Hello,
I cannot prepare Manjaro for installation on this machine, it barely starts when it ‘boots’, in the option that asks for drivers, whether I choose proprietary or not, it does not respond when I click on these options, it does not go anywhere, other options such as language, etc, work… Could it be that Manjaro cannot be installed on older machines like this one? Thanks.
@ThinkPad-Yoga-11e-3rd-Gen:~$ inxi -v7azy
Kernel: 5.15.0-100-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.15.0-100-generic
root=UUID=a82cd2f0-bbdc-4b38-bb34-f981e895ce1b ro quiet splash
Desktop: Xfce 4.18.1 tk: Gtk 3.24.33 info: xfce4-panel wm: xfwm 4.18.0
vt: 7 dm: LightDM 1.30.0 Distro: Linux Mint 21.3 Virginia
base: Ubuntu 22.04 jammy
Type: Convertible System: LENOVO product: 20G8S04G00
v: ThinkPad Yoga 11e 3rd Gen serial: <superuser required> Chassis: type: 31
Mobo: LENOVO model: Intel powered classmate PC
serial: <superuser required> UEFI: LENOVO v: R0AET38W (1.21)
date: 01/21/2019
ID-1: BAT1 charge: 38.0 Wh (99.7%) condition: 38.1/42.0 Wh (90.6%)
volts: 12.6 min: 11.4 model: LGC LNV-00HW043 type: Li-poly serial: <filter>
status: Not charging
RAM: total: 3.65 GiB used: 1.61 GiB (44.2%)
RAM Report:
Info: model: Intel Celeron N3150 bits: 64 type: MCP arch: Airmont family: 6
model-id: 0x4C (76) stepping: 3 microcode: 0x368
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB
desc: d-4x24 KiB; i-4x32 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 589 high: 778 min/max: 480/2080 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 620 2: 778 3: 480 4: 480
bogomips: 12800
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_perfmon bts
clflush cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb
erms est fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear mmx monitor
movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pclmulqdq pdcm pebs pge pni
popcnt pse pse36 pti rdrand rdtscp rep_good sep smep ss sse sse2 sse4_1
sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer
tsc_known_freq tsc_reliable vme xtopology xtpr
Type: spec_store_bypass status: Not affected
STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
Integrated Graphics
vendor: Lenovo driver: i915 v: kernel ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:22b1
class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:3 chip-ID: 04f2:b55d class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.4 compositor: xfwm v: 4.18.0 driver:
X: loaded: modesetting unloaded: fbdev,vesa gpu: i915 display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP-1 model: Samsung built: 2015 res: 1366x768 hz: 60 dpi: 136
gamma: 1.2 size: 256x144mm (10.1x5.7") diag: 294mm (11.6") ratio: 16:9
modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 400 (BSW)
v: 4.6 Mesa 23.2.1-1ubuntu3.1~22.04.2 direct render: Yes
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
High Definition Audio
vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:2284 class-ID: 0403
Sound Server-1: ALSA v: k5.15.0-100-generic running: yes
Sound Server-2: PulseAudio v: 15.99.1 running: yes
Sound Server-3: PipeWire v: 0.3.48 running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 1000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:095b class-ID: 0280
IP v6: <filter> type: temporary dynamic scope: global
IP v6: <filter> type: dynamic mngtmpaddr noprefixroute scope: global
bus-ID: 1-5:4 chip-ID: 8087:0a2a class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 2.1
lmp-v: 4.2 sub-v: 1000 hci-v: 4.2 rev: 1000
Info: acl-mtu: 1021:5 sco-mtu: 96:6 link-policy: rswitch hold sniff
link-mode: peripheral accept
service-classes: rendering, capturing, audio, telephony
Local Storage: total: 233.84 GiB used: 60.32 GiB (25.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZNTY128HDHP-000L1
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 3L0Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: USB 3.2Gen1
size: 114.6 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: GPT
ID-1: / raw-size: 42.12 GiB size: 41.16 GiB (97.73%) used: 16.6 GiB (40.3%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: LinuxMint
uuid: a82cd2f0-bbdc-4b38-bb34-f981e895ce1b
used: 6.2 MiB (1.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 03B5-3946
ID-3: /media/keos/86BD-26B9 raw-size: 29.57 GiB size: 29.55 GiB (99.95%)
used: 5.29 GiB (17.9%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 86BD-26B9
ID-4: /media/keos/Debian-12 raw-size: 14.74 GiB size: 14.22 GiB (96.47%)
used: 11.38 GiB (80.0%) fs: ext4 dev: /dev/sdb4 maj-min: 8:20
label: Debian-12 uuid: 6f8314ff-48e4-4afb-9402-adea4bcaba17
ID-5: /media/keos/LinuxMint raw-size: 17.67 GiB size: 17.1 GiB (96.76%)
used: 14.69 GiB (85.9%) fs: ext4 dev: /dev/sdb3 maj-min: 8:19
label: LinuxMint uuid: 7b468763-5ba5-4aff-b6e7-727f96db1283
ID-6: /media/keos/Manjaro raw-size: 15.48 GiB size: 14.94 GiB (96.56%)
used: 12.36 GiB (82.7%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: Manjaro
uuid: b263f48a-8ada-4e3d-afe8-fdf74eab2e28
ID-1: swap-1 type: file size: 1.95 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sda2 maj-min: 8:2 size: 48.68 GiB fs: ext4 label: rootMX21
uuid: 3f171e56-a218-4f57-936a-9c3f43e48e0e
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 7 rev: 2.0
Device-1: 1-1:2 info: Areson Corp Laser mouse type: Mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 25a7:2410 class-ID: 0300
Device-2: 1-3:3 info: Chicony Integrated Camera type: Video
Device-3: 1-5:4 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
Device-1: 2-2:2 info: SanDisk Ultra Flair type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s power: 896mA
chip-ID: 0781:5591 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 45.0 C mobo: 0.0 C
Fan Speeds (RPM): cpu: 3816
Processes: 240 Uptime: 27m wakeups: 2 Init: systemd v: 249 runlevel: 5
tool: systemctl Compilers: gcc: 11.4.0 alt: 11/12 clang: 14.0.0-1ubuntu1.1
Packages: apt: 2664 lib: 1486 flatpak: 0 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.13
Hi @Alnone ,
I highly doubt that it can not be done. However, just because you can do something, doesn’t mean you should do it.
In this case, especially since
…nowadays that is very little RAM. I’ve heard that at least 8GB is recommended these days. And
…as far as I know, the Celerons were never the best processors, so that’s a second bottleneck, according to me.
So I’d suggest rather looking at, and considering one of the more lightweight community editions, especially since it seems you don’t have much, if anything to loose:
Hope it helps!
6x12
10 March 2024 12:48
3
What DE are you trying to run? Xfce or Mate works fine with 4GB and integrated graphics; best install the minimal version and add what you need. Avoid transparencies and other eye candy and you should be good. In my experience Manjaro Xfce minimal is leaner than Mint’s Xfce.
With the weak integrated graphics of your processor I’d stay away from Gnome/KDE/Cinnamon.
Is secure boot disabled in the BIOS/UEFI?
This is the only option to Xfce4 that I can see:
@Mirdarthos actually suggested that you try:
On the Manjaro download page… scroll down, dude.
I don’t think it’s a performance issue. Obviously Manjaro gnome works on that hardware:
[Screenshot from 2022-09-05 20-32-05]
[Screenshot from 2022-09-05 20-37-54]
Well, one week ago I bought a Laptop Lenovo Yoga 11e, it was installed Windows 10 and right now I just installed Manjaro Gnome. Everything works very well and I have more memory unlike Windows 10 but when I turn my laptop to tablet iio-sensor-proxy recognize the position but auto-rotate-screen doesn’t work
is there some solution for that??
Maybe the used usb stick / ISO is corrupted?
System resources, or lack thereof, can certainly contribute. On the same system with additional RAM, and possibly an SSD, Gnome or KDE might install without issue; whether it would, or not, is not as obvious as you suggest.
However, the USB drive indeed could be a bottleneck of sorts; especially if it were only USB2; an even greater problem if it was borked somehow.
I would suggest the OP creates a VENTOY USB instead of writing an ISO to a USB; which can often not go as planned:
I strongly recommend using a Ventoy USB to boot any ISO you choose. The beauty of using Ventoy is that nothing else is needed.
Simply copy/drag any ISO to the Ventoy USB, and you’re done.
Boot with a Ventoy USB, and ISO files are automatically listed in the Ventoy menu, and can be booted directly. A 32GB (minimum) capacity USB should allow ample space to store several ISOs of your choice.
