Kernel Version 5.15.7-1
Last things I’ve done were install some language packs which it said to be missing, and several applications, the last one being “Intellij idea community”; I’ve also applied some updates from pacman graphic interface.
Now, system, in GUI mode, frozes after some minutes; no mouse, no key response, the only way to get a response from the computer is to turn off.
The image shows Ntop after system froze. May be it is a journald problem?
I’ve tried to open a terminal before GUI login, and it’s worked!
I have done a pacman update, and system seems to be working now…
I’d entered terminal to run inxi, and this were the result:
Kernel: 5.15.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: ro root=UUID=886f64f9-d824-41d1-80a2-d374c3d36147
initrd=boot\initramfs-5.15-x86_64.img
Console: tty 5 DM: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 81BG v: Lenovo ideapad 320-15IKB
serial: <filter> Chassis: type: 10 v: Lenovo ideapad 320-15IKB
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40700 WIN serial: <filter>
UEFI: LENOVO v: 6JCN33WW date: 06/30/2020
ID-1: BAT0 charge: 18.8 Wh (84.7%) condition: 22.2/30.0 Wh (74.2%)
volts: 8.1 min: 7.4 model: LGC L16L2PB2 type: Li-poly serial: <filter>
status: Charging
RAM: total: 11.48 GiB used: 593.6 MiB (5.1%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: ChannelA-DIMM0 size: 4 GiB speed: 2133 MT/s type: DDR4
detail: synchronous unbuffered (unregistered) bus-width: 64 bits
total: 64 bits manufacturer: Samsung part-no: M471A5244CB0-CRC serial: N/A
Device-2: ChannelB-DIMM0 size: 8 GiB speed: 2133 MT/s type: DDR4
total: 64 bits manufacturer: G.Skill part-no: F4-2133C15-8GRS serial: N/A
Info: model: Intel Core i5-8250U socket: U3E1 bits: 64 type: MT MCP
arch: Coffee Lake family: 6 model-id: 0x8E (142) stepping: 0xA (10)
microcode: 0xD6
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 702 high: 718 min/max: 400/3400 base/boost: 1500/3400
scaling: driver: intel_pstate governor: powersave volts: 0.7 V
ext-clock: 100 MHz cores: 1: 718 2: 700 3: 700 4: 700 5: 699 6: 700 7: 700
8: 700 bogomips: 28808
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp
hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm mca
mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep sgx smap smep ss ssbd sse sse2
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: Syntek EasyCamera type: USB driver: uvcvideo bus-ID: 1-8:3
chip-ID: 174f:116a class-ID: 0e02 serial: <filter>
Display: server: X.org 1.21.1.2 driver: loaded: modesetting
alternate: fbdev,vesa tty: 170x48
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.40 running: no
vendor: Lenovo driver: r8169 v: kernel port: 4000 bus-ID: 01:00.0
IF: enp1s0 state: down mac: <filter>
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: 3000
bus-ID: 02:00.0 chip-ID: 10ec:c821 class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-7:2 chip-ID: 0bda:c024 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.03 TiB used: 14.88 GiB (1.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: SK Hynix model: HFS128G32TNF-N3A0A
size: 119.24 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0P10 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SDSSDH3 1T00
type: SSD serial: <filter> rev: 20RL scheme: GPT
ID-1: / raw-size: 73.24 GiB size: 71.54 GiB (97.68%) used: 14.68 GiB (20.5%)
fs: ext4 block-size: 4096 B dev: /dev/sdb2 maj-min: 8:18 label: MJ-ROOT
uuid: 886f64f9-d824-41d1-80a2-d374c3d36147
ID-2: /efi raw-size: 384 MiB size: 380 MiB (98.96%) used: 2 MiB (0.5%)
fs: vfat block-size: 512 B dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 6864-413A
ID-3: /home raw-size: 73.24 GiB size: 71.54 GiB (97.68%)
used: 203.6 MiB (0.3%) fs: ext4 block-size: 4096 B dev: /dev/sdb3
maj-min: 8:19 label: MJ-HOME uuid: dd1b813b-cfbb-44e0-b1c0-8371b5027442
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb4 maj-min: 8:20 label: MJ-SWAP
uuid: 9659dec3-9ddc-44b4-9a6c-6a92d4fbc9c6
ID-1: /dev/sda1 maj-min: 8:1 size: 260 MiB fs: vfat label: SYSTEM_DRV
uuid: 7656-6044
ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-3: /dev/sda3 maj-min: 8:3 size: 118 GiB fs: ntfs label: Windows
uuid: 42D05A1CD05A168F
ID-4: /dev/sda4 maj-min: 8:4 size: 1000 MiB fs: ntfs label: WINRE_DRV
uuid: 2CDE5B7DDE5B3E70
ID-5: /dev/sdb5 maj-min: 8:21 size: 768.65 GiB fs: ntfs label: Virtual
uuid: 48621C73621C67C8
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-7:2 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Device-2: 1-8:3 info: Syntek EasyCamera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 174f:116a
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 30.0 C pch: 32.0 C mobo: N/A
Processes: 172 Uptime: 11m wakeups: 384 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1216 lib: 347
flatpak: 0 Shell: Bash (sudo) v: 5.1.12 running-in: tty 5 inxi: 3.3.11
