@Darksky Image works like a charm, thanks!
@Strit my mistake, thanks for detailed information, I will test this approach as well.
I have the same exact issue. I even used the uboot they tell us to flash when running the update.
installing and flashing bsp uboot package (uboot-pinebookpro-bsp) fixed the issue for me. If you do check /boot/extlinux/extlinux.conf file before reboot, it seems this package tries to change the root label, it should look like this: root=LABEL=ROOT_MNJRO
Hi, flashed the Pinebook XFCE variant on a 64GB SD. Verified SD card write. When booting, once uboot load the kernel, only thing I get is a black screen. Any idea how to troubleshoot ?
Update1: Well, thatās two manjaro releases (with 20.06) that failed to boot. My SD card is sus. I need another SD.
Update2: Switched to another SD, I canāt boot any of 20.06, 20.08 and 20.10 on my Pinebook 1080p. After uboot, the kernel only displays a blank screen. Any help please ?
Hi. Iām in trouble with the latest stable update. I am running from Rockpi4b with XFCE 20.10 release. In a new installation. When rebooting after the first update, it hangs on the startup logo but never loads the desktop. I already tried from scratch several times
y extlinux.conf file look like:
LABEL Manjaro ARM
KERNEL /Image
FDT /dtbs/rockchip/rk3399-rock-pi-4b.dtb
APPEND initrd=/initramfs-linux.img console=tty1 console=ttyS2,1500000 root=UUID=ae463f2f-49b0-4f03-8347-a07e64cb9b25 rw rootwait bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash
If the Manjaro logo is there, it means the kernel is running.
Check what happened to LightDM by doing this:
- Go to other TTY: CTRL+ALT+F3
- Run
systemctl status lightdm - Post the output here.
Hello, thanks for answering. The output of systemctl status lightdm is: unit lightdm.service could not be found.
Thatās weird. Re-install lightdm.
sudo pacman -S lightdm lightdm-gtk-greeter lightdm-gtk-greeter-settings
But before that, post the contents of your /var/log/pacman.log. I wanna see if lightdm really gets uninstalled for some reason.
[2020-11-11T15:53:22-0300] [PACMAN] Running 'pacman -Rsn --noconfirm manjaro-arm-oem-install'
[2020-11-11T15:53:23-0300] [ALPM] transaction started
[2020-11-11T15:53:23-0300] [ALPM] removed manjaro-arm-oem-install (20200629-1)
[2020-11-11T15:53:23-0300] [ALPM] transaction completed
[2020-11-11T15:53:23-0300] [ALPM] running '30-systemd-update.hook'...
[2020-11-11T15:57:48-0300] [PACMAN] Running 'pacman -Syyu'
[2020-11-11T15:57:48-0300] [PACMAN] synchronizing package lists
[2020-11-11T15:58:31-0300] [ALPM] transaction started
[2020-11-11T15:58:31-0300] [ALPM] upgraded manjaro-keyring (20200603-1 -> 20201029-1)
[2020-11-11T15:58:31-0300] [ALPM-SCRIPTLET] ==> AƱadiendo las claves de manjaro.gpg...
[2020-11-11T15:58:33-0300] [ALPM-SCRIPTLET] ==> Firmando localmente las claves de confianza en el depósito...
[2020-11-11T15:58:33-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave B4663188A692DB1E45A98EE95BD96CC4247B52CC...
[2020-11-11T15:58:33-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 76C6E477042BFE985CC220BD9C08A255442FAFF0...
[2020-11-11T15:58:33-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 7C89F4D439B2BFACF425107B62443D89B35859F8...
[2020-11-11T15:58:33-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 1E7908935AAB9A00D6B47503363DFFFD59152F77...
[2020-11-11T15:58:33-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 04BB537F5BC2D399BFA72F8F17C752B61B2F2E90...
[2020-11-11T15:58:33-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 5A97ED6B72418199F0C22B23137C934B5DCB998E...
[2020-11-11T15:58:33-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 75C1B95A4D9514A57EB2DAE71817DC63CD3B5DF5...
[2020-11-11T15:58:33-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 39F0EC1AE50B37E5F3196F09DAD3B211663CA268...
[2020-11-11T15:58:33-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 2D14560CDCE6A75BB186DB758238651DDF5E0594...
[2020-11-11T15:58:33-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 7A443CEE69B6B3777740E258084A7FC0035B1D49...
[2020-11-11T15:58:33-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave F66AD0FF0E57C561615A0901CEE477135C5872B0...
[2020-11-11T15:58:33-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 35B4FF23EA9477582C2A0AF12B80869C5C0102A6...
[2020-11-11T15:58:33-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave E4CDFE50A2DA85D58C8A8C70CAA6A59611C7F07E...
[2020-11-11T15:58:33-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 74C2F2CC05A0AB7D859839938934292D604F8BA2...
[2020-11-11T15:58:33-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 3B794DE6D4320FCE594F4171279E7CF5D8D56EC8...
[2020-11-11T15:58:34-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 77DC01C9971AC3C39A0626F72C089F09AC97B894...
