Manjaro ARM Beta26 of Phosh for PinePhone!
The Manjaro ARM project is proud to announce our twenty sixth BETA release for the PinePhone running Phosh!
Those images run the 5.19 kernel from Megi.
Features:
- Firefox uses a dedicated configuration and plays videos on Youtube pretty well
- Camera app with access to back and front camera, including autofocus (only PinePhone)
- Auto-Rotate function and manual rotate
- Welcome wizard for easy setup of the device
- We have now a working Torch in the quick-access-menu
- Prime phone functions working, including resume from deep-sleep and free speaking
- Recording of audio works
- Most applications got added to
scale-to-fit - Haptic feedback functions are given
- Optimized keyboard layout for terminal
- Maps working with geolocate
- Volume buttons working
- Sensors fully functional
- Easy access to Bluetooth, Wlan, Rotate and Mobile functions via quick settings
- Default branch is
arm-stable. This can be changed by editing/etc/pacman-mirrors.conf - usage of callaudiod for better audio experience with calls
- This image uses a Crust enabled uboot
Changes since Beta25
- Pipewire got updated to 0.3.56
- added some patches by purism to callaudiod
- eg25-manager 0.4.4 allows different attribute values for the community firmware
- more Gnome 42.4 updates
- Kernel is now at 5.19
- Mesa is at 22.1.6
- Phoc sees a new stable release: 0.21.0
- Phosh got updated to 0.20.0
- squeekboard got renewed to 1.19.0
- Systemd now at 251.4
- uboot got updated to 2022.07 for Pinephone while kept at 2022.04 for PinephonePro
- Firefox is now at 103.0.1
A detailed list of package changes can be found here.
Currently broken:
- GPS may not work as it should
Known issues
- Making sure you're not a bot!
- During a Call the Mic can’t be muted on Pinephone
- Cameras are not accessible to users on PinephonePro
- UI becomes unresponsive after a while.
- Doing a recording may result in noisy audio savings
- Lots of apps are still missing or are not mobile friendly yet.
Download:
About the device:
PinePhone:
Perhaps you’re in a line of work where security is a must, or a hard-core Linux enthusiast, or perhaps you’ve just got enough of Android and iOS and you’re ready for something else – the PinePhone may be the next Phone for you. Powered by the same Quad-Core ARM Cortex A53 64-Bit SOC used in our popular PINE A64 Single Board Computer, the PinePhone runs mainline Linux as well as anything else you’ll get it to run.
The purpose of the PinePhone isn’t only to deliver a functioning Linux phone to end-users, but also to actively create a market for such a device, as well as to support existing and well established Linux-on-Phone projects. All major Linux Phone-oriented projects, as well as other FOSS OS’, are represented on the PinePhone and developers work together on our platform to bring support this this community driven device.
Order
Pinephones Beta Edition are still on stock. Visit the Pine64 Store
How to install:
Download the image/xz file from the download location. Verify that the download completed successfully.
After that, install Etcher (sudo pacman -S etcher if on Manjaro) and burn the to an SD card (8 GB or larger).
The PinePhone should recognize the SD card as a bootable device and boot from it.
The premade users are:
User: manjaro
Password: 123456
User: root
password: root
Donate!
Please consider supporting Manjaro ARM directly via Patreon, Ko-Fi or Open Collective.
You can also donate to our upstream, which is Arch Linux ARM.
Bugtracker
If you face issues with this editon, please open a new issue on our bug-tracker
Development Changelog
We will list our progress to Beta27 here
- Beta26 (2022-08-18) Download
- based on stable branch
- Dev (2022-08-21) Download
- Dev (2022-08-23) Download
- based on unstable branch
- Kernel got updated to 5.19.3 which brings in the following fixes:
- fix various rt5640 codec issues: megi's PinePhone Development Log
- decouple camera ISP1 and DRM on RK3399 (fixes lack of display when rear camera is not probed)
- Dev (2022-09-01) Download
- Kernel got updated to 5.19.4 which brings in the following fixes:
- fix longstanding issue with 44.1kHz sample rate playback not working correctly after playing 48kHz audio on RK3399 (Pinephone Pro)
- Firefox got updated to 104.0
- Mesa got renewed to 22.1.7
- Phosh and Phoc got some fixes added
- this fixes the loop issue
- Dev (2022-09-02) Download
- Kernel got updated to 5.19.6
- Firefox got updated to 104.0.1
- Phosh is now at 0.21.0
- Phoc got renewed to 0.21.1
- Phosh-Mobile-Settings got added
- Megapixels gained initial PinephonePro support
- Rear camera sometimes might not initialize. You may need to remove the lines in the ini.config
- Dev (2022-09-04) Download
- fixed issue with Megapixels loading both cameras on PPP
