Good, almost done. Lets install 517 kernel with:
pacman -S linux517
ok done.
Post output from:
find /etc/X11/ -name "*.conf"
[manjaro /]# find /etc/X11/ -name â*.confâ
/etc/X11/xorg.conf.d/30-touchpad.conf
/etc/X11/xorg.conf.d/00-keyboard.conf
what now?
Now run these commands:
update-grub
mkinitcpio -P
exit
systemctl reboot
Now you shoul be able to boot into your normal installation
Tysm works perfectly : ). Also can u tell someone to finally fix the time tysm.
What do you mean with fix time?
I meant that they should fix the time zones they are moved by 2 hours I think they tried to fix it but made it 2 hrs instead of moving it the other way to make it 0
go to system settings/regional settings/date & time and select âset date and time automaticallyâ and in the next tab âtime zoneâ select your current area
Yea and itâs move by 2hrs
i had the same issue, but on manjaro my time was correct and in windows it was 2 hours different⌠try this guide:
