5 posts were merged into an existing topic: [Stable Update] 2024-05-18 - Linux-Firmware, PHP, Gitlab, Qt6
One observation: only a small percentage of the checksum links (in this thread) have been clicked versus the .ISO links ⌠![]()
Folks, comments in the thread should be about feedback regarding the ISOs and fresh installs, not updating from existing installs. Iâve had to move multiple replies to the proper Stable Updates thread.
Fresh install in my case is the Manjaro GNOME .ISO in VirtualBox. Works well so far with my experimentation/testing. I didnât install an office suite or a few other things I wonât need for VB testing.
The only issue Iâve had is I found it locks up after a while in (U)EFI mode but that seemingly isnât a Manjaro issue rather a VirtualBox problem (same thing happens with EndeavourOS and Manjaro KDE).
Also my issue of being a Gnome âVirginâ and as yet have no idea how to find my way around it! Totally alien to me. (Installed it to see if might be useful for âhelpingâ on here).
You will be quite surprised checking all previous Manjaro versions namesâŚ
Haha @anton6613 hit the nail on the head - thatâs funny.
Wasnât âVulcanâ a dead giveaway? ![]()
LLAP...
So I managed to get up-to-date and running nvidia-390 with Plasma 6 [and even Wayland (but only @480p)] with kernels 61, 65, 66, 69.
The last and only iso I could do it with was manjaro-kde-23.0.4-231015-linux65.iso
The ones before it might be doable, but you run into dependency-cycle issues with plasma5>plasma6 packages on pamac/pacman.
The ones after, the isos came with linux66 or newer and proprietary installs (my graphics card is NVIDIA GF119M [GeForce 410M]) would not boot past the logo on the 66+ kernels.
As this might be scaring off ânew users on older hardwareâ I believe this is useful info for devs here.
There must have been some changes in either Calamares, or possibly Mhwd from the 23.0.4 to the 23.1.0 release! Sddm I donât think is an issue as I selected auto-login on boot in Calamares.
As this is not only concerning this Wynsdey release I can provide info in the thread I opened here for the issue: Nvidia 390 not working with kernel 66 on new install?
Btw, where can I find the plasma-to-defaults.sh script kindly provided by @linux-aarhus ?
Oh no - I see trouble aheadâŚ
They have all been celestial bodies. Planets. And stars in some cases I think?
( in the Star Trek universe
Vulcan, in particular; both a planet (homeworld of Spock) and part of the Star Trek Universe. Some little-known trivia is that Vulcan was once thought to be an actual planet (or planetesimal) within our own non-fictional star system; a hypothetical planet claimed to have been discovered in orbit between Sol and Mercury (though never rediscovered or confirmed). Hereâs another fun fact.
Linux distribution code names have always amused me. In particular, Debian, with itâs âToy Storyâ theme. Iâm still waiting for any distribution to choose âWascally Wabbitâ as a code name.
Trouble? Why, I think Grand Nagus Zek would make a fine name for a release.
Article in distrowatch about Manjaro: DistroWatch.com: Put the fun back into computing. Use Linux, BSD.
It was a long time since I had installed Manjaro. I decided to reinstall it on my old desktop, since it was a bit of a mess.
I used the default installer with manual partitioning, since I use a bunch of lvm volumes and wanted to keep the layout.
Everything went fine, first boost froze, maybe something related to Wayland, I donât know (I use X11). Changed tty, terminated the session, installed some more packages I needed, rebooted and everything seems to be working fine.
Thank you very much to the team and keep the good work.