[2020-11-11T15:58:34-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 16DC688DF3EECC72323954237EC47C82A42D53A2...
[2020-11-11T15:58:34-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 2C688B52E3FC0144B7484BABE3B3F44AC45EE0AA...
[2020-11-11T15:58:34-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 22C903DE964E6FE321656E318DB9F8C18DF53602...
[2020-11-11T15:58:34-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 688E8F82879D0E25CE541426150C200743ED46D8...
[2020-11-11T15:58:34-0300] [ALPM-SCRIPTLET] ==> Importando los valores de los propietarios de confianza...
[2020-11-11T15:58:34-0300] [ALPM-SCRIPTLET] gpg: changing ownertrust from 1 to 4
[2020-11-11T15:58:34-0300] [ALPM-SCRIPTLET] gpg: setting ownertrust to 4
[2020-11-11T15:58:34-0300] [ALPM-SCRIPTLET] ==> Desactivando las claves revocadas en el depósito...
[2020-11-11T15:58:34-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 540DE7083B89314CF70EA6F0C1B1AD0DA80EBF3E...
[2020-11-11T15:58:35-0300] [ALPM-SCRIPTLET] -> Desactivando la clave FAA6840E8C3FC7F89BEE0DC8AC7AB10BCB6CDD17...
[2020-11-11T15:58:35-0300] [ALPM-SCRIPTLET] ==> Actualizando la base de datos de claves de confianza...
[2020-11-11T15:58:35-0300] [ALPM-SCRIPTLET] gpg: key 1EB2638FF56C0C53: no user ID for key signature packet of class 10
[2020-11-11T15:58:35-0300] [ALPM-SCRIPTLET] gpg: key 786C63F330D7CB92: no user ID for key signature packet of class 10
[2020-11-11T15:58:35-0300] [ALPM-SCRIPTLET] gpg: marginals needed: 3 completes needed: 1 trust model: pgp
[2020-11-11T15:58:35-0300] [ALPM-SCRIPTLET] gpg: nivel: 0 validez: 1 firmada: 30 confianza: 0-, 0q, 0n, 0m, 0f, 1u
[2020-11-11T15:58:35-0300] [ALPM-SCRIPTLET] gpg: nivel: 1 validez: 30 firmada: 81 confianza: 0-, 0q, 0n, 27m, 0f, 0u
[2020-11-11T15:58:35-0300] [ALPM-SCRIPTLET] gpg: nivel: 2 validez: 78 firmada: 25 confianza: 78-, 0q, 0n, 0m, 0f, 0u
[2020-11-11T15:58:35-0300] [ALPM-SCRIPTLET] gpg: siguiente comprobación de base de datos de confianza el: 2021-01-01
[2020-11-11T15:58:35-0300] [ALPM] upgraded archlinux-keyring (20200820-1 -> 20201028-1)
[2020-11-11T15:58:36-0300] [ALPM-SCRIPTLET] ==> AƱadiendo las claves de archlinux.gpg...
[2020-11-11T15:58:41-0300] [ALPM-SCRIPTLET] ==> Firmando localmente las claves de confianza en el depósito...
[2020-11-11T15:58:41-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave D8AFDDA07A5B6EDFA7D8CCDAD6D055F927843F1C...
[2020-11-11T15:58:41-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave DDB867B92AA789C165EEFA799B729B06A680C281...
[2020-11-11T15:58:41-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 91FFE0700E80619CEB73235CA88E23E377514E00...
[2020-11-11T15:58:41-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave 0E8B644079F599DFC1DDC3973348882F6AC6A4C2...
[2020-11-11T15:58:41-0300] [ALPM-SCRIPTLET] -> Firmando localmente la clave AB19265E5D7D20687D303246BA1DFB64FFF979E7...
[2020-11-11T15:58:41-0300] [ALPM-SCRIPTLET] ==> Importando los valores de los propietarios de confianza...
[2020-11-11T15:58:41-0300] [ALPM-SCRIPTLET] ==> Desactivando las claves revocadas en el depósito...
[2020-11-11T15:58:41-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 8F76BEEA0289F9E1D3E229C05F946DED983D4366...
[2020-11-11T15:58:41-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 63F395DE2D6398BBE458F281F2DBB4931985A992...
[2020-11-11T15:58:42-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 50F33E2E5B0C3D900424ABE89BDCF497A4BBCC7F...
[2020-11-11T15:58:42-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 27FFC4769E19F096D41D9265A04F9397CDFD6BB0...
[2020-11-11T15:58:42-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 39F880E50E49A4D11341E8F939E4F17F295AFBF4...
[2020-11-11T15:58:42-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 8840BD07FC24CB7CE394A07CCF7037A4F27FB7DA...
[2020-11-11T15:58:42-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 5559BC1A32B8F76B3FCCD9555FA5E5544F010D48...
[2020-11-11T15:58:42-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 0B20CA1931F5DA3A70D0F8D2EA6836E1AB441196...
[2020-11-11T15:58:42-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 07DFD3A0BC213FA12EDC217559B3122E2FA915EC...
