Known after failure: SD card in mmcblk0 is corrupt
Flasher downloads the requested image and prompts to continue. When dismissing the panel to begin writing to the target, flasher hangs leaving and unresponsive panel.
Oct 29 09:21:42 pi002.adbuco.com python3[2019]: Traceback (most recent call last):
File "/usr/local/bin/manjaro-arm-flasher", line 823, in showFlashComplete
print( self.flashProc.readAll().data().decode( "utf8" ).strip() )
RuntimeError: wrapped C/C++ object of type QProcess has been deleted
Oct 29 09:21:44 pi002.adbuco.com systemd-coredump[2606]: [🡕] Process 2019 (manjaro-arm-fla) of user 1000 dumped core.
Module linux-vdso.so.1 with build-id a68d7e932e10d1108e6e2f3c5a7b2bb32ba1f4c9
Module libnss_resolve.so.2 with build-id 01f261872ea1815a9f4906c1a6b5a6f5f0c39e15
Module libnss_myhostname.so.2 with build-id 214207d96fb434794b73b406a1b0be6b4c999935
Module libnss_mymachines.so.2 with build-id 19a49fc02c1792af04af32b34bb4bccff820baa3
Module libqsvgicon.so with build-id 6c01237f7d14ad9cea47f26d465caa8698a7d3ea
Module libresolv.so.2 with build-id 7b04c33881a5856b4772580959fb03ca224ddb02
Module libkeyutils.so.1 with build-id bb7058f5ed47bb3eea0a0787373dbe5951200b3d
Module libkrb5support.so.0 with build-id 03dd9e5cb57e38505a8ef49e32e1871c4e4f75f4
Module libcom_err.so.2 with build-id 4d3519bec62821560a76e699c333c1386fd0dfc7
Module libk5crypto.so.3 with build-id 6dc376458c81fa38c38f3b431a6ffbfa7bd908a5
Module libkrb5.so.3 with build-id ee65ba17aa37a5ff7c078c0f49b94b1073b2d272
Module libgssapi_krb5.so.2 with build-id fd3eebe76aaada751c48d7ba6ebdfb97385d5969
Module libQt6Network.so.6 with build-id ee6ac28bca148d5d77084fe59a194117e84e5dc2
Module libQt6Pdf.so.6 with build-id 1a39d277bd47d721f3f59f0d11ad1c7f7a46c137
Module libqpdf.so with build-id 3483457e18c6c0650fe757bdae539ac9c8c32425
Module libqico.so with build-id 03811b207a5d6542b4c8b4bc4cf8a63971707806
Module libQt6Svg.so.6 with build-id 1c25d9db5d01a7cf038e4cd88ce51205c04c9e16
Module libqsvg.so with build-id 757f3fbd74e852f741eb72294914b30dba5c284f
Module libqgif.so with build-id 5d7dd03ff33610cab450d70877ec7199c07217d7
Module libqjpeg.so with build-id 8c5500ed5b0619d82fa12157c52288a02fc02fcc
Module libcomposeplatforminputcontextplugin.so with build-id 6cfbe0876f1bc39b27c0c1dda5d6b337445ebb2e
Module libgvfscommon.so with build-id 8eff85b77a549cd0f1cfff13cbd0112d94790041
Module libgvfsdbus.so with build-id 7241facc8924753fec7f1ee97447c2cda3afcb75
Module libogg.so.0 with build-id cd094d37daca0f473ddb0114a4d4e12bbf586bfb
Module libvorbis.so.0 with build-id 6e61f620dc5f1521bc1159776bbaf8960e788670
Module libltdl.so.7 with build-id 35ef7f0f5e1b88ce575cb73a17fba95cba7c76fc
Module libtdb.so.1 with build-id 10dbc9fe8b79e5f116d4a1189060ad5e3e035459
Kernel: 5.15.74-2-MANJARO-ARM-RPI arch: aarch64 bits: 64 compiler: gcc
v: 12.1.0 parameters: coherent_pool=1M 8250.nr_uarts=0
snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1
video=HDMI-A-1:1920x1080M@60 video=HDMI-A-2:1920x1080M@60
smsc95xx.macaddr=DC:A6:32:80:5B:D6 vc_mem.mem_base=0x3eb00000
vc_mem.mem_size=0x3ff00000 root=PARTUUID=e56efd08-02 rw rootwait
console=ttyS0,115200 console=tty3 selinux=0 quiet splash
plymouth.ignore-serial-consoles smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0
kgdboc=ttyS0,115200 usbhid.mousepoll=8 audit=0
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro ARM base: Arch Linux
Type: ARM System: Raspberry Pi 4 Model B Rev 1.2 details: BCM2835
rev: c03112 serial: <filter>
RAM: total: 3.78 GiB used: 1.75 GiB (46.4%) gpu: 64 MiB
RAM Report: missing: Required tool dmidecode not installed. Check
--recommends
Info: model: N/A variant: cortex-a72 bits: 64 type: MCP arch: ARMv8
family: 8 model-id: 0 stepping: 3
Topology: cpus: 1x cores: 4 smt: N/A cache: L1: 320 KiB desc: d-4x32 KiB;