Oh, I changed the kernel to 6.6, but 6.9 was working fine
Kernel: 6.6.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/vmlinuz-6.6-x86_64
root=/dev/mapper/vgManjaro-lvRoot rw quiet splash udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: P5P43TD PRO v: Rev X.0x
serial: <superuser required> uuid: <superuser required>
BIOS: American Megatrends v: 0710 date: 11/04/2010
Info: model: Intel Core2 Quad Q9650 bits: 64 type: MCP arch: Penryn
level: v1 built: 2008 process: Intel 45nm family: 6 model-id: 0x17 (23)
stepping: 0xA (10) microcode: 0xA0B
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 12 MiB desc: 2x6 MiB
Speed (MHz): avg: 3300 high: 3600 min/max: N/A cores: 1: 3600 2: 2400
3: 3600 4: 3600 bogomips: 28808
Flags: ht lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT disabled
Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling;
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 2
speed: 5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: HDMI-A-2 off: HDMI-A-1 empty: DP-1,DP-2,DVI-D-1 bus-ID: 01:00.0
chip-ID: 1002:67df class-ID: 0300 temp: 46.0 C
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
s-diag: 581mm (22.86") monitors: <missing: xrandr>
Monitor-1: HDMI-A-1 model: LG (GoldStar) TV serial: <filter> built: 2009
res: 1440x900 dpi: 78 gamma: 1.2 size: 409x230mm (16.1x9.06")
diag: 558mm (22") ratio: 16:10 modes: max: 1440x900 min: 720x400
Monitor-2: HDMI-A-2 model: LG (GoldStar) W2246 serial: <filter>
built: 2010 res: 1920x1080 dpi: 102 gamma: 1.2
size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.8-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 470 Graphics
(radeonsi polaris10 LLVM 17.0.6 DRM 3.54 6.6.32-1-MANJARO)
device-ID: 1002:67df memory: 3.91 GiB unified: no
Device-1: Intel 82801JI HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3a3e class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1
chip-ID: 1002:aaf0 class-ID: 0403
API: ALSA v: k6.6.32-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
Device-1: Qualcomm Atheros AR8121/AR8113/AR8114 Gigabit or Fast Ethernet
vendor: ASUSTeK driver: ATL1E v: N/A modules: atl1e pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: dc00 bus-ID: 02:00.0 chip-ID: 1969:1026
class-ID: 0200
Device-2: Realtek RTL88x2bu [AC1200 Techkey] driver: rtw_8822bu type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 9-1.4:3
chip-ID: 0bda:b812 class-ID: 0000 serial: <filter>
IF: wlp4s0u1u4 state: up mac: <filter>
Device-1: ASUSTek ASUS USB-BT500Ăż driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 0b05:190e
Local Storage: total: 1.25 TiB used: 12.49 GiB (1.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: PNY model: CS900 120GB SSD
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0613 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SD7SB3Q064G1122
size: 59.63 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0000 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Zheino model: CHN 25SATA02M 064
size: 59.62 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: 6K scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Hitachi model: HDT721010SLA360
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: A31B scheme: MBR
ID-5: /dev/sde maj-min: 8:64 vendor: Vaseky model: V800 128G
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: SSD serial: <filter> fw-rev: 7A scheme: GPT
ID-1: / raw-size: 78.2 GiB size: 78.19 GiB (100.00%) used: 12.17 GiB (15.6%)
fs: f2fs dev: /dev/dm-14 maj-min: 254:14 mapped: vgManjaro-lvRoot
ID-2: /boot raw-size: 512 MiB size: 487.2 MiB (95.16%)
used: 322.7 MiB (66.2%) fs: ext4 dev: /dev/dm-5 maj-min: 254:5
mapped: vgManjaro-lvBoot
System Temperatures: cpu: 209.0 C mobo: 33.0 C gpu: amdgpu temp: 46.0 C
Fan Speeds (rpm): cpu: 892 psu: 1298 case-1: 1973 gpu: amdgpu fan: 1454
Power: 12v: 12.62 5v: N/A 3.3v: 2.93 vbat: N/A gpu: amdgpu watts: 14.00
Memory: total: 16 GiB available: 15.62 GiB used: 2.07 GiB (13.2%)
Processes: 268 Power: uptime: 17m states: freeze,standby,mem,disk
suspend: deep avail: s2idle,shallow wakeups: 0 hibernate: platform
avail: shutdown, reboot, suspend, test_resume image: 6.23 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1187 libs: 345 tools: pamac pm: flatpak pkgs: 0
Compilers: N/A Shell: Zsh v: 5.9 default: Bash v: 5.2.26 running-in: konsole
inxi: 3.3.34
HI , how did you make the taskbarâs âcurrent running appsâ look like that? I mean like, with the name displaying and all
I am on KDE myself and would like to change to that. Hereâs a screenshot of my taskbar setup
Right click on free space of your panel and choose another alternative.
thanks so much, good sir!
It seems Wynsdey III is quite obscure in Star Trek lore.
I suppose itâs understandable that the reference is so obscure:
Despite itâs obscurity, I imagine it was considered vital for the particular episode; at least from the perspective of whoever write it. If Iâm reading the trivia correctly, Wyndney didnât actually make it to the finished episode.