[2020-11-11T15:58:42-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 4FCF887689C41B09506BE8D5F3E1D5C5D30DB0AD...
[2020-11-11T15:58:42-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 5A2257D19FF7E1E0E415968CE62F853100F0D0F0...
[2020-11-11T15:58:42-0300] [ALPM-SCRIPTLET] -> Desactivando la clave D921CABED130A5690EF1896E81AF739EC0711BF1...
[2020-11-11T15:58:42-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 7FA647CD89891DEDC060287BB9113D1ED21E1A55...
[2020-11-11T15:58:42-0300] [ALPM-SCRIPTLET] -> Desactivando la clave BC1FBE4D2826A0B51E47ED62E2539214C6C11350...
[2020-11-11T15:58:42-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 4A8B17E20B88ACA61860009B5CED81B7C2E5C0D2...
[2020-11-11T15:58:42-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 5696C003B0854206450C8E5BE613C09CB4440678...
[2020-11-11T15:58:42-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 684148BB25B49E986A4944C55184252D824B18E8...
[2020-11-11T15:58:42-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 8CF934E339CAD8ABF342E822E711306E3C4F88BC...
[2020-11-11T15:58:42-0300] [ALPM-SCRIPTLET] -> Desactivando la clave F5A361A3A13554B85E57DDDAAF7EF7873CFD4BB6...
[2020-11-11T15:58:42-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 5E7585ADFF106BFFBBA319DC654B877A0864983E...
[2020-11-11T15:58:42-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 65EEFE022108E2B708CBFCF7F9E712E59AF5F22A...
[2020-11-11T15:58:42-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 40440DC037C05620984379A6761FAD69BA06C6A9...
[2020-11-11T15:58:43-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 34C5D94FE7E7913E86DC427E7FB1A3800C84C0A5...
[2020-11-11T15:58:43-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 1A60DC44245D06FEF90623D6EEEEE2EEEE2EEEEE...
[2020-11-11T15:58:43-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 81D7F8241DB38BC759C80FCE3A726C6170E80477...
[2020-11-11T15:58:43-0300] [ALPM-SCRIPTLET] -> Desactivando la clave E7210A59715F6940CF9A4E36A001876699AD6E84...
[2020-11-11T15:58:43-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 5357F3B111688D88C1D88119FCF2CB179205AC90...
[2020-11-11T15:58:43-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 4D913AECD81726D9A6C74F0ADA6426DD215B37AD...
[2020-11-11T15:58:43-0300] [ALPM-SCRIPTLET] -> Desactivando la clave FB871F0131FEA4FB5A9192B4C8880A6406361833...
[2020-11-11T15:58:43-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 66BD74A036D522F51DD70A3C7F2A16726521E06D...
[2020-11-11T15:58:43-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 487EACC08557AD082088DABA1EB2638FF56C0C53...
[2020-11-11T15:58:43-0300] [ALPM-SCRIPTLET] -> Desactivando la clave B1F2C889CB2CCB2ADA36D963097D629E437520BD...
[2020-11-11T15:58:44-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 9515D8A8EAB88E49BB65EDBCE6B456CAF15447D5...
[2020-11-11T15:58:44-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 76B4192E902C0A52642C63C273B8ED52F1D357C1...
[2020-11-11T15:58:44-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 40776A5221EF5AD468A4906D42A1DB15EC133BAD...
[2020-11-11T15:58:44-0300] [ALPM-SCRIPTLET] -> Desactivando la clave D4DE5ABDE2A7287644EAC7E36D1A9E70E19DAA50...
[2020-11-11T15:58:44-0300] [ALPM-SCRIPTLET] -> Desactivando la clave 44D4A033AC140143927397D47EFD567D4C7EA887...
[2020-11-11T15:58:44-0300] [ALPM-SCRIPTLET] ==> Actualizando la base de datos de claves de confianza...
[2020-11-11T15:58:44-0300] [ALPM-SCRIPTLET] gpg: siguiente comprobación de base de datos de confianza el: 2021-01-01
[2020-11-11T15:58:45-0300] [ALPM] transaction completed
[2020-11-11T15:58:45-0300] [ALPM] running '30-systemd-update.hook'...
