What does /etc/vconsole.conf contain?
cat /etc/vconsole.conf
KEYMAP=de-latin1-nodeadkeys
Now all seems to be ok
The āarm-testingā is the preselected repo. Is this OK or can also arm-unstable be used?
That is up to you. It only influences how often updates come in to your device.
Just flashed the beta 2 plasma build and after updating pintab no longer starts. I push the power button and nothing happens. If I remove the SD card it will start as it should, but putting the SD card back in and it wonāt start. I donāt believe its the SD card because if I flash a different distro on it like the phosh (Releases Ā· dreemurrs-embedded/Pine64-Arch Ā· GitHub) from arch that boots, so Iām wondering if there is something misconfigured with this build.
