Hello, kinda new to manjaro here and first time forum user.
I have been using Manjaro as a daily driver for about a year now (Prev windows user).
Today i had a power outage and when i powered on my pc it booted in emergency mode with the following messages:
Timed out waiting for device /dev/device… and the uuid of the partition
Dependency failed for /boot/efi
this also hapens for the root and swap partition…
I am able to boot to my system when exiting out of emergency mode but on restart i boot back to emergency mode.
I have tried other kernels (6.3, 6.2, 6.1, 5.15) but its all the same.
I have tried repairing the partitions with fsck from Manjaro live but nothing happens.
I have tried running mkinitcpio -P still nothing.
I checked the uuid in /etc/fstab with the output of blkid and they are the same.
How can i solve this? I have read other similar forum posts about this but nothing helped me.
fstab:
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=5DCE-90EE /boot/efi vfat umask=0077 0 2
UUID=d98ac944-f9cc-43c9-acd0-152b5f7b3586 / ext4 defaults,noatime 0 1
UUID=46fc092e-df39-47fc-b405-b08088a5d44b swap swap defaults,noatime 0 0
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
blkid:
/dev/sda1: LABEL_FATBOOT="NO_LABEL" LABEL="NO_LABEL" UUID="5DCE-90EE" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="3b6fec47-9d71-3d45-b357-584f2d3f912f"
/dev/sda2: UUID="d98ac944-f9cc-43c9-acd0-152b5f7b3586" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="root" PARTUUID="3188563a-c2fe-2e44-94f0-d005e6f30d48"
/dev/sda3: LABEL="swap" UUID="46fc092e-df39-47fc-b405-b08088a5d44b" TYPE="swap" PARTUUID="578861dd-744d-ba42-b01d-c4c4c7507f5c"
/dev/sdb5: BLOCK_SIZE="512" UUID="77B20B414C2D84A9" TYPE="ntfs" PARTUUID="0d7735aa-05"
/dev/sdc5: BLOCK_SIZE="512" UUID="4E797E480B19B2A7" TYPE="ntfs" PARTUUID="56ed03ca-05"
lsblk -f
AME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0
squash 4.0 0 100% /var/lib/snapd/snap/bare/5
loop1
squash 4.0 0 100% /var/lib/snapd/snap/code/128
loop2
squash 4.0 0 100% /var/lib/snapd/snap/code/129
loop3
squash 4.0 0 100% /var/lib/snapd/snap/core/14784
loop4
squash 4.0 0 100% /var/lib/snapd/snap/core/14946
loop5
squash 4.0 0 100% /var/lib/snapd/snap/core18/2745
loop6
squash 4.0 0 100% /var/lib/snapd/snap/core18/2751
loop7
squash 4.0 0 100% /var/lib/snapd/snap/core20/1879
loop8
squash 4.0 0 100% /var/lib/snapd/snap/core20/1891
loop9
squash 4.0 0 100% /var/lib/snapd/snap/cpu-monitoring-webapp/147
loop10
squash 4.0 0 100% /var/lib/snapd/snap/cura-slicer/118
loop11
squash 4.0 0 100% /var/lib/snapd/snap/cura-slicer/121
loop12
squash 4.0 0 100% /var/lib/snapd/snap/flutter/130
loop13
squash 4.0 0 100% /var/lib/snapd/snap/flutter/141
loop14
squash 4.0 0 100% /var/lib/snapd/snap/gamepad-tool/5
loop15
squash 4.0 0 100% /var/lib/snapd/snap/gnome-3-28-1804/194
loop16
squash 4.0 0 100% /var/lib/snapd/snap/gnome-3-28-1804/198
loop17
squash 4.0 0 100% /var/lib/snapd/snap/gnome-3-38-2004/137
