try adding these 2 parameters, just like you added the parameter nowatchdog:
mem_sleep_default=deep pcie_aspm=off
save it, update grub, reboot and test
no changes…
logs(ethernet still off):
Dec 16 19:13:34 G4 kernel: x86/cpu: SGX disabled by BIOS.
Dec 16 19:13:34 G4 kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Dec 16 19:13:34 G4 kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Dec 16 19:13:34 G4 kernel: #3
Dec 16 19:13:34 G4 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Dec 16 19:13:34 G4 kernel: hpet_acpi_add: no address or irqs in _CRS
Dec 16 19:13:34 G4 kernel: usb: port power management may be unreliable
Dec 16 19:13:34 G4 systemd-journald[262]: File /var/log/journal/0ccd20a3cc5c4a4da491b30d78a9ff2d/system.journal corrupted or uncleanly shut down, renaming and replacing.
Dec 16 22:13:21 G4 kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
Dec 16 22:13:21 G4 kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
Dec 16 22:13:21 G4 kernel: resource sanity check: requesting [mem 0xfed10000-0xfed15fff], which spans more than pnp 00:08 [mem 0xfed10000-0xfed13fff]
Dec 16 22:13:21 G4 kernel: caller snb_uncore_imc_init_box+0x82/0xd0 [intel_uncore] mapping multiple BARs
Dec 16 22:13:22 G4 kernel: thermal thermal_zone2: failed to read out thermal zone (-61)
Dec 16 22:13:23 G4 kernel: kauditd_printk_skb: 210 callbacks suppressed
Dec 16 22:13:23 G4 systemd[773]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Dec 16 22:13:23 G4 bluetoothd[773]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Dec 16 22:13:23 G4 bluetoothd[773]: src/plugin.c:plugin_init() Failed to init vcp plugin
Dec 16 22:13:23 G4 bluetoothd[773]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Dec 16 22:13:23 G4 bluetoothd[773]: src/plugin.c:plugin_init() Failed to init mcp plugin
Dec 16 22:13:23 G4 bluetoothd[773]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Dec 16 22:13:23 G4 bluetoothd[773]: src/plugin.c:plugin_init() Failed to init bap plugin
Dec 16 22:13:29 G4 kernel: kauditd_printk_skb: 13 callbacks suppressed
Dec 16 22:13:36 G4 lightdm[864]: gkr-pam: unable to locate daemon control file
Dec 16 22:13:36 G4 systemd-xdg-autostart-generator[875]: /home/atfq/.config/autostart/xcape.desktop:9: Unknown key name 'RunHook' in section 'Desktop Entry', ignoring.
Dec 16 22:13:36 G4 systemd-xdg-autostart-generator[875]: /home/atfq/.config/autostart/blueman.desktop:2: Unknown key name 'RunHook' in section 'Desktop Entry', ignoring.
Dec 16 22:13:36 G4 systemd-xdg-autostart-generator[875]: Configuration file /home/atfq/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
Dec 16 22:13:36 G4 systemd-xdg-autostart-generator[875]: /home/atfq/.config/autostart/xfce-pbw.sh:2: Assignment outside of section. Ignoring.
Dec 16 22:13:36 G4 systemd-xdg-autostart-generator[875]: /home/atfq/.config/autostart/xfce-pbw.sh:3: Assignment outside of section. Ignoring.
Dec 16 22:13:36 G4 systemd-xdg-autostart-generator[875]: /home/atfq/.config/autostart/xfce-pbw.sh:4: Assignment outside of section. Ignoring.
Dec 16 22:13:36 G4 systemd-xdg-autostart-generator[875]: /home/atfq/.config/autostart/xfce-pbw.sh:5: Assignment outside of section. Ignoring.
Dec 16 22:13:36 G4 systemd-xdg-autostart-generator[875]: /home/atfq/.config/autostart/xfce-pbw.sh:6: Assignment outside of section. Ignoring.
Dec 16 22:13:36 G4 systemd-xdg-autostart-generator[875]: /home/atfq/.config/autostart/xfce-pbw.sh:7: Assignment outside of section. Ignoring.
Dec 16 22:13:36 G4 systemd-xdg-autostart-generator[875]: Configuration file /home/atfq/.config/autostart/xfce-panel-workaround.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Dec 16 22:13:37 G4 pipewire[961]: mod.rt: Can't find xdg-portal: (null)
Dec 16 22:13:37 G4 pipewire[961]: mod.rt: found session bus but no portal
Dec 16 22:13:37 G4 pipewire-pulse[963]: mod.rt: Can't find xdg-portal: (null)
Dec 16 22:13:37 G4 pipewire-pulse[963]: mod.rt: found session bus but no portal
Dec 16 22:13:37 G4 wireplumber[962]: Failed to set scheduler settings: Operation not permitted
Dec 16 22:13:39 G4 tumblerd[1059]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.7.so.0: cannot open shared object file: No such file or directory
Dec 16 22:13:41 G4 kernel: kauditd_printk_skb: 20 callbacks suppressed
are these logs from the failed suspend?
those were from failed hibernate to be correct
these are from failed suspend:
Dec 16 19:15:11 G4 kernel: x86/cpu: SGX disabled by BIOS.
