Hi,
there’s a HP notebook that doesn’t boot anymore.
There was an update running while the battery runs empty.
Before:
The notebook hangs in grub menu, if I select the kernel to boot I got the message:
file /boot/vmlinuz-515xyz-anynumber not found
Now:
I tried to fix it with manjaro-chroot -a, did pacman -Syyu, and grub-install
manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sda1. Check your device.map.
==> Mounting (ManjaroLinux) [/dev/nvme0n1p3]
--> mount: [/mnt]
--> mount: [/mnt/boot/efi]
--> mount: [/mnt/home]
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
Installing for x86_64-efi platform.
Installation finished. No error reported.
grub-mkconfig -o /boot/grub/grub.cfg
ERROR: mkdir /var/lock/dmraid
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
efibootmgr -v
BootCurrent: 0001
Timeout: 0 seconds
BootOrder: 0002,2001,0000,2002,3002,2004
Boot0000* EFI Hard Drive (SK hynix BC501 HFM512GDJTNG-8310A) PciRoot(0x0)/Pci(0x1d,0x4)/Pci(0x0,0x0)/NVMe(0x1,AC-E4-2E-00-0A-0D-FA-6E)/HD(1,GPT,9578db9d-dee4-8243-829b-74d59bcc201a,0x800,0x96000)RC
dp: 02 01 0c 00 d0 41 03 0a 00 00 00 00 / 01 01 06 00 04 1d / 01 01 06 00 00 00 / 03 17 10 00 01 00 00 00 ac e4 2e 00 0a 0d fa 6e / 04 01 2a 00 01 00 00 00 00 08 00 00 00 00 00 00 00 60 09 00 00 00 00 00 9d db 78 95 e4 de 43 82 82 9b 74 d5 9b cc 20 1a 02 02 / 7f ff 04 00
data: 52 43
Boot0001* USB Hard Drive (UEFI) - Corsair Flash Voyager (Corsair Flash Voyager)PciRoot(0x0)/Pci(0x14,0x0)/USB(0,0)/HD(1,MBR,0x0,0x75937c,0x2000)RC
dp: 02 01 0c 00 d0 41 03 0a 00 00 00 00 / 01 01 06 00 00 14 / 03 05 06 00 00 00 / 04 01 2a 00 01 00 00 00 7c 93 75 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01 / 7f ff 04 00
data: 52 43
Boot0002* manjaro HD(1,GPT,9578db9d-dee4-8243-829b-74d59bcc201a,0x800,0x96000)/File(\EFI\manjaro\grubx64.efi)
dp: 04 01 2a 00 01 00 00 00 00 08 00 00 00 00 00 00 00 60 09 00 00 00 00 00 9d db 78 95 e4 de 43 82 82 9b 74 d5 9b cc 20 1a 02 02 / 04 04 36 00 5c 00 45 00 46 00 49 00 5c 00 6d 00 61 00 6e 00 6a 00 61 00 72 00 6f 00 5c 00 67 00 72 00 75 00 62 00 78 00 36 00 34 00 2e 00 65 00 66 00 69 00 00 00 / 7f ff 04 00
Boot2001* EFI USB Device RC
dp: 7f ff 04 00
data: 52 43
Boot2002* EFI DVD/CDROM RC
dp: 7f ff 04 00
data: 52 43
Boot3002* Internal Hard Disk or Solid State Disk RC
dp: 7f ff 04 00
data: 52 43
Now, at boot, I get no Grub menu.
