Manjaro arm on Amlogic Tv box?
@Tiber, Thanks.
Hi @spikerguy & Manjaro Users,
I wonder any of you are experiencing system slow down and becoming less responsive as uptime progresses on the latest mesa-git (3.1 Mesa 21.2.0-devel (git-17d7b0bb8f)) on Stable Branch with Panfrost enabled on XFCE, cpu-governor=performance.
The tell tale sign is for example on boot up you run glmark2 or glmark2-es2 (first run) eg. score 446 and you run glmark2 or glmark2-es2 again the score will drop quite significantly to 348 and if run again the score will drop further. You will also notice CPU usage is higher the in the 2nd or 3rd glmark2 or glmark2-es2 run.
As uptime progresses at times the system become less responsive where you move the mouse to select from a menu it lags.
I first notice this on Armbian with Oibaf graphics drivers mesa-git built dated after 2021-05-19 (mesa-git 21.2-devel) but not sure whether it is due to mesa-git or something else. Updated the mesa-git built a few rounds mesa-git 21.2-devel to 2021-06-07 the same results slow down on XFCE session. Manjaro-XFCE with earlier mesa-git devel earlier than 2021-05-19, do notice this systme slow down or glmark2-es2 score dropping significantly after each run.
So I updated the Manjaro-XFCE to the latest Stable Update 2021-06-04 with the accompanying mesa-git and I am noticing this glmark2 or glmark2-es2 scores dropping after subsequent runs.
By the way mesa 21.1.1-1 (stable) doesn’t seems to have this issue. Not sure whether this is the right place to post this.
Edit:
After 90 minutes of up time with Panfrost enabled on mesa-git(3.1 Mesa 21.2.0-devel (git-17d7b0bb8f) current mesa-git on stable repo, the system is already not that responsive. Glmark2-es2 scroe of 439 (30 minutes idling after boot up) and after 90 minutes web surfing and re-run glmark2-es2 score dropped to 186.
Dear @JFL after my optimization the system is very stable:
I’m on XFCE from
https://github.com/manjaro-arm/vim3-images/releases/download/20210517/
with kernel linux-aml 5.12 & Mesa 21.1.1-1 and
cpupower governor set to conservative ,
run very stable.
My advice: check the SoC and DDR temperature and keep them cool. Also the connected USB-stick which sometimes overheat by thermal conduction and linux writing processes.
I have no issue with mesa 21.1.1-1 (mesa stable) but issue is with mesa-git (3.1 Mesa 21.2.0-devel (git-17d7b0bb8f) or mesa-git 21.2.0-devel built after 2021-05-19 up to date.
I do run Manjaro-XFCE with mesa-21.1.1-1 which is very stable and responsive with Panfrost enabled on a SD Card. I have another image of Manjaro-XFCE with mesa-git 21.2.0-devel which having the issue the system resposiveness drops with uptime usage and so does the glmark2 or glmark2-es2 scores.
You can switch to mesa-git and see whether you have the same issue with Panfrost enabled. Run glmark2-es2 three times and see whether the score drop signicantly or use the system for 2 hours and re-run glmark2-es2 and compared it to score you just boot up.
Previous mesa-git 21.2…0-devel build date before 2021-05-18 don’t have this issue and the glmark2-es2 generally is higher than the mesa stable build.
Device: Beelink GT King Pro (SOC: S922X-H, GPU: G52)
OS: Manjaro-Arm-XFCE, Kernel: mainline linux 5.12.8-1
mesa-git (3.1 Mesa 21.2.0-devel (git-17d7b0bb8f) from stable branch 2021-06-04
Panfrost Enabled
Just an update on the system responsiveness after 3hr 26min of uptime. The system is now not very responsive compared to the first boot up.
Below is a snap shot of glmark2-es2 scores.
