Hi,
My usb 3.0 prots weren’t working in Manjaro, but they work in Windows (dual boot config on laptop).
The laptop has 1 usb 2.0 and 2 usb 3.0 ports.
So I tried to fix it, and made it worse. Now usb 2.0 port is also not working. -_-
This is the link to the post I had open on my phone when trying to fix it:
TBH: I missread a lot and may have overlooked an important detail in the console output of the user in the post.
The following is a step by step command review of what stupid stuff I did with comments and output where I still have it.
State USB 3.0 not working and USB 2.0 Working
// for comments
# for console output I still have in hand
lsmod | grep xhci
hwinfo --usb-ctrl
sudo modprobe xhci_pci xhci_pci_renesas
USB 2.0 stopps working
sudo modprobe xhci_pci_renesas xhci_pci
// trying to revert while thinking modprobe replaces x with y
reboot // trying to und the changes
hwinfo
hwinfo | grep "renesas"
sudo modprobe xhci_plat_hcd
sudo modprobe ehci-hcd
sudo pamac build hw-probe
// googled modprobe
sudo modprobe xhci_pci xhci_pci_renesas -r
// trying to get rid off stuff that made usb 2.0 not work
hwinfo --usb-ctrl
//following suggestion in hwinfo
sudo modprobe xhci_hcd
// trying commands from the forum post again
sudo nano /etc/modules-load.d/usb3.conf
//looking for file in post result: empty nano => file doesn't exist or empty
lsusb -t
sudo inxi -Fazc0 --usb
Starting to write this poste and trying to undo most modprobe commands by trying to remove the installed stuff
sudo modprobe xhci_plat_hcd -r
sudo modprobe ehci-hcd -r
# modprobe: FATAL: Module ehci_hcd is buildin
sudo modprobe xhci-hcd -r
# modprobe: FATAL: Module xhci_hcd is builtin.
sudo modprobe xhci_hcd -r
sudo modprobe xhci_pci -r
sudo modprobe xhci_pci_renesas -r
sudo modprobe xhci_pci // hoping it was the default before
result of all of it:
not only is usb 3.0 not working
usb 2.0 has stopped working
+ I know i should read more befor doing
Stuff that could be usefull:
inxi -zv8:
Kernel: 6.6.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=fac3077d-c6ec-4ddd-8a21-214d4a3e9017 rw quiet apparmor=1
Desktop: Cinnamon v: 6.0.4 tk: GTK v: 3.24.41 wm: Muffin v: 6.0.1 tools:
avail: cinnamon-screensaver vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro
base: Arch Linux
Type: Laptop System: Acer product: Aspire A315-23 v: V1.21
serial: <superuser required>
Mobo: DL model: Lotus_DA v: V1.21 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 1.21
date: 09/08/2022
ID-1: BAT1 charge: 16.3 Wh (62.2%) condition: 26.2/37.0 Wh (70.7%)
volts: 7.4 min: 7.6 model: MURATA AP16M4J type: Li-ion serial: <filter>
status: discharging
System RAM: total: 20 GiB available: 17.5 GiB used: 3.51 GiB (20.1%)
(unregistered) size: 16 GiB speed: 2400 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Crucial
part-no: CT16G4SFD824A.M16FE serial: <filter>
(unregistered) size: 4 GiB speed: spec: 2667 MT/s actual: 2400 MT/s volts:
note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: Micron Technology part-no: 4ATF51264HZ-2G6E1 serial: N/A
Info: model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3 note: check
built: 2019 process: GF 12nm family: 0x17 (23) model-id: 0x18 (24)
stepping: 1 microcode: 0x8108109
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1345 high: 2100 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1266 2: 2100
3: 1205 4: 1223 5: 1222 6: 1241 7: 1264 8: 1239 bogomips: 33609
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Acer Incorporated ALI driver: amdgpu v: kernel arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
lanes: 16 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 05:00.0
chip-ID: 1002:15d8 class-ID: 0300 temp: 43.0 C
Display: x11 server: X.org v: 1.21.1.12 with: Xwayland v: 23.2.6 driver:
X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x07cb built: 2018
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 chroma: red: x: 0.584 y: 0.361
green: x: 0.353 y: 0.569 blue: x: 0.161 y: 0.129 white: x: 0.314 y: 0.329
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720,
1024x768, 800x600, 640x480
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics
(radeonsi raven LLVM 16.0.6 DRM 3.54 6.6.26-1-MANJARO)
device-ID: 1002:15d8 memory: 1.95 GiB unified: no
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Acer Incorporated ALI driver: snd_pci_acp3x v: kernel
alternate: snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 05:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.6.26-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: off tools: pw-cli
Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
vendor: Acer Incorporated ALI RTL8111/8168/8411 driver: r8169 v: kernel
pcie: speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s port: 2000
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Info: services: NetworkManager,wpa_supplicant
Local Storage: total: 953.87 GiB used: 108.58 GiB (11.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-1T00-1014 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 21103900 temp: 38.9 C scheme: GPT
ID-1: / raw-size: 373.08 GiB size: 366.15 GiB (98.14%)
used: 108.51 GiB (29.6%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: fac3077d-c6ec-4ddd-8a21-214d4a3e9017
used: 70.8 MiB (73.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: ESP uuid: A07A-1812
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 579.68 GiB fs: ntfs label: Acer
uuid: CEE27AA8E27A9505
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1024 MiB fs: ntfs
label: Recovery uuid: 8C967B97967B808E
