I’ve been having a strange problem for some time. Manjaro after booting, tends to crash and restart. The strange thing is that the pc can stay on even for so many hours that it doesn’t show any kind of problem. This error occurs only after the boot phase.
Ram and ssd tested and are ok.
Kernel: 6.1.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=50499043-af8c-4110-81de-cfcd7c8b9e38 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 dm: SDDM
Type: Desktop Mobo: SAPPHIRE model: EDGE VS series v: FP2M3038 serial: N/A
UEFI: American Megatrends v: 4.6.5 date: 03/22/2013
RAM: total: 7.23 GiB used: 5.1 GiB (70.5%)
Array-1: capacity: 8 GiB slots: 2 EC: None max-module-size: 4 GiB
note: est.
Device-1: A1_DIMM0 type: DDR3 detail: synchronous unbuffered (unregistered)
size: 4 GiB speed: 667 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: Samsung part-no: N/A serial: <filter>
Device-2: A1_DIMM1 type: DDR3 detail: synchronous unbuffered (unregistered)
size: 4 GiB speed: spec: 667 MT/s actual: 54205 MT/s note: check volts: N/A
width (bits): data: 64 total: 64 manufacturer: Samsung part-no: N/A
serial: <filter>
Info: model: AMD A8-4555M APU with Radeon HD Graphics socket: P0 bits: 64
type: MT MCP arch: Piledriver level: v2 built: 2012-13 process: GF 32nm
family: 0x15 (21) model-id: 0x10 (16) stepping: 1 microcode: 0x6001119
Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 192 KiB
desc: d-4x16 KiB; i-2x64 KiB L2: 4 MiB desc: 2x2 MiB
Speed (MHz): avg: 1100 min/max: 1100/1600 boost: enabled
base/boost: 1600/1600 scaling: driver: acpi-cpufreq governor: schedutil
volts: 0.9 V ext-clock: 100 MHz cores: 1: 1100 2: 1100 3: 1100 4: 1100
bogomips: 12781
Flags: 3dnowprefetch abm aes aperfmperf apic arat avx bmi1 clflush cmov
cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists
extapic extd_apicid f16c flushbyasid fma fma4 fpu fxsr fxsr_opt ht
hw_pstate ibs lahf_lm lbrv lm lwp mca mce misalignsse mmx mmxext monitor
msr mtrr nodeid_msr nonstop_tsc nopl npt nrip_save nx osvw pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 svm svm_lock syscall tbm tce topoext tsc tsc_scale vmcb_clean
vme vmmcall wdt xop xsave
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: AMD Trinity [Radeon HD 7600G] driver: radeon v: kernel
alternate: amdgpu arch: TeraScale-3 code: Northern Islands process: TSMC 32nm
built: 2010-13 ports: active: HDMI-A-1 empty: DP-1 bus-ID: 00:01.0
chip-ID: 1002:9908 class-ID: 0300
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
loaded: radeon unloaded: modesetting alternate: fbdev,vesa dri: r600
gpu: radeon display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-1 mapped: HDMI-0 model: LG (GoldStar) FULL HD
serial: <filter> built: 2016 res: 1920x1080 hz: 75 dpi: 102 gamma: 1.2
size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
API: OpenGL v: 4.5 Mesa 22.3.4 renderer: AMD ARUBA (DRM 2.50.0 /
6.1.9-1-MANJARO LLVM 15.0.7) direct-render: Yes
Device-1: AMD Trinity HDMI Audio driver: snd_hda_intel v: kernel
bus-ID: 00:01.1 chip-ID: 1002:9902 class-ID: 0403
Device-2: AMD FCH Azalia driver: snd_hda_intel v: kernel bus-ID: 00:14.2
chip-ID: 1022:780d class-ID: 0403
Sound API: ALSA v: k6.1.9-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.65 running: yes
vendor: PC Partner / Sapphire driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Ralink RT3290 Wireless 802.11n 1T/1R PCIe vendor: AzureWave
driver: rt2800pci v: 2.3.0 pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 1814:3290 class-ID: 0280
IF: wlp3s0f0 state: down mac: <filter>
Device-1: Ralink RT3290 Bluetooth vendor: AzureWave driver: N/A pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.1 chip-ID: 1814:3298 class-ID: 0d11
Device-2: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 4-1:2 chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
Report: ID: hci0 rfk-id: 0 state: up address: N/A
Local Storage: total: 465.76 GiB used: 216.84 GiB (46.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
