Hallo Megavolt,
vielen Dank für den Tipp.
Ich habe mal die Warnings und Errors aus den Logfiles extrahiert ( grep -e EE -e WW …)
Hier die Ergebnisse:
Mit 3 D Beschleunigung aus /var/log/XOrg.0.log.old
[ 18.770] Current Operating System: Linux rudolf-virtualbox 5.10.36-2-MANJARO #1 SMP PREEMPT Tue May 11 19:38:44 UTC 2021 x86_64
[ 18.776] (WW) fonts.dir' not found (or not valid) in "/usr/share/fonts/misc". [ 18.777] (WW)
fonts.dir’ not found (or not valid) in “/usr/share/fonts/TTF”.
[ 18.777] (WW) The directory “/usr/share/fonts/OTF” does not exist.
[ 18.777] (WW) The directory “/usr/share/fonts/Type1” does not exist.
[ 18.777] (WW) The directory “/usr/share/fonts/100dpi” does not exist.
[ 18.777] (WW) The directory “/usr/share/fonts/75dpi” does not exist.
[ 18.809] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 19.112] (WW) Warning, couldn’t open module fbdev
[ 19.112] (EE) Failed to load module “fbdev” (module does not exist, 0)
[ 19.112] (WW) Warning, couldn’t open module vesa
[ 19.112] (EE) Failed to load module “vesa” (module does not exist, 0)
[ 19.128] (WW) Falling back to old probe method for modesetting
[ 19.176] (II) Initializing extension MIT-SCREEN-SAVER
[ 19.475] (**) Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:06.0/usb2/2-1/2-1:1.0/0003:80EE:0021.0001/input/input4/event3”
[ 27.985] (EE) event5 - VirtualBox mouse integration: client bug: event processing lagging behind by 11ms, your system is too slow
Software Rendering Mode aus /var/log/XOrg.0.log
[ 19.859] Current Operating System: Linux rudolf-virtualbox 5.10.36-2-MANJARO #1 SMP PREEMPT Tue May 11 19:38:44 UTC 2021 x86_64
[ 19.875] (WW) fonts.dir' not found (or not valid) in "/usr/share/fonts/misc". [ 19.877] (WW)
[ 19.877] (WW) The directory “/usr/share/fonts/OTF” does not exist.
[ 19.877] (WW) The directory “/usr/share/fonts/Type1” does not exist.
[ 19.877] (WW) The directory “/usr/share/fonts/100dpi” does not exist.
[ 19.877] (WW) The directory “/usr/share/fonts/75dpi” does not exist.
[ 19.903] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 20.187] (WW) Warning, couldn’t open module fbdev
[ 20.187] (EE) Failed to load module “fbdev” (module does not exist, 0)
[ 20.187] (WW) Warning, couldn’t open module vesa
[ 20.187] (EE) Failed to load module “vesa” (module does not exist, 0)
[ 20.193] (WW) Falling back to old probe method for modesetting
[ 20.247] (II) Initializing extension MIT-SCREEN-SAVER
[ 20.582] (**) Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:06.0/usb2/2-1/2-1:1.0/0003:80EE:0021.0001/input/input4/event3”
Ausgeschaltete 3D Beschleunigung aus /var/log/XOrg.0.log
[ 20.169] Current Operating System: Linux rudolf-virtualbox 5.10.36-2-MANJARO #1 SMP PREEMPT Tue May 11 19:38:44 UTC 2021 x86_64
[ 20.188] (WW) fonts.dir' not found (or not valid) in "/usr/share/fonts/misc". [ 20.189] (WW)
[ 20.189] (WW) The directory “/usr/share/fonts/OTF” does not exist.
[ 20.189] (WW) The directory “/usr/share/fonts/Type1” does not exist.
[ 20.190] (WW) The directory “/usr/share/fonts/100dpi” does not exist.
[ 20.190] (WW) The directory “/usr/share/fonts/75dpi” does not exist.
[ 20.214] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 20.497] (WW) Warning, couldn’t open module fbdev
[ 20.497] (EE) Failed to load module “fbdev” (module does not exist, 0)
[ 20.497] (WW) Warning, couldn’t open module vesa
[ 20.497] (EE) Failed to load module “vesa” (module does not exist, 0)
[ 20.514] (WW) Falling back to old probe method for modesetting
[ 20.524] (WW) vmware(0): Failed to initialize Gallium3D Xa. No render acceleration available.
[ 20.524] (WW) vmware(0): Skipped initialization of direct rendering due to lack of render acceleration.
[ 20.525] (WW) vmware(0): Disabling Xv because no adaptors could be initialized.
Mit ausgeschalteter 3 D Beschleunigung verhält sich das System wie im Software Rendering Mode .
Habe in der VM dann unter Manjaro Settings → Hardware → Displaycontroller ( VMWARE405) noch die Module video-modesetting und video-vesa installiert .
Ich hatte gedacht das dann evtl. zu mindestens die Fehlermeldung Failed to load module “vesa” (module does not exist, 0) verschwinden würde, was sich negativ ausgewirkt hat ( es erscheint kein Login Screen mehr ).
Da ich die virtuellen Maschinen ausschliesslich zum Onlinebanking oder ausprobieren von Software verwende denke ich das ich ohne 3D Beschleunigung leben kann.
Evtl. behebt sich das Problem mit einem der nächsten Updates ja wieder.
Was ist Deine Meinung ???
MfG
Rudi
