Congratulations on the release! Thanks for all your hard work on this.
I saw some oddities in two spots when I did the update.
The Keyring update gave a lot more output than it usually does, including a mass of warnings that I don’t know enough to tell if I need to worry about.
This is up to the edition maintainers. Not all editions ship with avahi.
This seems like something that should be changed from the nano package.
Shipping a /etc/nanorc file is also up to the edition maintainers otherwise.
Not sure what you mean here?
The first run Setup works fine. And no, we won’t enable autologin options in our CLI setup tool. (but the new Calamares based one, seems to be able to do it)
Hi, I have a Magicsee N5 (s905x) too but I cannot Install Manjaro. Can you please tell me how did you install Manjaro for this TV Box. Thanks in advance!
Edit /BOOT_MNJRO/extlinux/extlinux.conf (on sdcard)
Change DTB file to: meson-gxl-s905x-p212.dtb FDT /dtbs/amlogic/meson-gxl-s905x-p212.dtb
/BOOT_MNJRO/
rename u-boot.ext to u-boot.ext.old (or delete)
rename u-boot-s905x-s912 to u-boot.ext
Insert sdcard to tvbox
hold down the button in the AV port by inserting a paper clip, a pin or something similar and keep it pressed while powering the device on. Keep the button pressed until you see the boot screen of your box. After a few seconds it should reboot off your SD card . You are only required to do this once.
