15 14:28:32 G4 kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
Dec 15 14:28:32 G4 kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
Dec 15 14:28:32 G4 kernel: resource sanity check: requesting [mem 0xfed10000-0xfed15fff], which spans more than pnp 00:08 [mem 0xfed10000-0xfed13fff]
Dec 15 14:28:32 G4 kernel: caller snb_uncore_imc_init_box+0x78/0xc0 [intel_uncore] mapping multiple BARs
Dec 15 14:28:33 G4 kernel: thermal thermal_zone2: failed to read out thermal zone (-61)
Dec 15 14:28:34 G4 kernel: kauditd_printk_skb: 88 callbacks suppressed
Dec 15 14:28:35 G4 systemd[630]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Dec 15 14:28:35 G4 bluetoothd[630]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Dec 15 14:28:35 G4 bluetoothd[630]: src/plugin.c:plugin_init() Failed to init vcp plugin
Dec 15 14:28:35 G4 bluetoothd[630]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Dec 15 14:28:35 G4 bluetoothd[630]: src/plugin.c:plugin_init() Failed to init mcp plugin
Dec 15 14:28:35 G4 bluetoothd[630]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Dec 15 14:28:35 G4 bluetoothd[630]: src/plugin.c:plugin_init() Failed to init bap plugin
Dec 15 14:28:35 G4 kernel: e1000e 0000:00:1f.6 0000:00:1f.6 (uninitialized): Failed to disable ULP
Dec 15 14:28:40 G4 kernel: kauditd_printk_skb: 12 callbacks suppressed
Dec 15 14:28:49 G4 lightdm[814]: gkr-pam: unable to locate daemon control file
Dec 15 14:28:50 G4 systemd-xdg-autostart-generator[831]: /home/atfq/.config/autostart/xcape.desktop:9: Unknown key name 'RunHook' in section 'Desktop Entry', ignoring.
Dec 15 14:28:50 G4 systemd-xdg-autostart-generator[831]: /home/atfq/.config/autostart/blueman.desktop:2: Unknown key name 'RunHook' in section 'Desktop Entry', ignoring.
Dec 15 14:28:50 G4 systemd-xdg-autostart-generator[831]: Configuration file /home/atfq/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
Dec 15 14:28:50 G4 systemd-xdg-autostart-generator[831]: /home/atfq/.config/autostart/xfce-pbw.sh:2: Assignment outside of section. Ignoring.
Dec 15 14:28:50 G4 systemd-xdg-autostart-generator[831]: /home/atfq/.config/autostart/xfce-pbw.sh:3: Assignment outside of section. Ignoring.
Dec 15 14:28:50 G4 systemd-xdg-autostart-generator[831]: /home/atfq/.config/autostart/xfce-pbw.sh:4: Assignment outside of section. Ignoring.
Dec 15 14:28:50 G4 systemd-xdg-autostart-generator[831]: /home/atfq/.config/autostart/xfce-pbw.sh:5: Assignment outside of section. Ignoring.
Dec 15 14:28:50 G4 systemd-xdg-autostart-generator[831]: /home/atfq/.config/autostart/xfce-pbw.sh:6: Assignment outside of section. Ignoring.
Dec 15 14:28:50 G4 systemd-xdg-autostart-generator[831]: /home/atfq/.config/autostart/xfce-pbw.sh:7: Assignment outside of section. Ignoring.
Dec 15 14:28:50 G4 systemd-xdg-autostart-generator[831]: Configuration file /home/atfq/.config/autostart/xfce-panel-workaround.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Dec 15 14:28:51 G4 pipewire-pulse[919]: mod.rt: Can't find xdg-portal: (null)
Dec 15 14:28:51 G4 pipewire-pulse[919]: mod.rt: found session bus but no portal
Dec 15 14:28:51 G4 pipewire[917]: mod.rt: Can't find xdg-portal: (null)
Dec 15 14:28:51 G4 pipewire[917]: mod.rt: found session bus but no portal
Dec 15 14:28:51 G4 wireplumber[918]: Failed to set scheduler settings: Operation not permitted
Dec 15 14:28:52 G4 tumblerd[1013]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.7.so.0: cannot open shared object file: No such file or directory
Dec 15 14:28:55 G4 kernel: kauditd_printk_skb: 14 callbacks suppressed
Dec 15 14:29:28 G4 kernel: e1000e 0000:00:1f.6 enp0s31f6: Failed to disable ULP
Dec 15 14:29:28 G4 kernel: smpboot: Scheduler frequency invariance went wobbly, disabling!
