I am using Manjaro KDE plasma. It used to boot up very quickly, but now it shows an error message for a minute before it boots up. Here is the complete error message
(i referred other posts regarding similar issue, but i think it’s little different)
/dev/sda1: clean , 1242362/30490624 files, 24726998/121938688 blocks
Timed out waiting for device /dev/disk/by-uuid
Dependency failed for swaps
And it eventually boots up, i guess it is because of swaps, not sure.
Manjaro is istalled at /dev/sda1
Swap is at /dev/sda4
Here is the output of cat /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=dedc4a68-08eb-4090-95ec-a36241437bb0 / ext4 defaults,noatime 0 1
UUID= none swap defaults 0 0
UUID=c6c4cefa-4ba0-4b77-afba-15e9c328d8aa none swap defaults 0 0
Here is the output of sudo blkid
/dev/loop1: TYPE="squashfs"
/dev/loop8: TYPE="squashfs"
/dev/loop6: TYPE="squashfs"
/dev/loop13: TYPE="squashfs"
/dev/loop4: TYPE="squashfs"
/dev/loop11: TYPE="squashfs"
/dev/loop2: TYPE="squashfs"
/dev/loop0: TYPE="squashfs"
/dev/loop9: TYPE="squashfs"
/dev/loop7: TYPE="squashfs"
/dev/sda4: UUID="c6c4cefa-4ba0-4b77-afba-15e9c328d8aa" TYPE="swap" PARTUUID="00e67923-04"
/dev/sda2: UUID="cb3beea4-6fc5-466e-9391-229949bdf404" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="00e67923-02"
/dev/sda9: UUID="ea90aa1a-9d91-4226-ab3f-39be59760704" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="00e67923-09"
/dev/sda7: UUID="fd809198-8aa8-4037-8fd1-b52ff56d064d" TYPE="swap" PARTUUID="00e67923-07"
/dev/sda5: UUID="1dba1425-97ad-498e-8728-4f3f3b00ada4" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="00e67923-05"
/dev/sda1: UUID="dedc4a68-08eb-4090-95ec-a36241437bb0" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="00e67923-01"
/dev/sda8: UUID="3fcb4471-1807-49b7-b16c-6642cde2171b" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="00e67923-08"
/dev/sda6: LABEL="parrot-syste" UUID="02167e28-75da-49b5-ba53-a2850b6425f6" BLOCK_SIZE="4096" TYPE="xfs" PARTUUID="00e67923-06"
/dev/loop14: TYPE="squashfs"
/dev/loop5: TYPE="squashfs"
/dev/loop12: TYPE="squashfs"
/dev/loop3: TYPE="squashfs"
/dev/loop10: TYPE="squashfs"
