Manjaro ARM Beta29 with Phosh (PinePhone / PinePhonePro)
Manjaro ARM Beta29 of Phosh for PinePhone!
The Manjaro ARM project is proud to announce our twenty nineth BETA release for the PinePhone running Phosh!
Those images run the 6.1 kernel from Megi.
Features:
  • Firefox uses a dedicated configuration and plays videos on Youtube pretty well
  • Camera app with access to back and front camera, including autofocus
  • Auto-Rotate function and manual rotate
  • Welcome wizard for easy setup of the device
  • We have now a working Torch in the quick-access-menu
  • Prime phone functions working, including resume from deep-sleep and free speaking
  • Recording of audio works
  • Most applications got added to scale-to-fit
  • Haptic feedback functions are given
  • Optimized keyboard layout for terminal
  • Maps working with geolocate
  • Volume buttons working
  • Sensors fully functional
  • Easy access to Bluetooth, Wlan, Rotate and Mobile functions via quick settings
  • Default branch is arm-stable. This can be changed by editing /etc/pacman-mirrors.conf
  • usage of callaudiod for better audio experience with calls
  • This image uses a Crust enabled uboot (Pinephone only)
Changes since Beta28
  • Kernel is now at 6.1.9
  • We ship now the normal Megapixels also to the Pinephone Pro as 1.6.0 includes all base patches to allow to apply needed PPP patch-set on top.
  • Phosh-Antispam got updated to 3.0
  • Chatty is at 0.7.0rc4
  • callaudiod is at 0.1.7
  • Bluez got renewed to 5.66
  • Firefox is renewed to 109.0.1
  • phosh is at 0.24.0, phoc at 0.24.0 and phosh-mobile-settings at 0.24.0
  • pipewire got renewed to 0.3.65
  • Systemd is at 252.5
  • xorg-server got updated to 21.1.7
  • mesa got refreshed to 22.3.5
  • Several Gnome packages got renewed, including Calls 43.3
A detailed list of package changes can be found here.
Currently broken:
  • GPS may not work as it should
Known issues
  • During a Call the Mic can’t be muted on Pinephone and PinephonePro
  • UI becomes unresponsive after a while.
  • Doing a recording may result in noisy audio savings
  • Lots of apps are still missing or are not mobile friendly yet.
Download:
Device Phosh
PinePhone Beta29
PinePhone Nightly
About the device:
PinePhone:
Perhaps you’re in a line of work where security is a must, or a hard-core Linux enthusiast, or perhaps you’ve just got enough of Android and iOS and you’re ready for something else – the PinePhone may be the next Phone for you. Powered by the same Quad-Core ARM Cortex A53 64-Bit SOC used in our popular PINE A64 Single Board Computer, the PinePhone runs mainline Linux as well as anything else you’ll get it to run.
The purpose of the PinePhone isn’t only to deliver a functioning Linux phone to end-users, but also to actively create a market for such a device, as well as to support existing and well established Linux-on-Phone projects. All major Linux Phone-oriented projects, as well as other FOSS OS’, are represented on the PinePhone and developers work together on our platform to bring support this this community driven device.
Order
Pinephones Beta Edition are still on stock. Visit the Pine64 Store
How to install:
Download the image/xz file from the download location. Verify that the download completed successfully.
After that, install Etcher (sudo pacman -S etcher if on Manjaro) and burn the to an SD card (8 GB or larger).
The PinePhone should recognize the SD card as a bootable device and boot from it.
The premade users are:
User: manjaro
Password: 123456
User: root
password: root
Donate!
Please consider supporting Manjaro ARM directly via Patreon, Ko-Fi or Open Collective.
You can also donate to our upstream, which is Arch Linux ARM.
Bugtracker
If you face issues with this editon, please open a new issue on our bug-tracker
Development Changelog
We will list our progress to Beta30 here
  • Beta29 (2023-02-17) Download
    • based on stable branch
  • Dev (2023-02-24) Download
    • based on unstable branch
    • Chatty is now at 0.7.0
    • Kernel got updated to 6.1.12
    • Mesa got renewed to 22.3.6
    • Pipewire is at 0.3.66
    • Systemd was updated to 253
    • Phosh, Phoc and Squeekboard got updated to the latest git versions
With PP this is again rock solid.
With PPP you need to edit VoiceCall.conf if you wan’t working mic.
I am not sure is my solution bullet proof but I did find it working and it is the same what postmarketOS uses (where mic with calls is working out of the box)