[2020-11-11T15:58:45-0300] [PACMAN] starting full system upgrade
[2020-11-11T16:08:29-0300] [ALPM] transaction started
[2020-11-11T16:08:29-0300] [ALPM] removed user-manager (5.19.5-1)
[2020-11-11T16:08:29-0300] [ALPM] upgraded alsa-topology-conf (1.2.3-1 -> 1.2.4-2)
[2020-11-11T16:08:29-0300] [ALPM] upgraded alsa-ucm-conf (1.2.3-2 -> 1.2.4-2)
[2020-11-11T16:08:29-0300] [ALPM] upgraded tzdata (2020b-2 -> 2020d-1)
[2020-11-11T16:08:30-0300] [ALPM] upgraded iana-etc (20200905-1 -> 20201012-1)
[2020-11-11T16:08:30-0300] [ALPM] upgraded alsa-lib (1.2.3.2-1 -> 1.2.4-3)
[2020-11-11T16:08:30-0300] [ALPM] upgraded alsa-utils (1.2.3-2 -> 1.2.4-2)
[2020-11-11T16:08:30-0300] [ALPM] upgraded libgcrypt (1.8.6-1 -> 1.8.7-1)
[2020-11-11T16:08:30-0300] [ALPM] upgraded libcap (2.43-1 -> 2.44-1)
[2020-11-11T16:08:30-0300] [ALPM] upgraded libzip (1.6.1-2 -> 1.7.3-1)
[2020-11-11T16:08:30-0300] [ALPM] upgraded vulkan-icd-loader (1.2.153-2 -> 1.2.158-1)
[2020-11-11T16:08:30-0300] [ALPM] upgraded ca-certificates-mozilla (3.57-1 -> 3.58-2)
[2020-11-11T16:08:30-0300] [ALPM] upgraded libldap (2.4.53-1 -> 2.4.54-1)
[2020-11-11T16:08:30-0300] [ALPM] upgraded curl (7.72.0-2 -> 7.73.0-1)
[2020-11-11T16:08:31-0300] [ALPM] upgraded libxml2 (2.9.10-2 -> 2.9.10-3)
[2020-11-11T16:08:31-0300] [ALPM] upgraded expat (2.2.9-3 -> 2.2.10-2)
[2020-11-11T16:08:33-0300] [ALPM] upgraded mesa (20.2.0-2 -> 20.2.1-1)
[2020-11-11T16:08:33-0300] [ALPM] upgraded libjpeg-turbo (2.0.5-2 -> 2.0.5-3)
[2020-11-11T16:08:33-0300] [ALPM] upgraded libevdev (1.9.1-1 -> 1.10.0-1)
[2020-11-11T16:08:33-0300] [ALPM] upgraded glib2 (2.66.1-2 -> 2.66.2-1)
[2020-11-11T16:08:33-0300] [ALPM] upgraded libcap-ng (0.7.11-2 -> 0.8-1)
[2020-11-11T16:08:33-0300] [ALPM] upgraded libpcap (1.9.1-2 -> 1.9.1-4)
[2020-11-11T16:08:33-0300] [ALPM] upgraded iptables (1:1.8.5-2 -> 1:1.8.6-1)
[2020-11-11T16:08:33-0300] [ALPM] upgraded libwacom (1.5-1 -> 1.6-1)
[2020-11-11T16:08:34-0300] [ALPM] upgraded libinput (1.16.2-1 -> 1.16.3-1)
[2020-11-11T16:08:34-0300] [ALPM] upgraded libusb (1.0.23-2 -> 1.0.23-3)
[2020-11-11T16:08:34-0300] [ALPM] upgraded freetype2 (2.10.2-1 -> 2.10.4-1)
[2020-11-11T16:08:36-0300] [ALPM] upgraded js78 (78.3.1-1 -> 78.4.0-1)
[2020-11-11T16:08:36-0300] [ALPM] upgraded gstreamer (1.18.0-1 -> 1.18.1-1)
[2020-11-11T16:08:37-0300] [ALPM] upgraded gst-plugins-base-libs (1.18.0-1 -> 1.18.1-1)
[2020-11-11T16:08:37-0300] [ALPM] upgraded gst-plugins-base (1.18.0-1 -> 1.18.1-1)
[2020-11-11T16:08:37-0300] [ALPM] upgraded openal (1.20.1-2 -> 1.21.0-1)
[2020-11-11T16:08:37-0300] [ALPM] upgraded knotifications (5.75.0-1 -> 5.75.0-2)
[2020-11-11T16:08:37-0300] [ALPM] upgraded libsecret (0.20.3-1 -> 0.20.4-1)
[2020-11-11T16:08:37-0300] [ALPM] upgraded nss (3.57-1 -> 3.58-2)
[2020-11-11T16:08:39-0300] [ALPM] upgraded kio (5.75.0-1 -> 5.75.0-2)
[2020-11-11T16:08:39-0300] [ALPM] upgraded ark (20.08.2-1 -> 20.08.3-1)
[2020-11-11T16:08:39-0300] [ALPM] upgraded lmdb (0.9.26-1 -> 0.9.27-1)
[2020-11-11T16:08:39-0300] [ALPM] upgraded libass (0.14.0-2 -> 0.15.0-2)
[2020-11-11T16:08:39-0300] [ALPM] upgraded libbluray (1.2.0-3 -> 1.2.1-1)
[2020-11-11T16:08:39-0300] [ALPM] upgraded libva (2.9.0-0.2 -> 2.9.1-0.1)
[2020-11-11T16:08:39-0300] [ALPM] upgraded hidapi (0.9.0-2 -> 0.10.0-2)
[2020-11-11T16:08:39-0300] [ALPM] upgraded sdl2 (2.0.12-2 -> 2.0.12-3)
[2020-11-11T16:08:39-0300] [ALPM] upgraded baloo-widgets (20.08.2-1 -> 20.08.3-1)
[2020-11-11T16:08:40-0300] [ALPM] upgraded bluedevil (1:5.19.5-1 -> 1:5.20.2-1)
[2020-11-11T16:08:40-0300] [ALPM] upgraded kdecoration (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:08:40-0300] [ALPM] upgraded breeze (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:08:41-0300] [ALPM] upgraded breeze-gtk (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:08:41-0300] [ALPM] upgraded colord (1.4.4+9+g1ce26da-2 -> 1.4.5-1)
