It happens sometimes when playing steam games(dota2, tetris effect).
inxi -Fazy:
Kernel: 5.15.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=317294c6-533c-41e9-976d-a8cd2b857ea6 rw quiet pcie_aspm=off
apparmor=1 security=apparmor
resume=UUID=8ae42f6d-3b02-4d4f-891f-0eff133456bf udev.log_priority=3
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: B360 AORUS GAMING 3 WIFI v: N/A
serial: <superuser required>
Mobo: Gigabyte model: B360 AORUS GAMING 3 WIFI-CF v: x.x
serial: <superuser required> UEFI: American Megatrends v: F13
date: 06/05/2019
Info: model: Intel Core i5-9400F bits: 64 type: MCP arch: Coffee Lake
gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB L3: 9 MiB
desc: 1x9 MiB
Speed (MHz): avg: 1462 high: 3162 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 896
5: 3162 6: 2318 bogomips: 34814
disabled
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Gigabyte GV-N105TOC-4GD
driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1c82 class-ID: 0300
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: N/A
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 92 s-size: 1060x292mm (41.73x11.50")
s-diag: 1099mm (43.29")
Monitor-1: DVI-D-0 pos: right res: 1920x1080 hz: 60 dpi: 93
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
Monitor-2: HDMI-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 92
size: 530x290mm (20.87x11.42") diag: 604mm (23.79") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.60.11 renderer: NVIDIA GeForce GTX 1050
Ti/PCIe/SSE2 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
Device-2: NVIDIA GP107GL High Definition Audio vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Sound API: ALSA v: k5.15.85-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
Device-2: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 1.35 TiB used: 734.31 GiB (53.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS480G2G0A-00JH30 size: 447.13 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0400
scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD10EZEX-22MFCA0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: GPT
ID-1: / raw-size: 64 GiB size: 62.44 GiB (97.57%) used: 30.07 GiB (48.2%)
fs: ext4 dev: /dev/sda6 maj-min: 8:6
used: 292 KiB (0.1%) fs: vfat dev: /dev/sda4 maj-min: 8:4
ID-3: /home raw-size: 234.62 GiB size: 229.88 GiB (97.98%)
used: 20.74 GiB (9.0%) fs: ext4 dev: /dev/sda7 maj-min: 8:7
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda5 maj-min: 8:5
System Temperatures: cpu: 37.0 C pch: 43.0 C mobo: N/A gpu: nvidia temp: 54 C
Processes: 245 Uptime: 10m wakeups: 0 Memory: 15.56 GiB
used: 3.81 GiB (24.5%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1420
pm: pacman pkgs: 1407 libs: 373 tools: pamac pm: flatpak pkgs: 0 pm: snap
pkgs: 13 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.24