Dec 16 19:15:11 G4 kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Dec 16 19:15:11 G4 kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Dec 16 19:15:11 G4 kernel: #3
Dec 16 19:15:11 G4 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Dec 16 19:15:11 G4 kernel: hpet_acpi_add: no address or irqs in _CRS
Dec 16 19:15:11 G4 kernel: usb: port power management may be unreliable
Dec 16 19:15:11 G4 systemd-journald[259]: File /var/log/journal/0ccd20a3cc5c4a4da491b30d78a9ff2d/system.journal corrupted or uncleanly shut down, renaming and replacing.
Dec 16 22:14:03 G4 kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
Dec 16 22:14:03 G4 kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
Dec 16 22:14:04 G4 kernel: resource sanity check: requesting [mem 0xfed10000-0xfed15fff], which spans more than pnp 00:08 [mem 0xfed10000-0xfed13fff]
Dec 16 22:14:04 G4 kernel: caller snb_uncore_imc_init_box+0x82/0xd0 [intel_uncore] mapping multiple BARs
Dec 16 22:14:05 G4 kernel: kauditd_printk_skb: 206 callbacks suppressed
Dec 16 22:14:05 G4 kernel: thermal thermal_zone2: failed to read out thermal zone (-61)
Dec 16 22:14:06 G4 systemd[769]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Dec 16 22:14:06 G4 bluetoothd[769]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Dec 16 22:14:06 G4 bluetoothd[769]: src/plugin.c:plugin_init() Failed to init vcp plugin
Dec 16 22:14:06 G4 bluetoothd[769]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Dec 16 22:14:06 G4 bluetoothd[769]: src/plugin.c:plugin_init() Failed to init mcp plugin
Dec 16 22:14:06 G4 bluetoothd[769]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Dec 16 22:14:06 G4 bluetoothd[769]: src/plugin.c:plugin_init() Failed to init bap plugin
Dec 16 22:14:08 G4 kernel: Bluetooth: hci0: Reading supported features failed (-16)
Dec 16 22:14:12 G4 lightdm[839]: gkr-pam: unable to locate daemon control file
Dec 16 22:14:12 G4 kernel: kauditd_printk_skb: 17 callbacks suppressed
Dec 16 22:14:12 G4 systemd-xdg-autostart-generator[870]: /home/atfq/.config/autostart/xcape.desktop:9: Unknown key name 'RunHook' in section 'Desktop Entry', ignoring.
Dec 16 22:14:12 G4 systemd-journald[259]: File /var/log/journal/0ccd20a3cc5c4a4da491b30d78a9ff2d/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
Dec 16 22:14:12 G4 systemd-xdg-autostart-generator[870]: /home/atfq/.config/autostart/blueman.desktop:2: Unknown key name 'RunHook' in section 'Desktop Entry', ignoring.
Dec 16 22:14:12 G4 systemd-xdg-autostart-generator[870]: Configuration file /home/atfq/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
Dec 16 22:14:12 G4 systemd-xdg-autostart-generator[870]: /home/atfq/.config/autostart/xfce-pbw.sh:2: Assignment outside of section. Ignoring.
Dec 16 22:14:12 G4 systemd-xdg-autostart-generator[870]: /home/atfq/.config/autostart/xfce-pbw.sh:3: Assignment outside of section. Ignoring.
Dec 16 22:14:12 G4 systemd-xdg-autostart-generator[870]: /home/atfq/.config/autostart/xfce-pbw.sh:4: Assignment outside of section. Ignoring.
Dec 16 22:14:12 G4 systemd-xdg-autostart-generator[870]: /home/atfq/.config/autostart/xfce-pbw.sh:5: Assignment outside of section. Ignoring.
Dec 16 22:14:12 G4 systemd-xdg-autostart-generator[870]: /home/atfq/.config/autostart/xfce-pbw.sh:6: Assignment outside of section. Ignoring.
Dec 16 22:14:12 G4 systemd-xdg-autostart-generator[870]: /home/atfq/.config/autostart/xfce-pbw.sh:7: Assignment outside of section. Ignoring.
Dec 16 22:14:12 G4 systemd-xdg-autostart-generator[870]: Configuration file /home/atfq/.config/autostart/xfce-panel-workaround.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Dec 16 22:14:14 G4 pipewire[955]: mod.rt: Can't find xdg-portal: (null)
Dec 16 22:14:14 G4 pipewire-pulse[957]: mod.rt: Can't find xdg-portal: (null)
Dec 16 22:14:14 G4 pipewire-pulse[957]: mod.rt: found session bus but no portal
Dec 16 22:14:14 G4 pipewire[955]: mod.rt: found session bus but no portal
Dec 16 22:14:14 G4 wireplumber[956]: Failed to set scheduler settings: Operation not permitted
Dec 16 22:14:15 G4 tumblerd[1045]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.7.so.0: cannot open shared object file: No such file or directory
Dec 16 22:14:17 G4 kernel: kauditd_printk_skb: 21 callbacks suppressed
Dec 16 22:15:47 G4 gnome-keyring-daemon[874]: asked to register item /org/freedesktop/secrets/collection/login/2, but it's already registered
Dec 16 22:15:47 G4 gnome-keyring-d[874]: asked to register item /org/freedesktop/secrets/collection/login/2, but it's already registered
Dec 16 22:24:31 G4 kernel: done.