Hub-4: 4-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 43.9 C mobo: N/A gpu: amdgpu temp: 43.0 C
Fan Speeds (rpm): N/A
Packages: 1432 pm: pacman pkgs: 1417 libs: 368 tools: pamac,yay pm: flatpak
pkgs: 15
1: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
3: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
4: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
5: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://mirror.init7.net/manjaro/stable/$repo/$arch
7: https://manjaro.ynh.ovh/stable/$repo/$arch
8: https://mirror.funami.tech/manjaro/stable/$repo/$arch
9: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
10: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
11: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
12: https://muug.ca/mirror/manjaro/stable/$repo/$arch
13: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
14: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
15: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
16: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
17: https://mirror.23m.com/manjaro/stable/$repo/$arch
18: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
19: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
20: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
21: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
22: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
23: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
24: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
25: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
26: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
27: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
28: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
29: http://manjaro.mirrors.theom.nz/manjaro/stable/$repo/$arch
30: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
31: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
32: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
33: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
34: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
35: https://mirrors.manjaro.org/repo/stable/$repo/$arch
36: https://mirror.dc.uz/manjaro/stable/$repo/$arch
37: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
38: http://mirror.fcix.net/manjaro/stable/$repo/$arch
39: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
40: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
41: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
42: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
43: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
44: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
45: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
46: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
47: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
48: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
49: https://repos.silknet.com/manjaro/stable/$repo/$arch
50: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
51: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
52: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
53: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
54: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
55: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
56: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
57: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
58: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
59: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
60: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
61: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
62: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
63: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
64: https://mirrors2.manjaro.org/stable/$repo/$arch
65: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
66: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
67: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
68: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
69: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
70: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
71: https://manjaro.kyberorg.fi/stable/$repo/$arch
72: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
73: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
74: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
75: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
76: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
77: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
78: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
79: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
80: https://mirror.koddos.net/manjaro/stable/$repo/$arch
81: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
82: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
83: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
84: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
85: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
86: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
87: https://linorg.usp.br/manjaro/stable/$repo/$arch
88: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
89: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
90: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
91: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
92: https://manjaro.kurdy.org/stable/$repo/$arch
93: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
94: http://manjaro.grena.ge/stable/$repo/$arch
95: https://mirror.easyname.at/manjaro/stable/$repo/$arch
96: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