1st glmark2-es2 run 30 minutes of idle from boot up score: 436
2nd run right after 1st run. score: 350
3rd run with 60 minutes web surfing (total uptime 90min). score: 186
4th run total uptime 190 minutes. score: 126
[jfl@MNJROGTKPRO ~]$ glmark2-es2
    glmark2 2021.02
    OpenGL Information
    GL_VENDOR:     Panfrost
    GL_RENDERER:   Mali G52 (Panfrost)
    GL_VERSION:    OpenGL ES 3.0 Mesa 21.2.0-devel (git-17d7b0bb8f)
[build] use-vbo=false: FPS: 477 FrameTime: 2.096 ms
[build] use-vbo=true: FPS: 509 FrameTime: 1.965 ms
[texture] texture-filter=nearest: FPS: 825 FrameTime: 1.212 ms
[texture] texture-filter=linear: FPS: 796 FrameTime: 1.256 ms
[texture] texture-filter=mipmap: FPS: 794 FrameTime: 1.259 ms
[shading] shading=gouraud: FPS: 353 FrameTime: 2.833 ms
[shading] shading=blinn-phong-inf: FPS: 353 FrameTime: 2.833 ms
[shading] shading=phong: FPS: 339 FrameTime: 2.950 ms
[shading] shading=cel: FPS: 343 FrameTime: 2.915 ms
[bump] bump-render=high-poly: FPS: 150 FrameTime: 6.667 ms
[bump] bump-render=normals: FPS: 820 FrameTime: 1.220 ms
[bump] bump-render=height: FPS: 761 FrameTime: 1.314 ms
[effect2d] kernel=0,1,0;1,-4,1;0,1,0;: FPS: 582 FrameTime: 1.718 ms
[effect2d] kernel=1,1,1,1,1;1,1,1,1,1;1,1,1,1,1;: FPS: 297 FrameTime: 3.367 ms
[pulsar] light=false:quads=5:texture=false: FPS: 672 FrameTime: 1.488 ms
[desktop] blur-radius=5:effect=blur:passes=1:separable=true:windows=4: FPS: 238 FrameTime: 4.202 ms
[desktop] effect=shadow:windows=4: FPS: 504 FrameTime: 1.984 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 228 FrameTime: 4.386 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=subdata: FPS: 225 FrameTime: 4.444 ms
[buffer] columns=200:interleave=true:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 230 FrameTime: 4.348 ms
[ideas] speed=duration: FPS: 336 FrameTime: 2.976 ms
[jellyfish] <default>: FPS: 397 FrameTime: 2.519 ms
[terrain] <default>: FPS: 34 FrameTime: 29.412 ms
[shadow] <default>: FPS: 249 FrameTime: 4.016 ms
[refract] <default>: FPS: 36 FrameTime: 27.778 ms
[conditionals] fragment-steps=0:vertex-steps=0: FPS: 544 FrameTime: 1.838 ms
[conditionals] fragment-steps=5:vertex-steps=0: FPS: 529 FrameTime: 1.890 ms
[conditionals] fragment-steps=0:vertex-steps=5: FPS: 510 FrameTime: 1.961 ms
[function] fragment-complexity=low:fragment-steps=5: FPS: 495 FrameTime: 2.020 ms
[function] fragment-complexity=medium:fragment-steps=5: FPS: 491 FrameTime: 2.037 ms
[loop] fragment-loop=false:fragment-steps=5:vertex-steps=5: FPS: 481 FrameTime: 2.079 ms
[loop] fragment-steps=5:fragment-uniform=false:vertex-steps=5: FPS: 459 FrameTime: 2.179 ms
[loop] fragment-steps=5:fragment-uniform=true:vertex-steps=5: FPS: 458 FrameTime: 2.183 ms
                                  glmark2 Score: 439 (First Run after 30 minutes idle from boot up)
    glmark2 2021.02
    OpenGL Information
    GL_VENDOR:     Panfrost
[build] use-vbo=false: FPS: 420 FrameTime: 2.381 ms
[build] use-vbo=true: FPS: 461 FrameTime: 2.169 ms
[texture] texture-filter=nearest: FPS: 541 FrameTime: 1.848 ms
[texture] texture-filter=linear: FPS: 534 FrameTime: 1.873 ms
[texture] texture-filter=mipmap: FPS: 530 FrameTime: 1.887 ms
[shading] shading=gouraud: FPS: 330 FrameTime: 3.030 ms
[shading] shading=blinn-phong-inf: FPS: 331 FrameTime: 3.021 ms
[shading] shading=phong: FPS: 319 FrameTime: 3.135 ms
[shading] shading=cel: FPS: 324 FrameTime: 3.086 ms