i-4x48 KiB L2: 1024 KiB desc: 1x1024 KiB
Speed (MHz): avg: 600 min/max: 600/1500 scaling: driver: cpufreq-dt
governor: schedutil cores: 1: 600 2: 600 3: 600 4: 600 bogomips: 432
Features: asimd cpuid crc32 evtstrm fp
Type: spectre_v1 mitigation: __user pointer sanitization
Type: spectre_v2 status: Vulnerable
Device-1: bcm2711-hdmi0 driver: vc4_hdmi v: N/A bus-ID: N/A
chip-ID: brcm:fef00700 class-ID: hdmi
Device-2: bcm2711-hdmi1 driver: vc4_hdmi v: N/A bus-ID: N/A
chip-ID: brcm:fef05700 class-ID: hdmi
Device-3: bcm2711-vc5 driver: vc4_drm v: N/A bus-ID: N/A chip-ID: brcm:gpu
class-ID: gpu
Display: x11 server: X.org v: 1.21.1.4 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting alternate: fbdev dri: vc4
gpu: vc4-drm,vc4_crtc,vc4_dpi,vc4_dsi,vc4_firmware_kms,vc4_hdmi,vc4_hvs,vc4_txp,vc4_v3d,vc4_vec
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1115 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,bottom-l
model: Acer K242HYL serial: <filter> built: 2020 res: 1920x1080 hz: 60
dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65") diag: 604mm (23.8")
ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-2 mapped: HDMI-2 pos: top-right model: Acer K242HYL
serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: bcm2711-hdmi0 driver: vc4_hdmi bus-ID: N/A chip-ID: brcm:fef00700
class-ID: hdmi
Device-2: bcm2711-hdmi1 driver: vc4_hdmi bus-ID: N/A
Device-3: bcm2835-audio driver: bcm2835_audio bus-ID: N/A
chip-ID: brcm:bcm2835_audio class-ID: bcm2835_audio
Sound API: ALSA v: k5.15.74-2-MANJARO-ARM-RPI running: yes
Sound Server-3: PipeWire v: 0.3.59 running: no
Device-1: bcm2835-mmc driver: mmc_bcm2835 v: N/A port: N/A bus-ID: N/A
chip-ID: brcm:fe300000 class-ID: mmcnr
Device-2: bcm2711-genet-v5 driver: bcmgenet v: N/A port: N/A bus-ID: N/A
chip-ID: brcm:fd580000 class-ID: ethernet
IF: eth0 state: down mac: <filter>
Device-1: pl011 driver: uart_pl011 bus-ID: N/A chip-ID: arm:fe201000
class-ID: serial
Device-2: pl011 driver: N/A bus-ID: N/A chip-ID: arm:serial0
class-ID: serial
Local Storage: total: 232.89 GiB used: 55.56 GiB (23.9%)
ID-1: /dev/sda maj-min: 8:0 type: USB vendor: Kingston model: SA2000M8250
size: 232.89 GiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 0209 scheme: MBR
ID-1: / raw-size: 232.65 GiB size: 228.92 GiB (98.40%) used: 55.5 GiB
(24.2%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: ROOT_MNJRO
uuid: 08bf4a63-4efc-4d7d-b81c-6f4e72f24c8f
ID-2: /boot raw-size: 213.6 MiB size: 213.4 MiB (99.89%) used: 54.8 MiB
(25.7%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: BOOT_MNJRO
uuid: BABE-65BB
Kernel: swappiness: 60 (default) cache-pressure: 80 (default 100)
ID-1: swap-1 type: zram size: 5.57 GiB used: 0 KiB (0.0%) priority: 100
dev: /dev/zram0
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 1-1:2 info: VIA Labs Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 2109:3431 class-ID: 0900
Hub-3: 1-1.1:3 info: VIA Labs VL820 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2820 class-ID: 0900
Device-1: 1-1.1.1:4 info: Lite-On USB Keyboard type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 70mA chip-ID: 04ca:0022 class-ID: 0301
Device-2: 1-1.1.2:5 info: Pixart Imaging Optical Mouse type: Mouse
power: 100mA chip-ID: 093a:2510 class-ID: 0301
Hub-4: 2-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-5: 2-1:2 info: VIA Labs VL820 Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 2109:0820 class-ID: 0900
Device-1: 2-1.3:3 info: JMicron / USA JMS567 SATA 6Gb/s bridge
type: Mass Storage driver: uas interfaces: 1 rev: 3.2 speed: 5 Gb/s
power: 896mA chip-ID: 152d:0562 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 43.3 C mobo: N/A
Processes: 201 Uptime: 22m Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 782 libs: 223 tools: pamac Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.22