[2020-11-11T16:08:41-0300] [ALPM] upgraded dhcpcd (9.2.0-1 -> 9.3.2-1)
[2020-11-11T16:08:41-0300] [ALPM] upgraded dnssec-anchors (20190629-2 -> 20190629-3)
[2020-11-11T16:08:42-0300] [ALPM] upgraded smbclient (4.13.0-1 -> 4.13.2-1)
[2020-11-11T16:08:42-0300] [ALPM] upgraded kio-extras (20.08.2-1 -> 20.08.3-1)
[2020-11-11T16:08:43-0300] [ALPM] upgraded dolphin (20.08.2-1 -> 20.08.3-1)
[2020-11-11T16:08:43-0300] [ALPM] upgraded dolphin-plugins (20.08.2-1 -> 20.08.3-1)
[2020-11-11T16:08:44-0300] [ALPM] installed guile (2.2.6-2)
[2020-11-11T16:08:44-0300] [ALPM] upgraded gdb-common (9.2-2 -> 10.1-2)
[2020-11-11T16:08:45-0300] [ALPM] upgraded gdb (9.2-2 -> 10.1-2)
[2020-11-11T16:08:45-0300] [ALPM] upgraded drkonqi (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:08:52-0300] [ALPM] upgraded firefox (81.0.1-1 -> 82.0.2-1)
[2020-11-11T16:08:52-0300] [ALPM] upgraded firefox-ublock-origin (1.30.2-1 -> 1.30.6-1)
[2020-11-11T16:08:52-0300] [ALPM] upgraded grep (3.4-1 -> 3.5-1)
[2020-11-11T16:08:53-0300] [ALPM] upgraded git (2.28.0-1 -> 2.29.2-1)
[2020-11-11T16:08:53-0300] [ALPM] upgraded libkipi (20.08.2-1 -> 20.08.3-1)
[2020-11-11T16:08:53-0300] [ALPM] upgraded libraw (0.20.0-1 -> 0.20.2-1)
[2020-11-11T16:08:53-0300] [ALPM] upgraded libkdcraw (20.08.2-1 -> 20.08.3-1)
[2020-11-11T16:08:53-0300] [ALPM] upgraded signon-kwallet-extension (20.08.2-1 -> 20.08.3-1)
[2020-11-11T16:08:53-0300] [ALPM] upgraded kaccounts-integration (20.08.2-1 -> 20.08.3-1)
[2020-11-11T16:08:53-0300] [ALPM] upgraded gwenview (20.08.2-1 -> 20.08.3-1)
[2020-11-11T16:08:53-0300] [ALPM] upgraded inxi (3.1.05+2-1 -> 3.1.08+1-1)
[2020-11-11T16:08:54-0300] [ALPM] upgraded iproute2 (5.8.0-1 -> 5.9.0-1)
[2020-11-11T16:08:54-0300] [ALPM] upgraded kactivitymanagerd (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:08:54-0300] [ALPM] upgraded libgit2 (1:1.0.1-1 -> 1:1.1.0-1)
[2020-11-11T16:08:54-0300] [ALPM] upgraded ktexteditor (5.75.0-1 -> 5.75.0-2)
[2020-11-11T16:08:56-0300] [ALPM] upgraded kate (20.08.2-1 -> 20.08.3-1)
[2020-11-11T16:08:56-0300] [ALPM] upgraded kcalc (20.08.2-1 -> 20.08.3-1)
[2020-11-11T16:08:56-0300] [ALPM] upgraded kde-cli-tools (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:08:56-0300] [ALPM] upgraded kde-gtk-config (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:08:57-0300] [ALPM] upgraded kinfocenter (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:08:57-0300] [ALPM] upgraded kmenuedit (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:08:57-0300] [ALPM] upgraded knetattach (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:08:57-0300] [ALPM] upgraded konsole (20.08.2-1 -> 20.08.3-1)
[2020-11-11T16:08:57-0300] [ALPM] upgraded libkscreen (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:08:57-0300] [ALPM] upgraded kscreen (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:08:57-0300] [ALPM] upgraded kscreenlocker (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:08:58-0300] [ALPM] upgraded libksysguard (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:08:58-0300] [ALPM] upgraded ksysguard (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:08:58-0300] [ALPM] upgraded kwallet-pam (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:08:58-0300] [ALPM] upgraded kwayland-integration (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:08:58-0300] [ALPM] upgraded kwayland-server (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:08:58-0300] [ALPM] installed pipewire (0.3.13-3)
[2020-11-11T16:08:58-0300] [ALPM-SCRIPTLET] Created symlink /etc/systemd/user/sockets.target.wants/pipewire.socket ā /usr/lib/systemd/user/pipewire.socket.
