Hello. After a recent update my system has been taking significantly long to propely boot. After selecting manjaro from GRUB (I dual boot with windows), it hangs on the black screen for a significant amount of time which can last up to 5 minutes. When I login, the splash screen also takes a chunk of time to process. Here is me system information:
sudo systemd-analyze blame
[sudo] password for user:
2min 14.359s systemd-tmpfiles-clean.service
51.837s udisks2.service
50.572s systemd-journal-flush.service
49.283s snapd.service
22.801s pamac-cleancache.service
16.300s dev-sda4.device
16.272s dev-loop31.device
16.025s dev-loop32.device
15.754s dev-loop37.device
15.655s dev-loop35.device
15.631s dev-loop34.device
15.549s dev-loop36.device
15.282s dev-loop29.device
15.159s dev-loop27.device
15.158s dev-loop39.device
15.144s dev-loop21.device
15.105s dev-loop38.device
15.088s dev-loop23.device
14.566s dev-loop24.device
14.480s dev-loop28.device
13.762s dev-loop33.device
13.119s systemd-fsck@dev-disk-by\x2duuid-163E\x2dECA1.service
13.088s dev-loop1.device
13.028s dev-loop12.device
12.909s dev-loop22.device
12.697s dev-loop17.device
12.684s dev-loop30.device
12.485s dev-loop16.device
12.298s dev-loop20.device
12.018s dev-loop18.device
11.545s dev-loop15.device
10.738s dev-loop8.device
10.549s dev-loop3.device
10.511s dev-loop6.device
10.351s dev-loop0.device
10.234s dev-loop25.device
10.216s dev-loop9.device
9.872s dev-loop26.device
9.498s dev-loop5.device
9.178s dev-loop4.device
9.014s dev-loop19.device
8.580s dev-loop10.device
8.542s dev-loop13.device
8.394s dev-loop11.device
8.380s dev-loop7.device
7.792s apparmor.service
7.689s ModemManager.service
7.619s systemd-modules-load.service
7.484s systemd-random-seed.service
7.444s dev-loop14.device
6.328s cups.service
6.220s polkit.service
5.574s tlp.service
4.612s dev-loop2.device
4.333s user@1000.service
4.101s var-lib-snapd-snap-audacity-971.mount
4.100s var-lib-snapd-snap-audacity-992.mount
3.997s var-lib-snapd-snap-bare-5.mount
3.988s var-lib-snapd-snap-bomber-83.mount
3.803s var-lib-snapd-snap-chromium\x2dffmpeg-26.mount
3.792s avahi-daemon.service
3.791s bluetooth.service
3.785s systemd-logind.service
3.748s dbus.service
3.660s var-lib-snapd-snap-chromium\x2dffmpeg-28.mount
3.467s var-lib-snapd-snap-core-13250.mount
3.137s var-lib-snapd-snap-core-13308.mount
3.123s NetworkManager.service
2.987s var-lib-snapd-snap-core18-2344.mount
2.884s var-lib-snapd-snap-core18-2409.mount
2.810s var-lib-snapd-snap-core20-1494.mount
2.792s var-lib-snapd-snap-core20-1518.mount
2.757s var-lib-snapd-snap-docker-1767.mount
2.743s var-lib-snapd-snap-docker-1779.mount
2.619s systemd-tmpfiles-setup-dev.service
2.564s var-lib-snapd-snap-drive-22.mount
2.487s var-lib-snapd-snap-gnome\x2d3\x2d28\x2d1804-145.mount
2.211s systemd-udevd.service
2.202s accounts-daemon.service
2.099s boot-efi.mount
2.090s var-lib-snapd-snap-gnome\x2d3\x2d28\x2d1804-161.mount
1.962s wpa_supplicant.service
1.887s var-lib-snapd-snap-gnome\x2d3\x2d38\x2d2004-106.mount
1.809s lvm2-monitor.service
1.807s var-lib-snapd-snap-gnome\x2d3\x2d38\x2d2004-112.mount
1.594s snapd.apparmor.service
1.577s var-lib-snapd-snap-gtk2\x2dcommon\x2dthemes-13.mount
1.430s var-lib-snapd-snap-gtk\x2dcommon\x2dthemes-1534.mount
1.300s var-lib-snapd-snap-gtk\x2dcommon\x2dthemes-1535.mount
1.168s systemd-backlight@backlight:intel_backlight.service
1.069s systemd-rfkill.service
937ms upower.service
914ms var-lib-snapd-snap-julia-13.mount
817ms var-lib-snapd-snap-jupyter-6.mount
717ms var-lib-snapd-snap-kde\x2dframeworks\x2d5\x2dcore18-32.mount
715ms var-lib-snapd-snap-kde\x2dframeworks\x2d5\x2dqt\x2d5\x2d15\x2d3\x2dcore20-8.mount
683ms var-lib-snapd-snap-ktimer-65.mount
681ms var-lib-snapd-snap-ktimer-66.mount
678ms var-lib-snapd-snap-opencomic-6.mount
601ms var-lib-snapd-snap-opencomic-7.mount
598ms var-lib-snapd-snap-opera-181.mount
573ms var-lib-snapd-snap-opera-182.mount
546ms var-lib-snapd-snap-opera\x2dproxy-78.mount
538ms var-lib-snapd-snap-opera\x2dproxy-83.mount
506ms var-lib-snapd-snap-scrcpy-379.mount
477ms systemd-tmpfiles-setup.service
461ms var-lib-snapd-snap-scrcpy-386.mount
458ms var-lib-snapd-snap-spotify-58.mount
410ms var-lib-snapd-snap-spotify-60.mount
367ms systemd-journald.service
361ms var-lib-snapd-snap-pycharm\x2dcommunity-244.mount
242ms linux-module-cleanup.service
223ms dev-hugepages.mount
221ms dev-mqueue.mount