Dec 15 14:29:30 G4 kernel: Bluetooth: hci0: Reading supported features failed (-16)
Dec 15 14:29:30 G4 bluetoothd[630]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
Dec 15 14:29:37 G4 lightdm[1648]: gkr-pam: unable to locate daemon control file
Dec 15 14:29:37 G4 kernel: kauditd_printk_skb: 5 callbacks suppressed
Dec 15 14:30:09 G4 kernel: e1000e 0000:00:1f.6 enp0s31f6: Failed to disable ULP
Dec 15 14:30:09 G4 rtkit-daemon[920]: The canary thread is apparently starving. Taking action.
Dec 15 14:30:11 G4 kernel: Bluetooth: hci0: Reading supported features failed (-16)
Dec 15 14:30:11 G4 bluetoothd[630]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
Dec 15 14:30:18 G4 lightdm[1966]: gkr-pam: unable to locate daemon control file
Dec 15 14:30:18 G4 kernel: kauditd_printk_skb: 7 callbacks suppressed
Dec 15 14:30:56 G4 kernel: e1000e 0000:00:1f.6 enp0s31f6: Failed to disable ULP
Dec 15 14:30:58 G4 kernel: Bluetooth: hci0: Reading supported features failed (-16)
Dec 15 14:31:07 G4 lightdm[2285]: gkr-pam: unable to locate daemon control file
Dec 15 14:31:07 G4 kernel: kauditd_printk_skb: 7 callbacks suppressed
Dec 15 14:31:40 G4 kernel: e1000e 0000:00:1f.6 enp0s31f6: Failed to disable ULP
Dec 15 14:31:42 G4 kernel: Bluetooth: hci0: Reading supported features failed (-16)
Dec 15 14:31:49 G4 kernel: kauditd_printk_skb: 7 callbacks suppressed
Dec 15 14:31:53 G4 lightdm[2638]: gkr-pam: unable to locate daemon control file
Dec 15 14:31:58 G4 gnome-keyring-daemon[835]: asked to register item /org/freedesktop/secrets/collection/login/2, but it's already registered
Dec 15 14:31:58 G4 gnome-keyring-d[835]: asked to register item /org/freedesktop/secrets/collection/login/2, but it's already registered
you have these, but i have no idea if they are related… these point to your ethernet … maybe try disabling it in bios and test …
in the pic, there is again the watchod message … did you disable it as outlined above?
check with these if its disabled: cat /proc/sys/kernel/watchdog cat /proc/sys/kernel/nmi_watchdog
both should return ‘0’
Yes i did but when i tried cat /proc/sys/kernel/watchdog it returned 1 so i checked /etc/default/grub and realised that nowatchdog parameter just vanished… So i tried to add it again and check if it stays there after closing the file. But no, my edits in that file do not apply… I did all as you wrote i add it than pressed ctrl + x it asked me to save modified buffer so i pressed Y(Yes). What i did wrong?
you need to run sudo update-grub after you edit the grub config, after that it should be permanent… then reboot and check with the 2 cat commands if they return ‘0’ … if yes, reboot and disable the ethernet in bios and test suspending
My edits just do not apply… I don’t know why. I do everything as you asked, but when i re-open the file /etc/default/grubnowatchdog isn’t there. Maybe i’m adding it wrong?
I do GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor resume=UUID=56242996-2e2f-4958-8f12-59564b230866 udev.log_priority=3 nowatchdog"
Also /etc/modprobe.d/blacklist.conf is being deleted somehow. I created it yesterday after reading your post but now it does not exist…
Ooof, you didn’t say anything about enter before, i was only clicking Y(Yes) and closing terminal by alt+f4 because i didn’t know that Enter exits from nano. I am going to test this again now:
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
==> Starting build: 5.10.157-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [resume]
-> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: qla2xxx
==> WARNING: Possibly missing firmware for module: qla1280
==> WARNING: Possibly missing firmware for module: bfa
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img
==> ERROR: specified kernel image does not exist: `/boot/vmlinuz-5.15-x86_64'
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
==> Building image from preset: /etc/mkinitcpio.d/linux60.preset: 'default'
-> -k /boot/vmlinuz-6.0-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.0-x86_64.img
==> ERROR: specified kernel image does not exist: `/boot/vmlinuz-6.0-x86_64'
==> Building image from preset: /etc/mkinitcpio.d/linux60.preset: 'fallback'
-> -k /boot/vmlinuz-6.0-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.0-x86_64-fallback.img -S autodetect
==> Building image from preset: /etc/mkinitcpio.d/linux60-rt.preset: 'default'
-> -k /boot/vmlinuz-6.0-rt-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.0-rt-x86_64.img
==> ERROR: specified kernel image does not exist: `/boot/vmlinuz-6.0-rt-x86_64'
==> Building image from preset: /etc/mkinitcpio.d/linux60-rt.preset: 'fallback'
-> -k /boot/vmlinuz-6.0-rt-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.0-rt-x86_64-fallback.img -S autodetect
logs(ethernet turned off):
Dec 16 16:47:06 G4 kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Dec 16 16:47:06 G4 kernel: TAA CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/tsx_async_abort.html for more details.
Dec 16 16:47:06 G4 kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Dec 16 16:47:06 G4 kernel: #3
Dec 16 16:47:06 G4 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Dec 16 16:47:06 G4 kernel: hpet_acpi_add: no address or irqs in _CRS
Dec 16 16:47:06 G4 kernel: usb: port power management may be unreliable
Dec 16 16:47:06 G4 systemd-journald[227]: File /var/log/journal/0ccd20a3cc5c4a4da491b30d78a9ff2d/system.journal corrupted or uncleanly shut down, renaming and replacing.
Dec 16 19:44:34 G4 kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
Dec 16 19:44:34 G4 kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
Dec 16 19:44:34 G4 kernel: resource sanity check: requesting [mem 0xfed10000-0xfed15fff], which spans more than pnp 00:08 [mem 0xfed10000-0xfed13fff]
Dec 16 19:44:34 G4 kernel: caller snb_uncore_imc_init_box+0x78/0xc0 [intel_uncore] mapping multiple BARs
Dec 16 19:44:35 G4 kernel: thermal thermal_zone3: failed to read out thermal zone (-61)
Dec 16 19:44:35 G4 kernel: kauditd_printk_skb: 93 callbacks suppressed
Dec 16 19:44:37 G4 systemd[717]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Dec 16 19:44:37 G4 bluetoothd[717]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Dec 16 19:44:37 G4 bluetoothd[717]: src/plugin.c:plugin_init() Failed to init vcp plugin
Dec 16 19:44:37 G4 bluetoothd[717]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Dec 16 19:44:37 G4 bluetoothd[717]: src/plugin.c:plugin_init() Failed to init mcp plugin
Dec 16 19:44:37 G4 bluetoothd[717]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Dec 16 19:44:37 G4 bluetoothd[717]: src/plugin.c:plugin_init() Failed to init bap plugin
Dec 16 19:44:39 G4 kernel: Bluetooth: hci0: Reading supported features failed (-16)
Dec 16 19:44:45 G4 kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 16 19:44:47 G4 lightdm[806]: gkr-pam: unable to locate daemon control file
Dec 16 19:44:47 G4 systemd-xdg-autostart-generator[823]: /home/atfq/.config/autostart/xcape.desktop:9: Unknown key name 'RunHook' in section 'Desktop Entry', ignoring.
Dec 16 19:44:47 G4 systemd-journald[227]: File /var/log/journal/0ccd20a3cc5c4a4da491b30d78a9ff2d/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
Dec 16 19:44:47 G4 systemd-xdg-autostart-generator[823]: /home/atfq/.config/autostart/blueman.desktop:2: Unknown key name 'RunHook' in section 'Desktop Entry', ignoring.
Dec 16 19:44:47 G4 systemd-xdg-autostart-generator[823]: Configuration file /home/atfq/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
Dec 16 19:44:47 G4 systemd-xdg-autostart-generator[823]: /home/atfq/.config/autostart/xfce-pbw.sh:2: Assignment outside of section. Ignoring.
Dec 16 19:44:47 G4 systemd-xdg-autostart-generator[823]: /home/atfq/.config/autostart/xfce-pbw.sh:3: Assignment outside of section. Ignoring.
Dec 16 19:44:47 G4 systemd-xdg-autostart-generator[823]: /home/atfq/.config/autostart/xfce-pbw.sh:4: Assignment outside of section. Ignoring.
Dec 16 19:44:47 G4 systemd-xdg-autostart-generator[823]: /home/atfq/.config/autostart/xfce-pbw.sh:5: Assignment outside of section. Ignoring.