Dec 16 22:24:33 G4 kernel: Bluetooth: hci0: Reading supported features failed (-16)
Dec 16 22:24:33 G4 bluetoothd[769]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
Dec 16 22:24:41 G4 lightdm[2443]: gkr-pam: unable to locate daemon control file
Dec 16 22:24:41 G4 kernel: kauditd_printk_skb: 11 callbacks suppressed
Dec 16 22:24:52 G4 kernel: psmouse serio2: Failed to disable mouse on synaptics-pt/serio0
Dec 16 22:24:52 G4 kernel: done.
Dec 16 22:24:54 G4 kernel: Bluetooth: hci0: Reading supported features failed (-16)
Dec 16 22:26:50 G4 pkexec[2723]: atfq: Error executing command as another user: Not authorized [USER=root] [TTY=unknown] [CWD=/home/atfq] [COMMAND=/usr/bin/xfpm-power-backlight-helper --set-brightness 1363]
Dec 16 22:27:21 G4 lightdm[2706]: gkr-pam: unable to locate daemon control file
so you have this again, but i have no idea if its related…
i would try to disable also bluetooth in bios and test… otherwise im out of ideas, since there is really nothing in logs…
also you can download the latest iso from here - download both of the zip files, and test if it happens there too… if yes, its something not siting right with your hardware and xfce…
I see only one suitable zip archive (manjaro-xfce-22.0-221206-linux60.iso.zip). Which is the second? And you mean you suggest fully reinstall manjaro from the very beginning?
these 2 zips:
manjaro-xfce-22.0-221206-linux60.iso.z01
merge them and try with it…
this is for testing purposes, and if the suspend works on this latest iso, its probably something you modified/installed etc, thats causing the issue…
I’m sorry but i don’t know how to merge archives… Can you tell me please?
can the default zip program in xfce dont do it?
open terminal in the folder where you downloaded those archives and run this command:
7z x manjaro-xfce-22.0-221206-linux60.iso.z01
7-Zip [64] 17.04 : Copyright (c) 1999-2021 Igor Pavlov : 2017-08-28
p7zip Version 17.04 (locale=en_US.utf8,Utf16=on,HugeFiles=on,64 bits,4 CPUs x64)
Scanning the drive for archives:
1 file, 2097152000 bytes (2000 MiB)
Extracting archive: manjaro-xfce-22.0-221206-linux60.iso.z01
Path = manjaro-xfce-22.0-221206-linux60.iso.z01
Type = zip
Physical Size = 2097152000
Embedded Stub Size = 4
Total Physical Size = 3702234632
Multivolume = +
Volume Index = 0
Volumes = 2
Everything is Ok
Compressed: 3702234632
it did something. What should i do next? With second archive?
it already merged them, now flash the iso, and test with it
you mean i should make a live usb?
yes, use the merged/extracted iso and just test with it, like you did with the kde live usb
After many attemps(and many hours of attemts) to boot i’am here again. When i use that iso i can’t boot into system. Bios just skips the flash drive in boot order and boots into manjaro that is installed instead. I tried to remake live usb about 5 times but nothing changed. Just for test i made live usb manjaro 5.15 , i used 5.15 iso when i was installing the system that is installed rn. So i tried to make 5.15 live usb and boot and i booted. I tested suspend on 5.15 live usb and it is not working the same black screen as i get usually. Any ideas how to boot into manjaro 22.0-221206-linux60 live usb? I used rufus 3.19 if it matters.
use ventoy to flash isos, not rufus, but that doesnt matter:
the suspend doesnt work on your hardware + xfce …
I always thought that thinkpads are best laptops for linux so it’s discouraging to hear that. Anyway thank you for your time and help. I’ll try maybe some live usbs with older versions…
I’ll post in that topic later if i find a solution, if not i’ll switch to arch, hope it will work there.
that would be pointless to try older isos, just try live usb of a non arch distro with xfce, and test with it… if it happens also there, it would not make sense to switch to arch, since it would be affected too…
you could also try switching branch from stable to testing, since it has the latest xfce 4.18, maybe its fixed there, or wait till its in stable…
No changes on testing branch… The same black screen.
And even more i cannot downgrade so i can’t even open a browser because of conflicting libraries… My system is kinda broken now.
Going to test non arch distro with xfce…
this is how you switch back to stable:
sudo pacman-mirrors --api --set-branch stable
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyuu
if the non arch doesnt work, i would recommend a reinstall using non xfce, since it works at least with KDE
I used directly these commands from manjaro wiki but when i try to execute second command i got error: failed to commit transaction (conflicting files)
and list of libraries
then
Errors occured, no packages were upgraded
