trying to reinstall grub after reinstalling windows which was installed along side manjaro kde.
on the use manjaro-chroot part
i’m getting command not found error
i realized that after running following command ,
root # manjaro-chroot /mnt /bin/bash
the terminal is considering the manjaro installation in disk as the root partition therefore manjaro-chroot doesnt exist in /usr/bin . So what do i do now?
if not installed, for find a file :
sudo pacman -Fy # update database
pacman -F manjaro-chroot
result:
extra/manjaro-tools-base 0.15.12-1 (manjaro-tools) [installé: 0.15.13-1]
usr/bin/manjaro-chroot
extra/manjaro-tools-base-git r2952.bc23dce-1 (manjaro-tools)
or more simple ?
pamac search manjaro-chroot --files
sudo pacman -Syu manjaro-tools-base
core.db failed to download
error: failed retrieving file 'core.db' from repo.skni.umcs.pl : Could not resolve host: repo.skni.umcs.pl
warning: too many errors from repo.skni.umcs.pl, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from mirror.datacenter.by : Could not resolve host: mirror.datacenter.by
warning: too many errors from mirror.datacenter.by, skipping for the remainder of this transaction
error: failed retrieving file 'core.db' from manjaro.mirrors.theom.nz : Could not resolve host: manjaro.mirrors.theom.nz
warning: too many errors from manjaro.mirrors.theom.nz, skipping for the remainder of this transaction
error: failed to synchronize all databases (invalid url for server)
i’m connected through ethernet
can i just move that script to the mounted location and then run it?
Thank you for that
trying to install anything gets me
[manjaro ~]# sudo pacman -Syu manjaro-tools-base
core is up to date
extra is up to date
community is up to date
multilib is up to date
warning: manjaro-tools-base-0.15.13-1 is up to date -- reinstalling
resolving dependencies...
Packages (1) manjaro-tools-base-0.15.13-1
Total Installed Size: 0.07 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n] Y
(1/1) checking keys in keyring [#######################################] 100%
(1/1) checking package integrity [#######################################] 100%
(1/1) loading package files [#######################################] 100%
(1/1) checking for file conflicts [#######################################] 100%
(1/1) checking available disk space [#######################################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(1/1) reinstalling manjaro-tools-base [#######################################] 100%
(1/2) Arming ConditionNeedsUpdate...
(2/2) Refreshing PackageKit...
Error connecting: Could not connect: No such file or directory
error: command failed to execute correctly
Wait, from which environment are you running the command? It will be present if you boot the live image from USB.
Reinstall of grub was unnecessary in my case so i was able boot into my manjaro installation . Thank you for your time