loop18
squash 4.0 0 100% /var/lib/snapd/snap/gnome-3-38-2004/140
loop19
squash 4.0 0 100% /var/lib/snapd/snap/gtk-common-themes/1534
loop20
squash 4.0 0 100% /var/lib/snapd/snap/gtk-common-themes/1535
loop21
squash 4.0 0 100% /var/lib/snapd/snap/kde-frameworks-5-96-qt-5-15-5-core20/7
loop22
squash 4.0 0 100% /var/lib/snapd/snap/kde-frameworks-5-qt-5-15-3-core20/8
loop23
squash 4.0 0 100% /var/lib/snapd/snap/leagueoflegends/152
loop24
squash 4.0 0 100% /var/lib/snapd/snap/powertabeditor/7
loop25
squash 4.0 0 100% /var/lib/snapd/snap/powertabeditor/8
loop26
squash 4.0 0 100% /var/lib/snapd/snap/snapd/19122
loop27
squash 4.0 0 100% /var/lib/snapd/snap/snapd/19361
loop28
squash 4.0 0 100% /var/lib/snapd/snap/solvespace/479
loop29
squash 4.0 0 100% /var/lib/snapd/snap/spotify/64
loop30
squash 4.0 0 100% /var/lib/snapd/snap/spotify/67
loop31
squash 4.0 0 100% /var/lib/snapd/snap/wine-platform-5-staging/34
loop32
squash 4.0 0 100% /var/lib/snapd/snap/wine-platform-5-staging/36
loop33
squash 4.0 0 100% /var/lib/snapd/snap/wine-platform-6-stable/19
loop34
squash 4.0 0 100% /var/lib/snapd/snap/wine-platform-runtime/331
loop35
squash 4.0 0 100% /var/lib/snapd/snap/wine-platform-runtime/344
sda
├─sda1
│ vfat FAT32 NO_LABEL
│ 5DCE-90EE 299,1M 0% /boot/efi
├─sda2
│ ext4 1.0 d98ac944-f9cc-43c9-acd0-152b5f7b3586 134,9G 79% /
└─sda3
swap 1 swap 46fc092e-df39-47fc-b405-b08088a5d44b [SWAP]
sdb
├─sdb2
└─sdb5
ntfs 77B20B414C2D84A9
sdc
├─sdc1
└─sdc5
ntfs 4E797E480B19B2A7
what do you mean nohting happens? is there any output or what? can you access your files? were you updating during the power outage?
I am sorry. I recreated the issue.
This is what i get no mater what i try.
Thank you for the reply!
[Edit]
No i was not updating. I was processing vulcan shaders for battlefield V using steam proton
so boot into manjaro live usb, and run fsck on your sda1,2,3 partitions, one at a time:
sudo fsck -f /dev/sda1
sudo fsck -f /dev/sda2
sudo fsck -f /dev/sda3
and yes to all, if you are prompted …
EDIT:
if there were some repairs, reboot and see if it helped
Did it and nothing changed
Output:
sudo su ✔
[manjaro-gnome manjaro]# fsck -f /dev/sda1
fsck from util-linux 2.38.1
fsck.fat 4.2 (2021-01-31)
/dev/sda1: 13 files, 79/76645 clusters
[manjaro-gnome manjaro]# fsck -f /dev/sda2
e2fsck 1.46.5 (30-Dec-2021)
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/sda2: 2155491/58015744 files (1.1% non-contiguous), 185044482/232038308 blocks
[manjaro-gnome manjaro]# fsck -f /dev/sda3
[EDIT]
I also cloned the drive to another ssd with dd and i got the same thing
the fsck looks ok…
chroot:
manjaro-chroot -a
rerun update:
pacman-mirrors --fasttrack 5 && pacman -Syyu
if no errors, and you are up to date, run:
ldconfig
this should return nothing … then post output:
mkinitcpio -P && update-grub
manjaro-chroot -a
Returns this:
manjaro-chroot -a ✔
grub-probe: error: cannot find a GRUB drive for /dev/sdd1. Check your device.map.