220ms sys-kernel-debug.mount
219ms sys-kernel-tracing.mount
205ms systemd-update-utmp.service
190ms systemd-udev-trigger.service
187ms modprobe@fuse.service
181ms tmp.mount
178ms kmod-static-nodes.service
176ms systemd-sysctl.service
175ms modprobe@configfs.service
174ms modprobe@drm.service
165ms systemd-timesyncd.service
152ms var-lib-snapd-snap-pycharm\x2dcommunity-248.mount
136ms systemd-binfmt.service
114ms systemd-user-sessions.service
103ms rtkit-daemon.service
45ms proc-sys-fs-binfmt_misc.mount
44ms systemd-remount-fs.service
26ms user-runtime-dir@1000.service
17ms sys-fs-fuse-connections.mount
10ms alsa-restore.service
2ms sys-kernel-config.mount
1ms snapd.socket
And
systemd-analyze
Startup finished in 4.941s (firmware) + 6.498s (loader) + 3.717s (kernel) + 2min 14.047s (userspace) = 2min 29.205s
graphical.target reached after 2min 8.447s in userspace.
And
systemd-analyze critical-chain
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
graphical.target @2min 8.447s
└─multi-user.target @2min 8.447s
└─snapd.service @1min 19.163s +49.283s
└─basic.target @1min 19.156s
└─sockets.target @1min 19.156s
└─snapd.socket @1min 19.153s +1ms
└─sysinit.target @1min 19.019s
└─systemd-update-utmp.service @1min 18.814s +205ms
└─systemd-tmpfiles-setup.service @1min 18.271s +477ms
└─systemd-journal-flush.service @27.679s +50.572s
└─systemd-journald.service @27.282s +367ms
└─systemd-journald.socket @19.406s
└─-.mount @18.361s
└─-.slice @18.375s
And finally
inxi -Fza
Kernel: 5.18.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=799acea8-83e9-4271-880a-119665f23be5 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1
Type: Laptop System: HP product: HP Pavilion Laptop 15-cs3xxx
v: Type1ProductConfigId serial: <superuser required> Chassis: type: 10
Mobo: HP model: 86E2 v: 95.32 serial: <superuser required> UEFI: Insyde
v: F.06 date: 04/08/2020
ID-1: BAT0 charge: 36.5 Wh (98.1%) condition: 37.2/37.2 Wh (100.0%)
volts: 13.0 min: 11.4 model: HP Primary type: Li-ion serial: N/A
status: charging
Info: model: Intel Core i5-1035G1 bits: 64 type: MT MCP arch: Ice Lake
built: 2019-21 process: Intel 10nm family: 6 model-id: 0x7E (126)
stepping: 5 microcode: 0xB0
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 737 high: 878 min/max: 400/3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 848 2: 664 3: 589 4: 799
5: 779 6: 658 7: 681 8: 878 bogomips: 19048
Type: spectre_v2
mitigation: Enhanced IBRS, IBPB: conditional, RSB filling
Device-1: Intel Iris Plus Graphics G1 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen11 process: Intel 10nm built: 2019-21 ports:
active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a56
class-ID: 0300
Device-2: NVIDIA GM108M [GeForce MX130] vendor: Hewlett-Packard
driver: nvidia v: 515.48.07 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Maxwell process: TSMC 28nm
built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 3
speed: 8 GT/s bus-ID: 06:00.0 chip-ID: 10de:174d class-ID: 0302
Device-3: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-3:3 chip-ID: 04f2:b627 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.2
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: Najing CEC Panda 0x003c built: 2018
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 22.1.2
direct render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0403
Sound Server-1: ALSA v: k5.18.6-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.52 running: no
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 10:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF-ID-1: docker0 state: down mac: <filter>
bus-ID: 1-10:4 chip-ID: 8087:0026 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: <filter>
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 7060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 931.51 GiB used: 223.15 GiB (24.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 7C scheme: GPT
ID-1: / raw-size: 292.97 GiB size: 287.31 GiB (98.07%)
used: 223.13 GiB (77.7%) fs: ext4 dev: /dev/sda4 maj-min: 8:4
used: 25.3 MiB (26.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 46.0 C mobo: N/A
Processes: 268 Uptime: 26m wakeups: 1 Memory: 15.42 GiB
used: 3.9 GiB (25.3%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 2240
pacman: 2186 lib: 523 flatpak: 29 snap: 25 Shell: Zsh v: 5.9 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.19
