Manjaro CLI Cheat Sheet
I just didnt liked the ones that showed up in google (updated, with suggestions)
Nice. :+1:
Nice work.
What about transfering this to a wiki?
If you create this as a text(-wiki) post here, anyone can access the commands directly (copy and paste), and it can be extended (if as wiki-post).
System and Screen
Display the Kernel-version
uname -r
Or if you agree, I can create it in the manjaro-wiki. (It is more beautiful there than here)
thx, ok, a wiki post sounds great,
    Locating and Installing Packages
        sudo pacman-mirrors --fasttrack && sudo pacman -Syyu
                                    update mirrorlist with the fastest mirrors
        pamac checkupdates -a       check if updates are available
        pamac upgrade -a            update all installed packages
        pamac search PackageName    search available packages
        pamac install PackageName   install packages
        pamac remove PackageName    uninstall packages
    Maintenance
        du -sh ~/.cache/*           generate cache list
        find ~/.cache/ -type f -atime +100 -delete
                                    purge files not accessed in 100 days
        journalctl --disk-usage     report journal current size
        journalctl --vacuum-size=50M
        journalctl --vacuum-time=2weeks
                                    remove but recent entries by size or time
        pamac list -o               check for orphaned packages
        pamac remove -o             remove all orphans
        pamac clean --keep 3        remove all packages except the latest 3 versions
    AUR
        pamac search -a PackageName
                                    search for packages
        pamac build PackageName     build the package
    Access rights
        sudo command                executes command as root
        sudo -k                     empties password cache
        sudo visudo                 edits /etc/sudoers
        passwd                      changes user password
        chown owner:group           changes owner and group of file
        chmod permissions file      changes the file permissions
                                    to set permissions in octal mode:
                                    4 (read) 2 (write) 1 (execute)
                                    example - 755 read-write-execute for owner
                                    amd read-execute for group and others
        ls -lh [dir]                displays files and permissions [of directory]
    Files and Directories
        cd dir                      changes the working directory
        cd ..                       changes to the parent directory
        ls                          lists directory contents
        ls -a                       also lists the hidden files
        cp target file              copies the file
        cp -r target directory      copies the directory
        mv target source            move/rename target source
        rm -r dir                   removes directory recursively
        ln -s file link             removes directory recursively
        mount -t type dev path      mounts file system
        mount -o loop iso path      mounts iso image
        /home/user or ~/            home directory of user
        /etc                        directory with global configurations
    Network
        nmcli                       displays network informatio
        nmcli c                     lists wireless access points
        ufw enable                  enables the firewall [package Community: ufw]
        ufw default allow/deny      allows/denies all incoming traffic
        ufw status                  displays firewall status and rules
        ufw allow/deny port         allows/denies incoming traffic on the specified port
        ufw allow/deny from ip      allows/denies incoming traffic from specified IP address
    System and Screen
        uname -r                    displays the kernel version
        uname -a                    displays all the kernel version
        df                          reports file system disk space usage
        top                         displays system tasks
        inxi --admin --verbosity=7 --filter --width
                                    displays system information
        pstree                      display a tree of processes
        Ctrl+Alt+F2                 switches to tty
        Ctrl+Alt+F7                 switches to the X session
        shutdown -h now             shuts the sytem down
        shutdown -r now             restarts the system
    Find
        find <st­art­ing­dir­ect­ory> <op­tio­ns> <search term>
                                    Basic structure
        find -name "­file”           Find by name
        find -iname "­file”          Find by name, ignoring CL
        find -name “*.format”       Find by format
        find -not -name "­fil­e"      Exclude a name
        find -type "­typ­e"           f:file, d:dire­ctory, l:link...
        find -empty                 Empty files and directory
        find -exec                  Find executable programs
and force refresh the packages databases (required when changing mirror), and update the system
AUR included
typo, one o added
typo, not sure what you meant there
could maybe note that it is the same as the ~/ folder (for current user)
could be confusing for people with literally a Fn key (laptops usually)
Hello @guillopacheco ‘ifconfig’ is not installed per default on manjaro. But ‘nmcli’ should be available for everyone. :wink:
post updated, @andreas85 wiki - CheatSheet - Manjaro
Good as info, impossible to use as desktop wallpaper (for me) cause desktop icons presence and represents recent and constant working files/folders on the Desktop.
Could be useful for users who have no working files/folders on their Desktop and have to access them in more complicated way instead of instant and having list of them constantly immediately.
PS
Could be useful for those who have 2 monitors setup to show on second screen with no desktop icons on it.
maybe using virtual desktops, or activities can help you with that situation, we are free now in manjaro linux.
I agree with alven. It is the same reason why i don’t like and use conky. Putting up this in the wiki is a really nice idea :+1:
I actually have the cheatsheet as sticky notes, so i can change the wallpaper, or leave it random, theres the image, the text, the wiki… all covered
At copy and move operations source and target are in the wrong order:
cp [file] [target]
missing:
create symbolic link {{UserCmd|command=ln -s [target] [link]}}
outdated with systemd:
starts a daemon {{UserCmd|command=rc.d start [daemon]}}
stops a daemon {{UserCmd|command=rc.d stop [daemon]}}
restarts a daemon {{UserCmd|command=rc.d restart daemon}}
done
Install SSL Cert in system from a file
wget foobar.com/foobar.crt && sudo cp foobar.crt /etc/ca-certificates/trust-source/anchors/ && sudo trust extract-compat
KDE Connect ports
sudo ufw allow 1714:1764/tcp
sudo ufw allow 1714:1764/udp
Others stuffs
sudo parted -l
sudo blkid
findmnt -s
efibootmgr -v
nmcli
nmcli dev show
nmcli device wifi list
udisksctl loop-setup -f UDF-ISO-FILENAME.iso
udisksctl mount -b /dev/loop0
sudo fdisk -l
sudo e2label /dev/sdb1 "mydiskname"
inxi -Fxxxza --no-host
journalctl --this-boot --no-pager --no-hostname
systemd-analyze blame --no-pager
# https://stackoverflow.com/questions/23645595/how-to-find-linux-module-path
awk '{ print $1 }' /proc/modules | xargs modinfo -n | sort
rfkill list
sudo lspci -k
sudo lspci -vnnn | perl -lne 'print if /^\d+\:.+(\[\S+\:\S+\])/' | grep Control
sudo lspci -vnnn | perl -lne 'print if /^\d+\:.+(\[\S+\:\S+\])/' | grep 3D
grep -R . /sys/foo/bar
fixed. thx!