==> Mounting (ManjaroLinux) [/dev/sda2]
--> mount: [/mnt]
--> mount: [/mnt/boot/efi]
[manjaro-gnome /]#
Output of the others:
[manjaro-gnome /]# ldconfig
[manjaro-gnome /]#
[manjaro-gnome /]# mkinitcpio -P && update-grub
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img --microcode /boot/intel-ucode.img
==> Starting build: '5.10.181-1-MANJARO'
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [resume]
-> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: '/boot/initramfs-5.10-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect --microcode /boot/intel-ucode.img
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-5.10-x86_64-fallback.img'
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img
==> Starting build: '5.15.114-1-MANJARO'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-5.15-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: '/boot/initramfs-5.15-x86_64-fallback.img'
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'default'
-> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64.img --microcode /boot/intel-ucode.img
==> Starting build: '5.4.244-1-MANJARO'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-5.4-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'fallback'
-> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64-fallback.img -S autodetect --microcode /boot/intel-ucode.img
==> Creating gzip-compressed initcpio image: '/boot/initramfs-5.4-x86_64-fallback.img'
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'default'
-> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64.img --microcode /boot/intel-ucode.img
==> Starting build: '6.1.31-1-MANJARO'
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.1-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'fallback'
-> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64-fallback.img -S autodetect --microcode /boot/intel-ucode.img
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.1-x86_64-fallback.img'
==> Building image from preset: /etc/mkinitcpio.d/linux62.preset: 'default'
-> -k /boot/vmlinuz-6.2-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.2-x86_64.img --microcode /boot/intel-ucode.img
==> Starting build: '6.2.16-1-MANJARO'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.2-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux62.preset: 'fallback'
-> -k /boot/vmlinuz-6.2-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.2-x86_64-fallback.img -S autodetect --microcode /boot/intel-ucode.img
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.2-x86_64-fallback.img'
==> Building image from preset: /etc/mkinitcpio.d/linux63.preset: 'default'
-> -k /boot/vmlinuz-6.3-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.3-x86_64.img --microcode /boot/intel-ucode.img
==> Starting build: '6.3.5-1-MANJARO'
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.3-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux63.preset: 'fallback'
-> -k /boot/vmlinuz-6.3-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.3-x86_64-fallback.img -S autodetect --microcode /boot/intel-ucode.img
==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.3-x86_64-fallback.img'
Found linux image: /boot/vmlinuz-6.3-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.3-x86_64.img
Found initrd fallback image: /boot/initramfs-6.3-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.2-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.2-x86_64.img
Found initrd fallback image: /boot/initramfs-6.2-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.4-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.4-x86_64.img
Found initrd fallback image: /boot/initramfs-5.4-x86_64-fallback.img
ERROR: mkdir /var/lock/dmraid
done
[manjaro-gnome /]#
[EDIT]
Whan i update grub from my system i dont get this error:
everything looks ok… and you really dont need to have installed all available kernels, i would remove the 5.4, 5.10, 6.2 …
yes this happens if you run update-grub from chroot, ignore it…
so exit chroot:
exit
reboot and see if you can boot…
i can boot (By entering my root password and running exit)
But i always get booted to emergency mode first.
so you boot, get stuck, then you enter your password, exit and you boot normally?