[bump] bump-render=high-poly: FPS: 141 FrameTime: 7.092 ms
[bump] bump-render=normals: FPS: 529 FrameTime: 1.890 ms
[bump] bump-render=height: FPS: 521 FrameTime: 1.919 ms
[effect2d] kernel=0,1,0;1,-4,1;0,1,0;: FPS: 529 FrameTime: 1.890 ms
[effect2d] kernel=1,1,1,1,1;1,1,1,1,1;1,1,1,1,1;: FPS: 289 FrameTime: 3.460 ms
[pulsar] light=false:quads=5:texture=false: FPS: 459 FrameTime: 2.179 ms
[desktop] blur-radius=5:effect=blur:passes=1:separable=true:windows=4: FPS: 230 FrameTime: 4.348 ms
[desktop] effect=shadow:windows=4: FPS: 424 FrameTime: 2.358 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 203 FrameTime: 4.926 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=subdata: FPS: 199 FrameTime: 5.025 ms
[buffer] columns=200:interleave=true:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 220 FrameTime: 4.545 ms
[ideas] speed=duration: FPS: 309 FrameTime: 3.236 ms
[jellyfish] <default>: FPS: 378 FrameTime: 2.646 ms
[terrain] <default>: FPS: 33 FrameTime: 30.303 ms
[shadow] <default>: FPS: 246 FrameTime: 4.065 ms
[conditionals] fragment-steps=0:vertex-steps=0: FPS: 398 FrameTime: 2.513 ms
[conditionals] fragment-steps=5:vertex-steps=0: FPS: 392 FrameTime: 2.551 ms
[conditionals] fragment-steps=0:vertex-steps=5: FPS: 390 FrameTime: 2.564 ms
[function] fragment-complexity=low:fragment-steps=5: FPS: 377 FrameTime: 2.653 ms
[function] fragment-complexity=medium:fragment-steps=5: FPS: 373 FrameTime: 2.681 ms
[loop] fragment-loop=false:fragment-steps=5:vertex-steps=5: FPS: 370 FrameTime: 2.703 ms
[loop] fragment-steps=5:fragment-uniform=false:vertex-steps=5: FPS: 363 FrameTime: 2.755 ms
[loop] fragment-steps=5:fragment-uniform=true:vertex-steps=5: FPS: 357 FrameTime: 2.801 ms
                                  glmark2 Score: 350 - 2nd run right after the first run
    glmark2 2021.02
    OpenGL Information
    GL_VENDOR:     Panfrost
[build] use-vbo=false: FPS: 201 FrameTime: 4.975 ms
[build] use-vbo=true: FPS: 215 FrameTime: 4.651 ms
[texture] texture-filter=nearest: FPS: 210 FrameTime: 4.762 ms
[texture] texture-filter=linear: FPS: 211 FrameTime: 4.739 ms
[texture] texture-filter=mipmap: FPS: 212 FrameTime: 4.717 ms
[shading] shading=gouraud: FPS: 211 FrameTime: 4.739 ms
[shading] shading=blinn-phong-inf: FPS: 209 FrameTime: 4.785 ms
[shading] shading=phong: FPS: 206 FrameTime: 4.854 ms
[shading] shading=cel: FPS: 210 FrameTime: 4.762 ms
[bump] bump-render=high-poly: FPS: 121 FrameTime: 8.264 ms
[bump] bump-render=normals: FPS: 209 FrameTime: 4.785 ms
[bump] bump-render=height: FPS: 214 FrameTime: 4.673 ms
[effect2d] kernel=0,1,0;1,-4,1;0,1,0;: FPS: 208 FrameTime: 4.808 ms
[effect2d] kernel=1,1,1,1,1;1,1,1,1,1;1,1,1,1,1;: FPS: 209 FrameTime: 4.785 ms
[pulsar] light=false:quads=5:texture=false: FPS: 209 FrameTime: 4.785 ms
[desktop] blur-radius=5:effect=blur:passes=1:separable=true:windows=4: FPS: 196 FrameTime: 5.102 ms
[desktop] effect=shadow:windows=4: FPS: 206 FrameTime: 4.854 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 156 FrameTime: 6.410 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=subdata: FPS: 155 FrameTime: 6.452 ms
[buffer] columns=200:interleave=true:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 161 FrameTime: 6.211 ms
[ideas] speed=duration: FPS: 187 FrameTime: 5.348 ms
[jellyfish] <default>: FPS: 192 FrameTime: 5.208 ms