[2020-11-11T16:08:58-0300] [ALPM] installed libqaccessibilityclient (0.4.1-2)
[2020-11-11T16:09:00-0300] [ALPM] upgraded kwin (5.19.5-2 -> 5.20.2-1)
[2020-11-11T16:09:00-0300] [ALPM] upgraded libixion (0.15.0-1 -> 0.16.1-1)
[2020-11-11T16:09:00-0300] [ALPM] upgraded libkexiv2 (20.08.2-1 -> 20.08.3-1)
[2020-11-11T16:09:00-0300] [ALPM] upgraded libmm-glib (1.14.2-1 -> 1.14.6-1)
[2020-11-11T16:09:00-0300] [ALPM] upgraded libmspub (0.1.4-7 -> 0.1.4-8)
[2020-11-11T16:09:00-0300] [ALPM] upgraded libnewt (0.52.21-3 -> 0.52.21-4)
[2020-11-11T16:09:00-0300] [ALPM] upgraded libnm (1.26.2-1 -> 1.26.4-1)
[2020-11-11T16:09:00-0300] [ALPM] upgraded liborcus (0.15.4-1 -> 0.16.1-1)
[2020-11-11T16:09:00-0300] [ALPM] upgraded libpwquality (1.4.2-3 -> 1.4.4-1)
[2020-11-11T16:09:01-0300] [ALPM] upgraded libqalculate (3.13.0-1 -> 3.14.0-1)
[2020-11-11T16:09:01-0300] [ALPM] upgraded libqmi (1.26.4-1 -> 1.26.6-1)
[2020-11-11T16:09:01-0300] [ALPM] upgraded xmlsec (1.2.30-2 -> 1.2.31-1)
[2020-11-11T16:09:20-0300] [ALPM] upgraded libreoffice-fresh (7.0.2-1 -> 7.0.3-2)
[2020-11-11T16:09:34-0300] [ALPM] upgraded linux-firmware (20200916.00a84c5-1 -> 20201023.dae4b4c-1)
[2020-11-11T16:09:34-0300] [ALPM] warning: /etc/mkinitcpio.conf installed as /etc/mkinitcpio.conf.pacnew
[2020-11-11T16:09:34-0300] [ALPM] upgraded mkinitcpio (28-1 -> 29-1)
[2020-11-11T16:09:43-0300] [ALPM] upgraded linux (5.8.14-1 -> 5.9.6-1)
[2020-11-11T16:09:45-0300] [ALPM] upgraded man-pages (5.08-1 -> 5.09-1)
[2020-11-11T16:09:45-0300] [ALPM] upgraded milou (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:09:45-0300] [ALPM] upgraded mntray (1.1.2-1 -> 1.1.3-1)
[2020-11-11T16:09:45-0300] [ALPM] upgraded modemmanager (1.14.2-1 -> 1.14.6-1)
[2020-11-11T16:09:46-0300] [ALPM] upgraded networkmanager (1.26.2-1 -> 1.26.4-1)
[2020-11-11T16:09:46-0300] [ALPM] upgraded qca (2.3.1-3 -> 2.3.1-4)
[2020-11-11T16:09:47-0300] [ALPM] upgraded okular (20.08.2-1 -> 20.08.3-1)
[2020-11-11T16:09:48-0300] [ALPM] upgraded openssh (8.4p1-1 -> 8.4p1-2)
[2020-11-11T16:09:48-0300] [ALPM] upgraded openvpn (2.4.9-2 -> 2.5.0-1)
[2020-11-11T16:09:48-0300] [ALPM] upgraded python-urllib3 (1.25.10-1 -> 1.25.10-2)
[2020-11-11T16:09:48-0300] [ALPM] upgraded python-setuptools (1:50.3.0-1 -> 1:50.3.2-1)
[2020-11-11T16:09:48-0300] [ALPM] upgraded pamac-common (9.5.11-1 -> 9.5.12-1)
[2020-11-11T16:09:48-0300] [ALPM] upgraded pamac-cli (9.5.11-1 -> 9.5.12-1)
[2020-11-11T16:09:48-0300] [ALPM] upgraded pamac-gtk (9.5.11-1 -> 9.5.12-1)
[2020-11-11T16:09:48-0300] [ALPM] upgraded pamac-tray-appindicator (9.5.11-1 -> 9.5.12-1)
[2020-11-11T16:09:48-0300] [ALPM] upgraded polkit-kde-agent (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:09:48-0300] [ALPM] upgraded plasma-integration (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:09:48-0300] [ALPM] upgraded qrencode (4.1.0-1 -> 4.1.1-1)
[2020-11-11T16:09:51-0300] [ALPM] upgraded plasma-workspace (5.19.5-3 -> 5.20.2-1)
[2020-11-11T16:09:51-0300] [ALPM] upgraded systemsettings (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:09:54-0300] [ALPM] upgraded plasma-desktop (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:09:54-0300] [ALPM] upgraded plasma-nm (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:09:54-0300] [ALPM] upgraded plasma-pa (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:09:54-0300] [ALPM] upgraded plasma-vault (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:09:54-0300] [ALPM] upgraded powerdevil (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:09:54-0300] [ALPM] upgraded xorg-xkbcomp (1.4.3-1 -> 1.4.4-1)
[2020-11-11T16:09:55-0300] [ALPM] upgraded sddm (0.18.1-3 -> 0.19.0-2)
[2020-11-11T16:09:55-0300] [ALPM] upgraded sddm-kcm (5.19.5-1 -> 5.20.2-1)
[2020-11-11T16:09:55-0300] [ALPM] upgraded spectacle (20.08.2-1 -> 20.08.3-1)
[2020-11-11T16:09:55-0300] [ALPM] warning: /boot/extlinux/extlinux.conf saved as /boot/extlinux/extlinux.conf.pacsave
[2020-11-11T16:09:55-0300] [ALPM] upgraded uboot-rockpi4b (2020.07-4 -> 2020.10-1)
[2020-11-11T16:09:55-0300] [ALPM-SCRIPTLET] A new U-Boot version can be flashed onto your install drive. Please use lsblk to determine your drive, before proceeding.