Exactly like that. And i really don’t know what is wrong here… I have checked everything…
[EDIT]
My mistake. When i type exit my pc does not reboot, it just starts xfce in normal mode
post logs:
journalctl -b0 -p4 --no-pager
and output from:
cat /etc/mkinitcpio.conf
Output of
[george@georgemanjaro ~]$ journalctl -b0 -p4 --no-pager
Ιουν 02 16:51:25 georgemanjaro kernel: #9 #10 #11 #12 #13 #14 #15
Ιουν 02 16:51:25 georgemanjaro kernel: pci 0000:00:00.2: can't derive routing for PCI INT A
Ιουν 02 16:51:25 georgemanjaro kernel: pci 0000:00:00.2: PCI INT A: not connected
Ιουν 02 16:51:25 georgemanjaro kernel: clocksource: timekeeping watchdog on CPU4: Marking clocksource 'tsc' as unstable because the skew is too large:
Ιουν 02 16:51:25 georgemanjaro kernel: clocksource: 'hpet' wd_nsec: 510216591 wd_now: 22a1d27 wd_last: 1baa48a mask: ffffffff
Ιουν 02 16:51:25 georgemanjaro kernel: clocksource: 'tsc' cs_nsec: 506672379 cs_now: e6b4ec9a0 cs_last: df7f62e1a mask: ffffffffffffffff
Ιουν 02 16:51:25 georgemanjaro kernel: clocksource: Clocksource 'tsc' skewed -3544212 ns (18446744073706 ms) over watchdog 'hpet' interval of 510216591 ns (510 ms)
Ιουν 02 16:51:25 georgemanjaro kernel: clocksource: 'tsc' is current clocksource.
Ιουν 02 16:51:25 georgemanjaro kernel: clocksource: Checking clocksource tsc synchronization from CPU 7 to CPUs 0,3,10-11.
Ιουν 02 16:51:25 georgemanjaro kernel: tpm tpm0: AMD fTPM version 0x3004c00000005 causes system stutter; hwrng disabled
Ιουν 02 16:51:25 georgemanjaro kernel: ata6: failed to resume link (SControl 0)
Ιουν 02 16:51:25 georgemanjaro kernel: Unstable clock detected, switching default tracing clock to "global"
If you want to keep using the local clock, then add:
"trace_clock=local"
on the kernel command line
Ιουν 02 16:51:25 georgemanjaro kernel: ATPX version 1, functions 0x00000000
Ιουν 02 16:51:25 georgemanjaro kernel: amdgpu: SRAT table not found
Ιουν 02 16:51:25 georgemanjaro kernel: memfd_create() without MFD_EXEC nor MFD_NOEXEC_SEAL, pid=1 'systemd'
Ιουν 02 16:51:25 georgemanjaro kernel: ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\GSA1.SMBI) (20221020/utaddress-204)
Ιουν 02 16:51:25 georgemanjaro kernel: vboxdrv: loading out-of-tree module taints kernel.
Ιουν 02 16:51:25 georgemanjaro kernel: VBoxNetAdp: Successfully started.
Ιουν 02 16:51:25 georgemanjaro kernel: VBoxNetFlt: Successfully started.
Ιουν 02 16:51:26 georgemanjaro systemd-journald[520]: File /var/log/journal/6c07413ab2e1447eb18005640281b59c/system.journal corrupted or uncleanly shut down, renaming and replacing.
Ιουν 02 16:51:26 georgemanjaro kernel: snd_hda_intel 0000:04:00.0: Unknown capability 0
Ιουν 02 16:51:27 georgemanjaro kernel: mei_gsc i915.mei-gscfi.768: FW not ready: resetting: dev_state = 2 pxp = 0
Ιουν 02 16:51:27 georgemanjaro kernel: mei_gsc i915.mei-gscfi.768: unexpected reset: dev_state = ENABLED fw status = 00000345 84670000 00000000 00000000 E0020002 00000000
Ιουν 02 16:51:27 georgemanjaro kernel: mei_gsc i915.mei-gsc.768: FW not ready: resetting: dev_state = 2 pxp = 2
Ιουν 02 16:51:27 georgemanjaro kernel: mei_gsc i915.mei-gsc.768: unexpected reset: dev_state = ENABLED fw status = 00000345 84670000 00000000 00000000 E0020002 00000000
Ιουν 02 16:52:54 georgemanjaro systemd[1]: dev-disk-by\x2duuid-46fc092e\x2ddf39\x2d47fc\x2db405\x2db08088a5d44b.device: Job dev-disk-by\x2duuid-46fc092e\x2ddf39\x2d47fc\x2db405\x2db08088a5d44b.device/start timed out.