[terrain] <default>: FPS: 31 FrameTime: 32.258 ms
[shadow] <default>: FPS: 174 FrameTime: 5.747 ms
[refract] <default>: FPS: 34 FrameTime: 29.412 ms
[conditionals] fragment-steps=0:vertex-steps=0: FPS: 205 FrameTime: 4.878 ms
[conditionals] fragment-steps=5:vertex-steps=0: FPS: 208 FrameTime: 4.808 ms
[conditionals] fragment-steps=0:vertex-steps=5: FPS: 210 FrameTime: 4.762 ms
[function] fragment-complexity=low:fragment-steps=5: FPS: 206 FrameTime: 4.854 ms
[function] fragment-complexity=medium:fragment-steps=5: FPS: 207 FrameTime: 4.831 ms
[loop] fragment-loop=false:fragment-steps=5:vertex-steps=5: FPS: 201 FrameTime: 4.975 ms
[loop] fragment-steps=5:fragment-uniform=false:vertex-steps=5: FPS: 192 FrameTime: 5.208 ms
[loop] fragment-steps=5:fragment-uniform=true:vertex-steps=5: FPS: 189 FrameTime: 5.291 ms
                                  glmark2 Score: 186 - 3rd run after 60 minutes of web surfing. Total uptime is ~90 minutes.
    glmark2 2021.02
    OpenGL Information
    GL_VENDOR:     Panfrost
[build] use-vbo=false: FPS: 122 FrameTime: 8.197 ms
[build] use-vbo=true: FPS: 145 FrameTime: 6.897 ms
[texture] texture-filter=nearest: FPS: 136 FrameTime: 7.353 ms
[texture] texture-filter=linear: FPS: 134 FrameTime: 7.463 ms
[texture] texture-filter=mipmap: FPS: 142 FrameTime: 7.042 ms
[shading] shading=gouraud: FPS: 131 FrameTime: 7.634 ms
[shading] shading=blinn-phong-inf: FPS: 130 FrameTime: 7.692 ms
[shading] shading=phong: FPS: 129 FrameTime: 7.752 ms
[shading] shading=cel: FPS: 127 FrameTime: 7.874 ms
[bump] bump-render=high-poly: FPS: 119 FrameTime: 8.403 ms
[bump] bump-render=normals: FPS: 144 FrameTime: 6.944 ms
[bump] bump-render=height: FPS: 140 FrameTime: 7.143 ms
[effect2d] kernel=0,1,0;1,-4,1;0,1,0;: FPS: 136 FrameTime: 7.353 ms
[effect2d] kernel=1,1,1,1,1;1,1,1,1,1;1,1,1,1,1;: FPS: 137 FrameTime: 7.299 ms
[pulsar] light=false:quads=5:texture=false: FPS: 132 FrameTime: 7.576 ms
[desktop] blur-radius=5:effect=blur:passes=1:separable=true:windows=4: FPS: 136 FrameTime: 7.353 ms
[desktop] effect=shadow:windows=4: FPS: 129 FrameTime: 7.752 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 117 FrameTime: 8.547 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=subdata: FPS: 115 FrameTime: 8.696 ms
[buffer] columns=200:interleave=true:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 117 FrameTime: 8.547 ms
[ideas] speed=duration: FPS: 137 FrameTime: 7.299 ms
[jellyfish] <default>: FPS: 135 FrameTime: 7.407 ms
[terrain] <default>: FPS: 29 FrameTime: 34.483 ms
[shadow] <default>: FPS: 137 FrameTime: 7.299 ms
[refract] <default>: FPS: 33 FrameTime: 30.303 ms
[conditionals] fragment-steps=0:vertex-steps=0: FPS: 135 FrameTime: 7.407 ms
[conditionals] fragment-steps=5:vertex-steps=0: FPS: 134 FrameTime: 7.463 ms
[conditionals] fragment-steps=0:vertex-steps=5: FPS: 137 FrameTime: 7.299 ms
[function] fragment-complexity=low:fragment-steps=5: FPS: 136 FrameTime: 7.353 ms
[function] fragment-complexity=medium:fragment-steps=5: FPS: 137 FrameTime: 7.299 ms
[loop] fragment-loop=false:fragment-steps=5:vertex-steps=5: FPS: 138 FrameTime: 7.246 ms
[loop] fragment-steps=5:fragment-uniform=false:vertex-steps=5: FPS: 137 FrameTime: 7.299 ms
[loop] fragment-steps=5:fragment-uniform=true:vertex-steps=5: FPS: 138 FrameTime: 7.246 ms
                                  glmark2 Score: 126 - 4th run total uptime 190 minutes.