Dec 16 19:44:47 G4 systemd-xdg-autostart-generator[823]: /home/atfq/.config/autostart/xfce-pbw.sh:6: Assignment outside of section. Ignoring.
Dec 16 19:44:47 G4 systemd-xdg-autostart-generator[823]: /home/atfq/.config/autostart/xfce-pbw.sh:7: Assignment outside of section. Ignoring.
Dec 16 19:44:47 G4 systemd-xdg-autostart-generator[823]: Configuration file /home/atfq/.config/autostart/xfce-panel-workaround.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Dec 16 19:44:49 G4 pipewire[909]: mod.rt: Can't find xdg-portal: (null)
Dec 16 19:44:49 G4 pipewire[909]: mod.rt: found session bus but no portal
Dec 16 19:44:49 G4 pipewire-pulse[911]: mod.rt: Can't find xdg-portal: (null)
Dec 16 19:44:49 G4 pipewire-pulse[911]: mod.rt: found session bus but no portal
Dec 16 19:44:49 G4 wireplumber[910]: Failed to set scheduler settings: Operation not permitted
Dec 16 19:44:50 G4 kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 16 19:44:50 G4 tumblerd[1006]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.7.so.0: cannot open shared object file: No such file or directory
Dec 16 19:45:07 G4 kernel: smpboot: Scheduler frequency invariance went wobbly, disabling!
Dec 16 19:45:07 G4 kernel: done.
Dec 16 19:45:09 G4 kernel: Bluetooth: hci0: Reading supported features failed (-16)
Dec 16 19:45:09 G4 bluetoothd[717]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
Dec 16 19:45:13 G4 kernel: kauditd_printk_skb: 2 callbacks suppressed
Dec 16 19:45:20 G4 lightdm[1639]: gkr-pam: unable to locate daemon control file
according to the output above, you should have also kernel 6, kernel 6rt, kernel 5.15…
install the 5.15: sudo pacman -S linux515
and post output from it, if there are errors…
i wanted to see the output from the install command, to see if there are any errors, but since it installed i assume there were none…
post also output from:
ls /etc/mkinitcpio.d/*.preset
sudo ls /boot/initramfs-*
sudo ls /boot/vmlinuz-*
sudo ls /usr/lib/modules/*
there are some leftover presets, you can remove them: sudo rm /etc/mkinitcpio.d/linux60-rt.preset sudo rm /etc/mkinitcpio.d/linux60.preset
grub automatically booted with 5.15
(problem not solved)
Dec 16 18:50:06 G4 kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Dec 16 18:50:06 G4 kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Dec 16 18:50:06 G4 kernel: #3
Dec 16 18:50:06 G4 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Dec 16 18:50:06 G4 kernel: hpet_acpi_add: no address or irqs in _CRS
Dec 16 18:50:06 G4 kernel: usb: port power management may be unreliable
Dec 16 18:50:06 G4 systemd-journald[254]: File /var/log/journal/0ccd20a3cc5c4a4da491b30d78a9ff2d/system.journal corrupted or uncleanly shut down, renaming and replacing.
Dec 16 21:48:55 G4 kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
Dec 16 21:48:55 G4 kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
Dec 16 21:48:55 G4 kernel: resource sanity check: requesting [mem 0xfed10000-0xfed15fff], which spans more than pnp 00:08 [mem 0xfed10000-0xfed13fff]
Dec 16 21:48:55 G4 kernel: caller snb_uncore_imc_init_box+0x82/0xd0 [intel_uncore] mapping multiple BARs
Dec 16 21:48:56 G4 kernel: thermal thermal_zone2: failed to read out thermal zone (-61)
Dec 16 21:48:56 G4 kernel: kauditd_printk_skb: 208 callbacks suppressed
Dec 16 21:48:57 G4 systemd[768]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Dec 16 21:48:57 G4 bluetoothd[768]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Dec 16 21:48:57 G4 bluetoothd[768]: src/plugin.c:plugin_init() Failed to init vcp plugin
Dec 16 21:48:57 G4 bluetoothd[768]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Dec 16 21:48:57 G4 bluetoothd[768]: src/plugin.c:plugin_init() Failed to init mcp plugin
Dec 16 21:48:57 G4 bluetoothd[768]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Dec 16 21:48:57 G4 bluetoothd[768]: src/plugin.c:plugin_init() Failed to init bap plugin
Dec 16 21:48:59 G4 kernel: Bluetooth: hci0: Reading supported features failed (-16)
Dec 16 21:49:07 G4 kernel: kauditd_printk_skb: 16 callbacks suppressed
Dec 16 21:49:21 G4 lightdm[821]: gkr-pam: unable to locate daemon control file
Dec 16 21:49:21 G4 systemd-xdg-autostart-generator[864]: /home/atfq/.config/autostart/xcape.desktop:9: Unknown key name 'RunHook' in section 'Desktop Entry', ignoring.