Ιουν 02 16:52:54 georgemanjaro systemd[1]: Timed out waiting for device /dev/disk/by-uuid/46fc092e-df39-47fc-b405-b08088a5d44b.
Ιουν 02 16:52:54 georgemanjaro systemd[1]: Dependency failed for /dev/disk/by-uuid/46fc092e-df39-47fc-b405-b08088a5d44b.
Ιουν 02 16:52:54 georgemanjaro systemd[1]: Dependency failed for Swaps.
Ιουν 02 16:52:54 georgemanjaro systemd[1]: dev-disk-by\x2duuid-5DCE\x2d90EE.device: Job dev-disk-by\x2duuid-5DCE\x2d90EE.device/start timed out.
Ιουν 02 16:52:54 georgemanjaro systemd[1]: Timed out waiting for device /dev/disk/by-uuid/5DCE-90EE.
Ιουν 02 16:52:54 georgemanjaro systemd[1]: Dependency failed for File System Check on /dev/disk/by-uuid/5DCE-90EE.
Ιουν 02 16:52:54 georgemanjaro systemd[1]: Dependency failed for /boot/efi.
Ιουν 02 16:52:54 georgemanjaro systemd[1]: Dependency failed for Local File Systems.
Ιουν 02 16:52:54 georgemanjaro kernel: kauditd_printk_skb: 139 callbacks suppressed
Ιουν 02 19:45:06 georgemanjaro kernel: kauditd_printk_skb: 7 callbacks suppressed
Ιουν 02 19:45:07 georgemanjaro systemd[1]: vmware.service: Failed with result 'exit-code'.
Ιουν 02 19:45:07 georgemanjaro systemd[1]: Failed to start VMware host virtualization and network services for Workstation.
Ιουν 02 19:45:07 georgemanjaro squid[1614]: Starting Squid Cache version 5.8 for x86_64-pc-linux-gnu...
Ιουν 02 19:45:07 georgemanjaro squid[1614]: Service Name: squid
Ιουν 02 19:45:11 georgemanjaro kernel: irq 9: nobody cared (try booting with the "irqpoll" option)
Ιουν 02 19:45:11 georgemanjaro kernel: CPU: 1 PID: 0 Comm: swapper/1 Tainted: G OE 6.3.5-1-MANJARO #1 cfdfa49425c1fa5e73cd569c5d56ac8fde9928c4
Ιουν 02 19:45:11 georgemanjaro kernel: Hardware name: Gigabyte Technology Co., Ltd. B550 AORUS ELITE V2/B550 AORUS ELITE V2, BIOS F14 01/04/2022
Ιουν 02 19:45:11 georgemanjaro kernel: Call Trace:
Ιουν 02 19:45:11 georgemanjaro kernel: <IRQ>
Ιουν 02 19:45:11 georgemanjaro kernel: dump_stack_lvl+0x47/0x60
Ιουν 02 19:45:11 georgemanjaro kernel: __report_bad_irq+0x2b/0xc0
Ιουν 02 19:45:11 georgemanjaro kernel: note_interrupt+0x2cb/0x310
Ιουν 02 19:45:11 georgemanjaro kernel: handle_irq_event+0x75/0x80
Ιουν 02 19:45:11 georgemanjaro kernel: handle_fasteoi_irq+0x8e/0x1f0
Ιουν 02 19:45:11 georgemanjaro kernel: __common_interrupt+0x46/0xc0
Ιουν 02 19:45:11 georgemanjaro kernel: common_interrupt+0x81/0xa0
Ιουν 02 19:45:11 georgemanjaro kernel: </IRQ>
Ιουν 02 19:45:11 georgemanjaro kernel: <TASK>
Ιουν 02 19:45:11 georgemanjaro kernel: asm_common_interrupt+0x26/0x40