Are you shure that your box don’t has a thermal problem?
I did the glmark2-es several times and my monitoring is that the cpu-temperature raise up.
I would say it is worth to cool your box with an external fan and try it again.
And second: why do you install mesa-devel-git on stable?
Not good idea to stay on mesa-git for long time as with every update its not going to be a stable release.
Better to stay on stable mesa package.
Check thermals.
try Sensor Viewer (from official repository):
Screenshot_2021-06-08_12-35-35
some hints from Amazon-customers:
My X96 Max plus arrived today. I kinda messed up ordering this, I should’ve ordered another X96 Air Q1000 but its only a Ā£32 mistake so I’ll survive.
The included Android is buggier than the one included with the X96 Air but thankfully I don’t intend to use that anyway. The X96 Max plus has an IR port (instead of a third USB port like on the X96 Air) but does that actually do anything? I can’t imagine what it could be as the IR works without having to connect an external receiver.
I have tried my dtb for the X96 Air on the X96 max plus. Gigabit ethernet and HDMI audio work but wifi and bluetooth don’t. I haven’t tried any other dtbs but I’ll be sticking with the X96 Air because it has the extra USB port and I’ve got an almost fully featured dtb for the Air now.
I am working with the ffmpeg devs trying to get the meson vpu hardware video decoding to work and I should have my USB relay automated fan sorted today.
No thermal issue. involved. You notice that the 1st and 2nd run are consecutive (even then temp is below 74C or usually below 60C). The 3rd and 4th run are 60mins and 90mins apart.
there is a working meson-sm1-x96maxplus-100M-vim.dtb from @TheMojoMan
works for me with both kernes linux-vim or linux-aml 5.12.
For gpu accelleration s.also our posts in
Yes, I have one Manjaro version on mesa stable. The other is on mesa-git which is having the issue. Current Mesa-git performance wise is in regression.
When I mentioned that mesa-git slows down the system while web surfing after 90 mins or 180 mins, the CPU temp is in the range of 50C to 65C depending on activities.
As far as i can tell it is not heat related thermal issue. For testing purpose, on the stable mesa 21.1.1-1, I have ran glmark2-es2 5 consecutive times and do not encounter any noticeable system slow down or glmark2-es2 score dropping significantly.
Surprisingly, in Ubuntu-Wayland Focal using latest mesa-git (Oibaf PPA) the slow down is {Edit: not} that noticeable but in Ubuntu-XFCE Focal it has the same issue as in Manjaro-XFCE with mesa-git.
So far no thermal issue or reliability issue yet (around 10 months). Streaming high-resolution video on Android for 3 hrs, the device does get warm but not hot. Streaming 1080p/60 on Firefox or Chromium without hardware acceleration the device CPU temp will quickly shoot up to >80C. But if limit the 1080p/30 on MPV with vo=gpu and with --hwdec=v4l2m2m-copy the CPU temp is in 60C range.
Hi Tiber
I have tried both of the dtb files in mojomans zip file. Both booted as far as the login screen but caused KDE to crash after logging in but before the desktop is displayed. This happens with both KDE wayland and X11 sessions.