family: based SSDs size: 465.76 GiB block-size: physical: 512 B
logical: 512 B sata: 3.2 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 4B6Q temp: 45 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 264d 10h cycles: 3195
written: 10.42 TiB
ID-1: / raw-size: 36.9 GiB size: 36.03 GiB (97.63%) used: 19.77 GiB (54.9%)
fs: ext4 block-size: 4096 B dev: /dev/sda2 maj-min: 8:2 label: system
uuid: 50499043-af8c-4110-81de-cfcd7c8b9e38
ID-2: /boot/efi raw-size: 501 MiB size: 500 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
label: N/A uuid: 0054-16C8
ID-3: /home raw-size: 37.25 GiB size: 36.37 GiB (97.63%)
used: 23.81 GiB (65.5%) fs: ext4 block-size: 4096 B dev: /dev/sda3
maj-min: 8:3 label: home uuid: e1dd12e3-13d5-42c6-b4ea-6b4ef81373a1
ID-4: /media/DATI raw-size: 360.12 GiB size: 353.4 GiB (98.13%)
used: 173.25 GiB (49.0%) fs: ext4 block-size: 4096 B dev: /dev/sda4
maj-min: 8:4 label: DATI uuid: dbacbefd-21ad-4421-bcd2-f56a19720edd
ID-5: /media/TV raw-size: N/A size: 3.58 TiB used: 2.12 TiB (59.2%) fs: nfs
remote: 192.168.1.11:/export/TV
ID-6: /media/cartoni raw-size: N/A size: 3.58 TiB used: 2.12 TiB (59.2%)
fs: nfs remote: 192.168.1.11:/export/Cartoni
ID-7: /media/christian raw-size: N/A size: 3.58 TiB used: 2.12 TiB (59.2%)
fs: nfs remote: 192.168.1.11:/export/home
ID-8: /media/fanta1 raw-size: N/A size: 457.38 GiB used: 142.77 GiB (31.2%)
fs: nfs remote: 192.168.1.11:/export/FANTA1
ID-9: /media/film raw-size: N/A size: 3.58 TiB used: 2.12 TiB (59.2%)
fs: nfs remote: 192.168.1.11:/export/Film
ID-10: /media/music raw-size: N/A size: 3.58 TiB used: 2.12 TiB (59.2%)
fs: nfs remote: 192.168.1.11:/export/Musica
ID-11: /media/photo raw-size: N/A size: 3.58 TiB used: 2.12 TiB (59.2%)
fs: nfs remote: 192.168.1.11:/export/Foto
ID-12: /media/torrent raw-size: N/A size: 457.38 GiB used: 21.4 GiB (4.7%)
fs: nfs remote: 192.168.1.11:/export/torrent
Hub-1: 1-0:1 info: Full speed or root hub ports: 5 rev: 2.0 speed: 480 Mb/s
Hub-2: 2-0:1 info: Full speed or root hub ports: 5 rev: 2.0 speed: 480 Mb/s
Hub-3: 3-0:1 info: Full speed or root hub ports: 5 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Hub-4: 4-0:1 info: Full speed or root hub ports: 5 rev: 1.1 speed: 12 Mb/s
Device-1: 4-1:2 info: Realtek Bluetooth Radio type: Bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA chip-ID: 0bda:8771
Device-2: 4-2:3 info: HP HP Wireless Keyboard and Mouse
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 03f0:2641 class-ID: 0301
Hub-5: 5-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-6: 6-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-7: 7-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 62.0 C mobo: N/A gpu: radeon temp: 60.0 C
Processes: 234 Uptime: 3h 48m wakeups: 1 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1608 libs: 390 tools: pamac pm: flatpak pkgs: 0
Shell: Zsh (sudo) v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.25
Cecking with journalctl --facility=3 --priority=3
- Boot 37bd73d7e9eb48dbb4d3d1fe610c36b0 --
feb 11 05:09:46 Astro64bit bluetoothd[493]: src/plugin.c:plugin_init() Failed to init vcp plugin
feb 11 05:09:46 Astro64bit bluetoothd[493]: src/plugin.c:plugin_init() Failed to init mcp plugin
feb 11 05:09:46 Astro64bit bluetoothd[493]: src/plugin.c:plugin_init() Failed to init bap plugin
-- Boot 0b95d7f24828449789cbb545fa08756e --
feb 11 05:11:21 Astro64bit systemd-coredump[704]: Failed to connect to coredump service: Connection refused
-- Boot a17b12a405f948a48059a5f0febe4a3f --
feb 11 05:11:50 Astro64bit bluetoothd[508]: src/plugin.c:plugin_init() Failed to init vcp plugin
feb 11 05:11:50 Astro64bit bluetoothd[508]: src/plugin.c:plugin_init() Failed to init mcp plugin
feb 11 05:11:50 Astro64bit bluetoothd[508]: src/plugin.c:plugin_init() Failed to init bap plugin
feb 11 05:12:20 Astro64bit bluetoothd[508]: Failed to add UUID: Authentication Failed (0x05)
feb 11 05:12:22 Astro64bit bluetoothd[508]: Failed to add UUID: Authentication Failed (0x05)