Ιουν 02 19:45:11 georgemanjaro kernel: RIP: 0010:menu_reflect+0xa/0x40
Ιουν 02 19:45:11 georgemanjaro kernel: Code: 00 00 00 44 89 c3 44 89 45 10 e9 6a ff ff ff 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 f3 0f 1e fa 0f 1f 44 00 00 53 <48> c7 c3 60 28 03 00 89 77 10 65 48 03 1d 5c 2c d9 56 c7 03 01 00
Ιουν 02 19:45:11 georgemanjaro kernel: RSP: 0018:ffffac3e8019fee0 EFLAGS: 00000202
Ιουν 02 19:45:11 georgemanjaro kernel: RAX: ffffffffa9286e80 RBX: ffff926b80928000 RCX: ffff926b80d42870
Ιουν 02 19:45:11 georgemanjaro kernel: RDX: 0000000000000040 RSI: 0000000000000002 RDI: ffff926b80d42800
Ιουν 02 19:45:11 georgemanjaro kernel: RBP: 0000000000000001 R08: ffffffffffcd233f R09: 00000000218358c7
Ιουν 02 19:45:11 georgemanjaro kernel: R10: 0000000000000000 R11: 0000000000000000 R12: ffffffffaa7494c0
Ιουν 02 19:45:11 georgemanjaro kernel: R13: ffff926b80d42800 R14: 0000000000000003 R15: 0000000000000000
Ιουν 02 19:45:11 georgemanjaro kernel: ? __pfx_menu_reflect+0x10/0x10
Ιουν 02 19:45:11 georgemanjaro kernel: do_idle+0x1c9/0x220
Ιουν 02 19:45:11 georgemanjaro kernel: cpu_startup_entry+0x1d/0x20
Ιουν 02 19:45:11 georgemanjaro kernel: start_secondary+0x115/0x140
Ιουν 02 19:45:11 georgemanjaro kernel: secondary_startup_64_no_verify+0xe5/0xeb
Ιουν 02 19:45:11 georgemanjaro kernel: </TASK>
Ιουν 02 19:45:11 georgemanjaro kernel: handlers:
Ιουν 02 19:45:11 georgemanjaro kernel: [<00000000d9b03619>] acpi_irq
Ιουν 02 19:45:11 georgemanjaro kernel: Disabling IRQ #9
Ιουν 02 19:45:11 georgemanjaro kernel: kauditd_printk_skb: 355 callbacks suppressed
Ιουν 02 19:45:15 georgemanjaro lightdm[2235]: gkr-pam: unable to locate daemon control file
Ιουν 02 19:45:15 georgemanjaro systemd-xdg-autostart-generator[2259]: Configuration file /home/george/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
Ιουν 02 19:45:15 georgemanjaro systemd-xdg-autostart-generator[2259]: Configuration file /home/george/.config/autostart/xfce-panel-workaround.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Ιουν 02 19:45:17 georgemanjaro tumblerd[2430]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.7.so.0: cannot open shared object file: No such file or directory
Ιουν 02 19:45:17 georgemanjaro kernel: kauditd_printk_skb: 10 callbacks suppressed
Ιουν 02 19:45:17 georgemanjaro pulseaudio[2370]: stat('/etc/pulse/default.pa.d'): No such file or directory
Ιουν 02 19:45:17 georgemanjaro pulseaudio[2370]: Sink alsa_output.usb-EDFIER_EDIFIER_W820NB_USBComposteDevice-00.analog-stereo does not exist.
