I have previously been able to chroot into my root volume using the following commands:
sudo mount /dev/nvme0p2 /mnt
manjaro-chroot /mnt/@
However, when I tried this today, I got the following error message:
mount: /mnt/@/etc/resolv.conf: mount point is a symbolic link to nowhere. dmesg(1) may have more information after failed mount system call.
My subvolume layout is the standard Timeshift one:
❯ sudo btrfs subvolume list -p /
ID 258 gen 687344 parent 5 top level 5 path @cache
ID 259 gen 687345 parent 5 top level 5 path @log
ID 260 gen 527980 parent 5 top level 5 path @swap
ID 3482 gen 687345 parent 5 top level 5 path @home
ID 4617 gen 687344 parent 5 top level 5 path @
ID 4964 gen 686520 parent 5 top level 5 path timeshift-btrfs/snapshots/2023-04-21_09-27-54/@
ID 4965 gen 684035 parent 5 top level 5 path timeshift-btrfs/snapshots/2023-04-21_09-27-54/@home
ID 4966 gen 686520 parent 5 top level 5 path timeshift-btrfs/snapshots/2023-04-21_21-00-01/@
ID 4967 gen 685205 parent 5 top level 5 path timeshift-btrfs/snapshots/2023-04-21_21-00-01/@home
ID 4968 gen 686520 parent 5 top level 5 path timeshift-btrfs/snapshots/2023-04-22_21-00-01/@
ID 4969 gen 686411 parent 5 top level 5 path timeshift-btrfs/snapshots/2023-04-22_21-00-01/@home
I tried manjaro-chroot /mnt as well. I have used these commands before, they’re from a previous (now disappeared post) on this forum and they worked without problems.
You first have to look after the mount. If the mount fails, chroot can’t work.
The mount also may depend on your actual fstab. If you do not give any options in the mount, it will use the options specified in fstab (if there is a line for this mountpoint)
You also can find good Information about Btrfs in the wiki