Ventoy is available from the official Manjaro extra repository:
sudo pacman -S ventoy
Type ventoy
(without arguments) to see usage information:
Usage: Ventoy2Disk.sh CMD [ OPTION ] /dev/sdX
CMD:
-i install Ventoy to sdX (fails if disk already installed with Ventoy)
-I force install Ventoy to sdX (no matter if installed or not)
-u update Ventoy in sdX
-l list Ventoy information in sdX
OPTION: (optional)
-r SIZE_MB preserve some space at the bottom of the disk (only for install)
-s/-S enable/disable secure boot support (default is enabled)
-g use GPT partition style, default is MBR (only for install)
-L Label of the 1st exfat partition (default is Ventoy)
-n try non-destructive installation (only for install)
Write the Ventoy system to an empty USB drive;
use /dev/sdX
to target the device itself, and not a partition:
sudo sh ventoy -i -r 100 -S -g -L VOLUME /dev/sdX
Substitute VOLUME
for a volume label name to use.
Substitute /dev/sdX
for the location of your USB device.
Preserve some space on the target device (example allows 100mb).
See also: Ventoy (GitHub);
soundofthunder:
According to the neofetch data in the linked thread the machine mentioned has 4GB of RAM also. If RAM was not upgraded presumably the stock harddrive (Toshiba MQ01ACF050 with 500 GB) wasn’t either.
fumum_vendidi:
4GB of RAM
Point being, each machine needs to be evaluated on a case by case basis. What may seem sufficient for one, may not be for another. Likely, the OP’s dilemma is a result of a combination of factors; system resources may play a part, just as much as other factors we might not be privy to, might contribute. I can assume without fact checking that the Toshiba drive is likely on the slower end of the spectrum, for example.
Aside:- 4GB (especially now) is generally insufficient RAM for most systems, whether it be Linux, Mac or Windows. That’s a given. 4GB might often be touted as enough to run [enter OS here] but in reality, is only the minimum required. I like to run software on top of any OS I use, which, depending on the requirements of that software, can invariably demand more resources.
Despite all that, it could simply be as you suggest, a borked USB. I guess we’ll wait and see what other useful information the OP can provide. Cheers.
I tried with another USB, I also changed to another ‘port’, no result, but now I try it on this other machine and it works correctly:
[alnone@alnone-inspiron3583 ~]$ inxi -v7azy
Kernel: 6.6.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=b263f48a-8ada-4e3d-afe8-fdf74eab2e28 rw quiet splash apparmor=1
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: Dell product: Inspiron 3583 v: N/A
Mobo: Dell model: 0WHCP7 v: A00 serial: <superuser required> part-nu: 08CA
uuid: <superuser required> UEFI: Dell v: 1.5.1 date: 05/30/2019
ID-1: BAT0 charge: 39.9 Wh (100.0%) condition: 39.9/42.0 Wh (95.0%)
volts: 12.7 min: 11.4 model: SMP DELL VM73283 type: Li-poly serial: <filter>
status: full
System RAM: total: 8 GiB available: 7.63 GiB used: 1.77 GiB (23.2%)
Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None
Device-1: DIMM A type: no module installed
Device-2: DIMM B type: DDR4 detail: synchronous size: 8 GiB speed:
spec: 2667 MT/s actual: 2400 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: 80AD000080AD
part-no: HMA81GS6JJR8N-VK serial: <filter>
Info: model: Intel Core i5-8265U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 8 level: v3 note: check
built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xF8
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 551 high: 810 min/max: 400/3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 400 3: 800 4: 400
5: 400 6: 810 7: 400 8: 400 bogomips: 28808
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Dell
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:3ea0
class-ID: 0300
Device-2: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 0bda:5520
Display: x11 server: X.org v: 1.21.1.11 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0.0 note: <missing: xdpyinfo/xrandr>
Monitor-1: eDP-1 model: AU Optronics 0x10ec built: 2017 res: 1366x768
dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (WHL GT2)
device-ID: 8086:3ea0 memory: 7.45 GiB unified: yes
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
API: ALSA v: k6.6.19-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000
bus-ID: 01:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Info: services: NetworkManager
Local Storage: total: 245.83 GiB used: 16.47 GiB (6.7%)
model: PC SN520 NVMe WDC 256GB size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: 20200012 temp: 44.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: Cruzer Glide
size: 7.36 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1.27
scheme: MBR
ID-1: / raw-size: 42.87 GiB size: 41.9 GiB (97.74%) used: 16.45 GiB (39.3%)
fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7 label: Manjaro
ID-2: /boot/efi raw-size: 1.43 GiB size: 1.43 GiB (99.80%)
used: 22.4 MiB (1.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 6693-9A38
ID-1: swap-1 type: partition size: 1.42 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 73e9a0ff-1e34-4792-8aab-b1eda8c17f07
ID-1: /dev/nvme0n1p3 maj-min: 259:3 size: 39.58 GiB fs: ext4 label: rootMX21
uuid: 18dde8e5-0707-421f-ba5a-551a6863f412
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 45.48 GiB fs: ext4
label: rootMX23 uuid: 10236dfd-8fba-48f5-b7cf-27aa1df5a9e7
ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 48.48 GiB fs: ext4
ID-4: /dev/nvme0n1p6 maj-min: 259:6 size: 59.21 GiB fs: ext4
ID-5: /dev/sda1 maj-min: 8:1 size: 3.52 GiB fs: iso9660
ID-6: /dev/sda2 maj-min: 8:2 size: 4 MiB fs: vfat label: MISO_EFI
uuid: AC16-6392
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-2:2 info: Areson Corp 2.4G Receiver type: keyboard,mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 25a7:fa67 class-ID: 0301
Device-2: 1-3:5 info: SanDisk Cruzer Glide type: mass storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 200mA chip-ID: 0781:5575 class-ID: 0806
serial: <filter>
Device-3: 1-6:3 info: Realtek Integrated_Webcam_HD type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 0bda:5520 class-ID: 0e02 serial: <filter>
Device-4: 1-8:4 info: Elan Micro Touchscreen type: HID
driver: hid-multitouch,usbhid interfaces: 1 rev: 2.0
chip-ID: 04f3:24dd class-ID: 0300
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
System Temperatures: cpu: 44.0 C pch: 43.0 C mobo: 37.0 C
Fan Speeds (rpm): cpu: 0
Processes: 245 Power: uptime: 9m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.04 GiB services: upowerd,xfce4-power-manager
Init: systemd v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1193 libs: 385 tools: octopi,pamac,yay
pm: flatpak pkgs: 0 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Bash
v: 5.2.26 running-in: xfce4-terminal inxi: 3.3.33
Alnone:
This other machine with 8GB of RAM may have been beneficial. You might consider (as @Mirdarthos previously suggested) opting for a more lightweight distribution for the Thinkpad. It doesn’t strictly need to be XFCE, does it?
6x12
10 March 2024 15:28
13
It was:
type: SSD
Hit ‘Download’ and you get:
I was going to suggest this - the minimal installs and works fine in a VM with 4GB alotted RAM.
Note that the “minimal” there only refers to the number of packages that come preinstalled, if I’m not mistaken.
Hence my suggestion of a lightweight community edition.
There are people with visual difficulties, the font configuration in my sisyema is very large, the ‘min-max’ option does not appear, it is covered up … – … someone should fix that format, whatever …
Thanks 6x12, for the graphic … I’m just downloading it, maybe that’s all …
Hmm - I don’t know the boot process of the live iso - could be that it is loaded to RAM and started from there - then things get tight.
That is true, yes.
I have no idea about the Live environments, but my Linux, with Plasma, after startup uses ±2GB Ram. But it’s heavily optimized for me. The Live environment has to be a lot more generic and as such probably uses quite a bit more.
6x12
10 March 2024 15:59
19
I think that (basically a calamares issue) might be it. We had similar discussions before and it was mentioned that older (and smaller) iso worked when the later ones didn’t. I also think some architect/iso-tools install might work too.
As to how much ram one can work with; it depends on the user, I remember talking to a guy here who said his pre 2010 runs fine on 2GB. For surfing with a couple of open tabs and playing music xfce never goes above 2GB.
The same story as before …
… opting for a more lightweight distribution for the Thinkpad. It doesn’t strictly need to be XFCE, does it?
*If there is a possibility to install Xfce4 later that would be fine with me, the space I have on that partition is 27GB – if this is possible please, which one do you recommend?. Thanks.