Dec 16 21:49:21 G4 systemd-xdg-autostart-generator[864]: /home/atfq/.config/autostart/blueman.desktop:2: Unknown key name 'RunHook' in section 'Desktop Entry', ignoring.
Dec 16 21:49:21 G4 systemd-xdg-autostart-generator[864]: Configuration file /home/atfq/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
Dec 16 21:49:21 G4 systemd-xdg-autostart-generator[864]: /home/atfq/.config/autostart/xfce-pbw.sh:2: Assignment outside of section. Ignoring.
Dec 16 21:49:21 G4 systemd-xdg-autostart-generator[864]: /home/atfq/.config/autostart/xfce-pbw.sh:3: Assignment outside of section. Ignoring.
Dec 16 21:49:21 G4 systemd-xdg-autostart-generator[864]: /home/atfq/.config/autostart/xfce-pbw.sh:4: Assignment outside of section. Ignoring.
Dec 16 21:49:21 G4 systemd-xdg-autostart-generator[864]: /home/atfq/.config/autostart/xfce-pbw.sh:5: Assignment outside of section. Ignoring.
Dec 16 21:49:21 G4 systemd-xdg-autostart-generator[864]: /home/atfq/.config/autostart/xfce-pbw.sh:6: Assignment outside of section. Ignoring.
Dec 16 21:49:21 G4 systemd-xdg-autostart-generator[864]: /home/atfq/.config/autostart/xfce-pbw.sh:7: Assignment outside of section. Ignoring.
Dec 16 21:49:21 G4 systemd-xdg-autostart-generator[864]: Configuration file /home/atfq/.config/autostart/xfce-panel-workaround.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Dec 16 21:49:22 G4 pipewire-pulse[952]: mod.rt: Can't find xdg-portal: (null)
Dec 16 21:49:22 G4 pipewire-pulse[952]: mod.rt: found session bus but no portal
Dec 16 21:49:22 G4 pipewire[950]: mod.rt: Can't find xdg-portal: (null)
Dec 16 21:49:22 G4 pipewire[950]: mod.rt: found session bus but no portal
Dec 16 21:49:22 G4 wireplumber[951]: Failed to set scheduler settings: Operation not permitted
Dec 16 21:49:23 G4 tumblerd[1046]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.7.so.0: cannot open shared object file: No such file or directory
Dec 16 21:50:36 G4 kernel: kauditd_printk_skb: 21 callbacks suppressed
Dec 16 21:50:41 G4 gnome-keyring-daemon[868]: asked to register item /org/freedesktop/secrets/collection/login/2, but it's already registered
Dec 16 21:50:41 G4 gnome-keyring-d[868]: asked to register item /org/freedesktop/secrets/collection/login/2, but it's already registered
Dec 16 21:51:34 G4 kernel: done.
Dec 16 21:51:35 G4 kernel: Bluetooth: hci0: Reading supported features failed (-16)
Dec 16 21:51:35 G4 bluetoothd[768]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
Dec 16 21:51:51 G4 lightdm[1973]: gkr-pam: unable to locate daemon control file
Dec 16 21:51:51 G4 kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 16 21:52:15 G4 kernel: Bluetooth: hci0: Reading supported features failed (-16)
Dec 16 21:52:15 G4 bluetoothd[768]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
Dec 16 21:52:25 G4 lightdm[2291]: gkr-pam: unable to locate daemon control file
Dec 16 21:52:25 G4 kernel: kauditd_printk_skb: 8 callbacks suppressed
Dec 16 21:52:52 G4 kernel: kauditd_printk_skb: 5 callbacks suppressed
Dec 16 21:53:02 G4 kernel: psmouse serio2: Failed to disable mouse on synaptics-pt/serio0
Dec 16 21:53:02 G4 kernel: done.
Dec 16 21:53:03 G4 kernel: Bluetooth: hci0: Reading supported features failed (-16)
Dec 16 21:53:14 G4 lightdm[2383]: gkr-pam: unable to locate daemon control file