Ιουν 02 19:45:17 georgemanjaro xdg-desktop-por[2611]: Theme parser error: gtk.css:5591:3-9: No property named "height"
Ιουν 02 19:45:17 georgemanjaro pipewire[2760]: mod.rt: Can't find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
Ιουν 02 19:45:17 georgemanjaro pipewire[2760]: mod.rt: found session bus but no portal
Ιουν 02 19:45:17 georgemanjaro pipewire-media-session[2761]: mod.rt: Can't find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
Ιουν 02 19:45:17 georgemanjaro pipewire-media-session[2761]: mod.rt: found session bus but no portal
Ιουν 02 19:53:40 georgemanjaro pulseaudio[2370]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Ιουν 02 20:13:56 georgemanjaro tumblerd[4059]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.7.so.0: cannot open shared object file: No such file or directory
And
[george@georgemanjaro ~]$ cat /etc/mkinitcpio.conf
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run. Advanced users may wish to specify all system modules
# in this array. For instance:
# MODULES=(piix ide_disk reiserfs)
MODULES="amdgpu"
# BINARIES
# This setting includes any additional binaries a given user may
# wish into the CPIO image. This is run last, so it may be used to
# override the actual binaries included by a given hook
# BINARIES are dependency parsed, so you may safely ignore libraries
BINARIES=()
# FILES
# This setting is similar to BINARIES above, however, files are added
# as-is and are not parsed in any way. This is useful for config files.
FILES=""
# HOOKS
# This is the most important setting in this file. The HOOKS control the
# modules and scripts added to the image, and what happens at boot time.
# Order is important, and it is recommended that you do not change the
# order in which HOOKS are added. Run 'mkinitcpio -H <hook name>' for
# help on a given hook.
# 'base' is _required_ unless you know precisely what you are doing.
# 'udev' is _required_ in order to automatically load modules
# 'filesystems' is _required_ unless you specify your fs modules in MODULES
# Examples:
## This setup specifies all modules in the MODULES setting above.
## No raid, lvm2, or encrypted root is needed.
# HOOKS=(base)
## This setup will autodetect all modules for your system and should
## work as a sane default
# HOOKS=(base udev autodetect block filesystems)
## This setup will generate a 'full' image which supports most systems.
## No autodetection is done.
# HOOKS=(base udev block filesystems)
## This setup assembles a pata mdadm array with an encrypted root FS.
## Note: See 'mkinitcpio -H mdadm' for more information on raid devices.
# HOOKS=(base udev block mdadm encrypt filesystems)
## This setup loads an lvm2 volume group on a usb device.
# HOOKS=(base udev block lvm2 filesystems)
## NOTE: If you have /usr on a separate partition, you MUST include the
# usr, fsck and shutdown hooks.
HOOKS="base udev autodetect modconf block keyboard keymap consolefont resume filesystems fsck"
# COMPRESSION
# Use this to compress the initramfs image. By default, gzip compression
# is used. Use 'cat' to create an uncompressed image.
#COMPRESSION="gzip"
#COMPRESSION="bzip2"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
#COMPRESSION="zstd"
# COMPRESSION_OPTIONS
# Additional options for the compressor
#COMPRESSION_OPTIONS=()
i wanted to check if theres something in the logs before the timed out message:
something related to intel graphics, but i dont think it has anything to do with the timed out …
it waits for the swap partition, so try to uncomment if in fstab
#UUID=46fc092e-df39-47fc-b405-b08088a5d44b swap swap defaults,noatime 0 0
save it, reboot and see…
fstab:
swap is not commented (never was)… Where did you get this from?
[EDIT]
I use the intel ARC770 for the main monitor and i have the secondary monitor running on ryzen7 5700G iGPU
i meant to add # to the swap uuid in your fstab, so that it looks like this:
maybe something got reset in your bios/uefi during the power outage?
are you dual booting with windows? if yes, is fast startup disabled?
is fast boot disabled in your bios/uefi - you may not have this option…
Did it and still the same…
Only linux
Fast boot and Secure boot disabled
so undo the fstab modification, and reinstall one kernel, for example the 5.15 if you are not running it:
sudo mhwd-kernel -r linux515
install it again:
sudo mhwd-kernel -i linux515
reboot and boot with the 5.15
Still nothing. Tried with linux515 and linux 62…
At this point i really have to thank you for the 4+ hours you have been helping me
Just out of curiosity, if you have Live USB of Manjaro with you, try powering off from the Live USB to see what happens (a clean test).
