When I restart my Pinetab after removing/moving icons or change the wallpaper on Plasma Mobile it seems like all those changes reset to the default icon/wallpaper configuration. Is anyone else experiencing this?
EDIT: Playing with this some more I noticed that this only happens when you reboot. If you shutdown or force power off by holding the power button, the icons and wallpaper configuration does not revert to the default.
Could someone shed some light into the behavior of the Tab when in a TTY?
On the Lomiri image, after the last update I ran the GUI failed to start, just gives me a flashing cursor on screen.
I booted it up today, switched to TTY from the flashing cursor on screen, and told pamac to update. It got to finalizing the update for linux-5.11 and the screen just went black. No buttons, keys, or touch will turn the screen back on. Iāll have to hard boot. However, given where the screen went dark in the update process, I donāt want to do a hard boot if thereās a chance that the Tab is still on/working, and the screen just wonāt show image.
Would this behavior be to turn off the device entirely or just the screen?
EDIT: I waited about 30m till hard booting it again, and it seems the update didnt fix the issue. should updates, or a specific branch be avoid in general for the lomiri img?
Installation and 700MB update now worked flawlessly
System boots and is usable. But I find no way to config the keyboard from Pine to my german keyboard settings. The virtual keyboard could be configured to use germen keymap. But for the Pine keyboard I cannot find any possibility to do it.
