Is anyone else having a problem with os-prober? In the last two days I’ve done three different operations and every time os-prober stalls and I have to reboot. The reboots take an extended amount of time because my system is waiting for processes to finish. The three operations I’ve tried to perform are;
A system update, it went well until the very end where it was running the post transaction hooks, os-prober stalled.
An hour ago I tried instlalling the 6.6 kernel. The kernel installed but was not listed in my grub menu. os-prober stalled.
A half hour ago I tried running sudo update-grub output was;
Generating grub configuration file …
Found linux image: /boot/vmlinuz-6.6-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-6.6-x86_64.img
Found initrd fallback image: /boot/initramfs-6.6-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.4-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-6.4-x86_64.img
Found initrd fallback image: /boot/initramfs-6.4-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
And there I currently sit, os-prober stalled again!
I have two other hard drives on this pc, one hard drive has blend os on it and the other has fedora. Both have their very own grub and if I want to use them I change the boot order so that I am booting to that drive and using each installs grub that was installed when I installed the system on that particular disk.
As far as I know there are no issues with the file systems on either disk. Any ideas on why this issue is suddenly occuring?