[2020-11-11T16:09:55-0300] [ALPM-SCRIPTLET] You can do this by running:
[2020-11-11T16:09:55-0300] [ALPM-SCRIPTLET] # dd if=/boot/idbloader.img of=/dev/mmcblkX seek=64 conv=notrunc
[2020-11-11T16:09:55-0300] [ALPM-SCRIPTLET] # dd if=/boot/u-boot.itb of=/dev/mmcblkX seek=16384 conv=notrunc
[2020-11-11T16:09:55-0300] [ALPM-SCRIPTLET] Keeping old extlinux.conf file...
[2020-11-11T16:09:55-0300] [ALPM] upgraded xorg-xinit (1.4.1-2 -> 1.4.1-3)
[2020-11-11T16:09:55-0300] [ALPM] transaction completed
[2020-11-11T16:09:58-0300] [ALPM] running '20-systemd-sysusers.hook'...
[2020-11-11T16:09:58-0300] [ALPM] running '30-systemd-daemon-reload.hook'...
[2020-11-11T16:09:58-0300] [ALPM] running '30-systemd-hwdb.hook'...
[2020-11-11T16:09:59-0300] [ALPM] running '30-systemd-tmpfiles.hook'...
[2020-11-11T16:10:00-0300] [ALPM] running '30-systemd-udev-reload.hook'...
[2020-11-11T16:10:00-0300] [ALPM] running '30-systemd-update.hook'...
[2020-11-11T16:10:00-0300] [ALPM] running '40-update-ca-trust.hook'...
[2020-11-11T16:10:03-0300] [ALPM] running '60-depmod.hook'...
[2020-11-11T16:10:03-0300] [ALPM] running '60-linux.hook'...
[2020-11-11T16:10:10-0300] [ALPM] running '90-linux.hook'...
[2020-11-11T16:10:10-0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux.preset: 'default'
[2020-11-11T16:10:10-0300] [ALPM-SCRIPTLET] -> -k 5.9.6-1-MANJARO-ARM -c /etc/mkinitcpio.conf -g /boot/initramfs-linux.img
[2020-11-11T16:10:11-0300] [ALPM-SCRIPTLET] ==> Starting build: 5.9.6-1-MANJARO-ARM
[2020-11-11T16:10:11-0300] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2020-11-11T16:10:12-0300] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2020-11-11T16:10:13-0300] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2020-11-11T16:10:14-0300] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2020-11-11T16:10:14-0300] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2020-11-11T16:10:15-0300] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2020-11-11T16:10:15-0300] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2020-11-11T16:10:15-0300] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2020-11-11T16:10:15-0300] [ALPM-SCRIPTLET] -> Running build hook: [bootsplash-manjaro]
[2020-11-11T16:10:15-0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2020-11-11T16:10:16-0300] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-linux.img
[2020-11-11T16:10:19-0300] [ALPM-SCRIPTLET] ==> Image generation successful
[2020-11-11T16:10:19-0300] [ALPM] running '90-mkinitcpio-install.hook'...
[2020-11-11T16:10:19-0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux.preset: 'default'
[2020-11-11T16:10:19-0300] [ALPM-SCRIPTLET] -> -k 5.9.6-1-MANJARO-ARM -c /etc/mkinitcpio.conf -g /boot/initramfs-linux.img
[2020-11-11T16:10:19-0300] [ALPM-SCRIPTLET] ==> Starting build: 5.9.6-1-MANJARO-ARM
[2020-11-11T16:10:20-0300] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2020-11-11T16:10:21-0300] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2020-11-11T16:10:22-0300] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2020-11-11T16:10:22-0300] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2020-11-11T16:10:22-0300] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2020-11-11T16:10:23-0300] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2020-11-11T16:10:23-0300] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2020-11-11T16:10:24-0300] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2020-11-11T16:10:24-0300] [ALPM-SCRIPTLET] -> Running build hook: [bootsplash-manjaro]
[2020-11-11T16:10:24-0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2020-11-11T16:10:24-0300] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-linux.img
[2020-11-11T16:10:28-0300] [ALPM-SCRIPTLET] ==> Image generation successful
[2020-11-11T16:10:28-0300] [ALPM] running 'dbus-reload.hook'...
