We are happy to present our ninth Beta Release of the Manjaro Plasma-Mobile edition for the PinePhone and PinePhone Pro. This marks the first release with the ModemManager stack!
This is also the first Beta with support for the PinePhone Pro!
This image includes
- Kernel 5.15.7 optimized for the Pinephone
- Frameworks 5.88
- Plasma 5.23.4
- Plasma-Mobile apps, which are now bundled as Plamo Gear 21.12
- Maui Apps 2.1 and
- Camera app Megapixels 1.4.2 with great improvements in responsiveness,
- Pipewire 0.3.40
- Appimagelauncher 2.2.0 and
- our Pico-Wizard for easy initial setup at first launch
Over the last months Plasma-Mobile has made a lot of remarkable progress in regards of graphical appearance with smooth transitions and auto-rotate. Apps are now launching faster, too.
The drop-down menu provides Settings, Flashlight, a Screenshot function and more.
With Plamo Gear and the Maui Apps applications for all typical everyday needs are pre-installed.
Known issues:
- Text prediction is currently only available for English.
- Many translations are still missing.
- Megapixels and camera does not work yet on Pinephone Pro.
- Charging does not work on Pinephone Pro yet.
- Audio quality on the Pinephone Pro is not good yet.
- Some small graphical regressions made their way into Plasma 5.23.
Download:
| Device | PlaMo |
| PinePhone (Pro) | Beta 9 |
| PinePhone (Pro) | Development |
About the device:
PinePhone:
Perhaps you’re in a line of work where security is a must, or a hard-core Linux enthusiast, or perhaps you’ve just got enough of Android and iOS and you’re ready for something else – the PinePhone may be the next Phone for you. Powered by the same Quad-Core ARM Cortex A53 64-Bit SOC used in our popular PINE A64 Single Board Computer, the PinePhone runs mainline Linux as well as anything else you’ll get it to run.
The purpose of the PinePhone isn’t only to deliver a functioning Linux phone to end-users, but also to actively create a market for such a device, as well as to support existing and well established Linux-on-Phone projects. All major Linux Phone-oriented projects, as well as other FOSS OS’, are represented on the PinePhone and developers work together on our platform to bring support this this community driven device.
PinePhone Pro:
The Pinephone Pro is all you love about the PinePhone, except with better specifications. It has a 6-Core RK3399S SoC and 4 GB RAM, which is a huge upgrade compared to the regular Pinephones Allwinner A64 and 2/3 GB of RAM.
More information can be found on the Pine64 PinePhone Pro page.
Order
Pinephones Beta Edition are still on stock. Visit the Pine64 Store
Pinephone Pro Explorer Edition will be available soon at the above link.
How to install:
Download the image/xz file from the download location. Verify that the download completed successfully.
After that, install Etcher (sudo pacman -S etcher if on Manjaro) and burn the to an SD card (8 GB or larger).
The PinePhone (Pro) should recognize the SD card as a bootable device and boot from it.
Donate!
Please consider supporting Manjaro ARM directly via Patreon, Ko-Fi or Open Collective.
You can also donate to our upstream, which is Arch Linux ARM.
Bugtracker
If you face issues with this editon, please open a new issue on our bug-tracker
which I presume means it failed. Like I mentioned calls work smoothly. Mobile internet also works, it selected a apn automatically and it just worked. This is a freshly installed beta 9 version.