The linux-aml kernel includes a meson-g12a-x96-max(not plus) dtb so I thought I may as well try that because of the similar name but that didn’t boot at all. My X96 Air dtb worked better than all three.
I have tried the mpv options mentioned in that thread but had no luck. If you want all the gory details of what I’ve tried and where I’m up to with mpv and ffmpeg, see:
https://trac.ffmpeg.org/ticket/9280
and
Did you ever try XFCE? works stable on my box, no kernel panic , no crashes, fast etc.
take this one:
https://github.com/manjaro-arm/vim3-images/releases/download/20210517/Manjaro-ARM-xfce-vim3-20210517.img.xz
For what do you need KDE and all the stuff? These little China boxes are made for small OS :wink:
and to get the best performance we need the smallest OS if possible.
On amd64 I usually use the MATE desktop but have you seen how much better the Mali GPU performs under KDE or GNOME wayland vs any X11 desktop such as XFCE? Its night and day.
Yes, KDE isn’t designed to run on these cheap ARM machines but it is doable with 4 GB RAM. I’m not a fan of GNOME although it is a bit more mature than KDE under Wayland. I’ve also tried Sway but thats like running Linux in the mid 90’s. I prefer to wait a bit longer for KDE to load and get superior GPU performance rather than save memory and get crappy graphics with X11 only XFCE or MATE.
Once you’ve tried Wayland, its hard to go back to X if you are using the Mali GPU. MATE under Wayland would be my ideal desktop but its got a way to go before it is usable with Wayland.
EDIT
Note you really have to be running manjaro unstable to get a usable Wayland-based KDE. It’s way too buggy under Manjaro stable.
I tried ubuntu with wayland / debian / armbian on my box and I’m now happy with manjaro arm XFCE. For me is cruical to get the best performance with the machine. With mesa you get hw-acceleration, s.a. the posts
Dear @danboid I’ve tried your movie with Android Movieplayer and one other player. Seems to be good with Android, but after booting before back to Manjaro the box crashed complete. :pensive:
Only after a great deal of coaxing and a toothpick the box booted again with manjaro. :grinning:
I’m not familiar with all the drivers but the S905X3 / S922x spec shows that both are with support for OpenGL ES 3.2, Vulkan 1.0 and OpenCL 2.0.
All three are available via Package manager.
https://dn.odroid.com/S905X3/ODROID-C4/Docs/S905X3_Public_Datasheet_Hardkernel.pdf
https://dn.odroid.com/S922X/ODROID-N2/Datasheet/S922X_Public_Datasheet_V0.2.pdf
with some interesting infos
Hi @Strit & @spikerguy,
Just wondering does this commit on mainline linux 5.12.9 resolved the ā€œunclean shutdownā€ on Beelink GT King Pro with mainline linux kernel thus far?
commit b4b91033a0b11fe9ade58156cd9168f89f4a8c1a
Author: Neil Armstrong <narmstrong@baylibre.com>
Date:   Fri Apr 30 10:27:44 2021 +0200
    drm/meson: fix shutdown crash when component not probed
    commit 7cfc4ea78fc103ea51ecbacd9236abb5b1c490d2 upstream.
    When main component is not probed, by example when the dw-hdmi module is
    not loaded yet or in probe defer, the following crash appears on shutdown:
    Unable to handle kernel NULL pointer dereference at virtual address 0000000000000038
    pc : meson_drv_shutdown+0x24/0x50
    lr : platform_drv_shutdown+0x20/0x30
    Call trace:
    device_shutdown+0x158/0x360
    kernel_restart_prepare+0x38/0x48
    kernel_restart+0x18/0x68
    __do_sys_reboot+0x224/0x250
    __arm64_sys_reboot+0x24/0x30
    Simply check if the priv struct has been allocated before using it.
    Fixes: fa0c16caf3d7 ("drm: meson_drv add shutdown function")
    Reported-by: Stefan Agner <stefan@agner.ch>
    Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
    Tested-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
    Reviewed-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
    Link: https://patchwork.freedesktop.org/patch/msgid/20210430082744.3638743-1-narmstrong@baylibre.com
    Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Thanks for the links Tiber!