97: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
98: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
99: https://mirrors.netix.net/manjaro/stable/$repo/$arch
100: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
101: https://mirror.erickochen.nl/manjaro/stable/$repo/$arch
102: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
103: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
104: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
105: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
106: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
107: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
108: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
109: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
110: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
111: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
112: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
113: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
114: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
115: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
116: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
117: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 280
1: cpu: 400% command: ps pid: 5637 mem: 4.22 MiB (0.0%)
2: cpu: 14.5% command: firefox pid: 1769 mem: 521.4 MiB (2.9%)
3: cpu: 5.8% command: cinnamon pid: 1489 mem: 259.2 MiB (1.4%)
4: cpu: 4.7% command: Xorg pid: 875 mem: 172.0 MiB (0.9%)
5: cpu: 4.4% command: firefox pid: 1989 mem: 228.9 MiB (1.2%)
Memory top: 5 of 280
1: mem: 521.4 MiB (2.9%) command: firefox pid: 1769 cpu: 14.5%
2: mem: 450.0 MiB (2.5%) command: firefox pid: 3925 cpu: 4.0%
3: mem: 359.3 MiB (2.0%) command: firefox pid: 2537 cpu: 1.5%
4: mem: 293.0 MiB (1.6%) command: firefox pid: 2053 cpu: 0.7%
5: mem: 279.6 MiB (1.5%) command: firefox pid: 2895 cpu: 2.3%
Processes: 280 Power: uptime: 42m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.99 GiB services: csd-power,upowerd
Init: systemd v: 255 default: graphical tool: systemctl
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Bash v: 5.2.26
running-in: gnome-terminal inxi: 3.3.34
lsusb -t:
/: Bus 001.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/4p, 480M
/: Bus 002.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/4p, 10000M
/: Bus 003.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/2p, 480M
/: Bus 004.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/1p, 10000M
hwinfo --usb-ctrl
08: PCI 500.3: 0c03 USB Controller (XHCI)
[Created at pci.386]
Unique ID: pb96.Hv+FGJY1z80
Parent ID: JZZT.N70T6T_iyf8
SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:05:00.3
SysFS BusID: 0000:05:00.3
Hardware Class: usb controller
Model: "AMD Raven USB 3.1"
Vendor: pci 0x1022 "AMD"
Device: pci 0x15e0 "Raven USB 3.1"
SubVendor: pci 0x1025 "Acer Incorporated [ALI]"
SubDevice: pci 0x1456
Driver: "xhci_hcd"
Driver Modules: "xhci_pci"
Memory Range: 0xc0700000-0xc07fffff (rw,non-prefetchable)
IRQ: 34 (no events)
Module Alias: "pci:v00001022d000015E0sv00001025sd00001456bc0Csc03i30"
Driver Info #0:
Driver Status: xhci_pci is active
Driver Activation Cmd: "modprobe xhci_pci"
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #20 (PCI bridge)
21: PCI 500.4: 0c03 USB Controller (XHCI)
Unique ID: hwex.oJy+ktfkUX0
SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:05:00.4
SysFS BusID: 0000:05:00.4
Device: pci 0x15e1 "Raven USB 3.1"
Driver: "xhci_hcd"
Memory Range: 0xc0600000-0xc06fffff (rw,non-prefetchable)
IRQ: 43 (no events)
Module Alias: "pci:v00001022d000015E1sv00001025sd00001456bc0Csc03i30"
Driver Info #0:
sudo inxi -Fazc0 --usb:
avail: cinnamon-screensaver dm: LightDM v: 1.32.0 Distro: Manjaro
base: Arch Linux
Type: Laptop System: Acer product: Aspire A315-23 v: V1.21 serial: <filter>
Mobo: DL model: Lotus_DA v: V1.21 serial: <filter>
part-nu: 0000000000000000 uuid: b854e3ca-854a-2e4c-96dd-b4a9fca2c912
UEFI: Insyde v: 1.21 date: 09/08/2022
ID-1: BAT1 charge: 15.5 Wh (59.2%) condition: 26.2/37.0 Wh (70.7%)
status: discharging
Info: model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx socket: FP5
bits: 64 type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3
note: check built: 2019 process: GF 12nm family: 0x17 (23)
model-id: 0x18 (24) stepping: 1 microcode: 0x8108109
desc: 1x4 MiB
Speed (MHz): avg: 1400 min/max: 1400/2100 boost: enabled
base/boost: 2100/3700 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1400 2: 1400 3: 1400 4: 1400
5: 1400 6: 1400 7: 1400 8: 1400 bogomips: 33609
chip-ID: 1002:15d8 class-ID: 0300 temp: 44.0 C
Display: server: X.org v: 1.21.1.12 with: Xwayland v: 23.2.6 driver: X:
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
Server-2: PipeWire v: 1.0.3 status: n/a (root, process) tools: pw-cli
Server-3: PulseAudio v: 17.0 status: active (root, process)
with: pulseaudio-alsa type: plugin tools: pacat,pactl,pavucontrol
used: 108.51 GiB (29.6%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5
used: 70.8 MiB (73.8%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
System Temperatures: cpu: 44.6 C mobo: N/A gpu: amdgpu temp: 44.0 C
Memory: total: 20 GiB note: est. available: 17.5 GiB used: 3.49 GiB (20.0%)
Processes: 282 Power: uptime: 48m states: freeze,mem,disk suspend: deep
pm: flatpak pkgs: 15 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Sudo (sudo)
v: 1.9.15p5 default: Bash v: 5.2.26 running-in: gnome-terminal
inxi: 3.3.34
I hope I can get at least usb 2.0 working again. USB 3.0 hadn’t mattered for 4 months so it should be fine.
Thank you to everyone who takes their time to help me.