[2020-11-11T16:10:28-0300] [ALPM] running 'glib-compile-schemas.hook'...
[2020-11-11T16:10:28-0300] [ALPM] running 'gtk-update-icon-cache.hook'...
[2020-11-11T16:10:28-0300] [ALPM] running 'texinfo-install.hook'...
[2020-11-11T16:10:29-0300] [ALPM] running 'update-desktop-database.hook'...
[2020-11-11T16:10:29-0300] [ALPM] running 'update-mime-database.hook'...
[2020-11-11T17:03:59-0300] [PACMAN] Running 'pacman -S lighdm-gtk-greeter-settings'
[2020-11-11T17:05:18-0300] [PACMAN] Running 'pacman -S lighdm lightdm-gtk-greeter lightdm-gtk-greeter-settings'
[2020-11-11T17:06:14-0300] [PACMAN] Running 'pacman -S gparted'
[2020-11-11T17:06:35-0300] [PACMAN] Running 'pacman -S lightdm'
[2020-11-11T17:07:20-0300] [PACMAN] Running 'pacman -S lightdm lightdm-gtk-greeter lightdm-gtk-greeter-settings'
[2020-11-11T17:07:34-0300] [ALPM] transaction started
[2020-11-11T17:07:34-0300] [ALPM] installed libxklavier (5.4-3)
[2020-11-11T17:07:34-0300] [ALPM] installed lightdm (1:1.30.0-4)
[2020-11-11T17:07:34-0300] [ALPM] installed lightdm-gtk-greeter (1:2.0.8-1)
[2020-11-11T17:07:34-0300] [ALPM] installed gobject-introspection-runtime (1.66.1-1)
[2020-11-11T17:07:34-0300] [ALPM] installed python-gobject (3.38.0-1)
[2020-11-11T17:07:34-0300] [ALPM] installed lightdm-gtk-greeter-settings (1.2.2-4)
[2020-11-11T17:07:34-0300] [ALPM] transaction completed
[2020-11-11T17:07:35-0300] [ALPM] running '20-systemd-sysusers.hook'...
[2020-11-11T17:07:35-0300] [ALPM-SCRIPTLET] Creating group lightdm with gid 971.
[2020-11-11T17:07:35-0300] [ALPM-SCRIPTLET] Creating user lightdm (Light Display Manager) with uid 971 and gid 971.
[2020-11-11T17:07:35-0300] [ALPM] running '30-systemd-daemon-reload.hook'...
[2020-11-11T17:07:35-0300] [ALPM] running '30-systemd-tmpfiles.hook'...
[2020-11-11T17:07:35-0300] [ALPM] running '30-systemd-update.hook'...
[2020-11-11T17:07:35-0300] [ALPM] running 'dbus-reload.hook'...
[2020-11-11T17:07:35-0300] [ALPM] running 'gtk-update-icon-cache.hook'...
[2020-11-11T17:07:36-0300] [ALPM] running 'update-desktop-database.hook'...
Now I am from another machine to answer this. I restarted the Rockpi4b after installing the lightdm packages, and I continue with the same problem, with the aggravation that I can no longer access the manjaro desktop from rockpi, unless I reinstall the operating system.
Yes I have access to the nvme disk where I have the system installed, but from the machine that I am using at the moment to write these lines. That way I accessed /var/log/pacman.log to copy them here
You asked me to copy the content of /var/log/pacman.log from the other tty, that is, from the command line, with nano, but I donāt know how to do that. So I rebooted the machine to see if it would work with reinstalling lightdm but not.
If I copy the installation image onto an SD card and boot my PBP from that card, it sets itself up to run from the SD card. How do I install onto the internal eMMC? I recall this was what an older image did (circa 20.04) but it didnāt give me an option to not do thatā¦
The way to flash to internal eMMC has changed slightly.
Look at the section in the Original Post of this Topic called āNew application for flashing imagesā.
Install manjaro-arm-flasher on your Manjaro SD card install.
Then open āManjaro ARM Flasherā from your menu and select the Device, Edition and Version you want to install to eMMC.
Thanks, that worked. Can I suggest that manjaro-arm-flasher and manjaro-arm-installer should be added to the set of packages included on the image? If only because installing them via pacman might necessitate a full system update first.
Good suggestion. Itās up to the edition maintainers to include them in their editions. But I think I will include it in mine, just for ease of use.
Ditto on XFCE.
If this is the case then what is manjaro-arm-emmc-flasher for?
Itās what we used before.
But it required us to do 2 images pr device/edition. Which wastes space on our CDN.
I would like test an image for odroid c4
is it possible to get it?
the connection hdmidvi is working under debian
is it possible to get an x86 minimal image iso with the arm flasher 4 sd?
thnks
Right now, you can only get an Odroid C4 install, by using the Manjaro ARM Installer.
No.
question where i could get the arm image for odroid c4?
as i saw no link for odroid c4.
could you post the link?
thnks
