This is a bit annoying. I use the GUI startup applications tool. I add Guake. I start Guake using the gear button. Exit the GUI startup applications tool and go back in. Guake is not there.
It’s like the Add function never saves anything.
I can’t help with startup applications not saving, but guake
has a start at login option in it’s preferences.
