Is there an upgrade method?
I ran the script - the Dolphin interface still locks up in the same way I demonstrated in this thread. Dolphin browser & Taskbar frequently hangs, locks up, since Nibia 20.2
Worth noting, the script had an error, attica-git was still present and so was in conflict with attica. I saved the output below (note I had already removed user-manager-git as per the instructions from a post above).
Updating package databases
core 169.5 KiB 277 KiB/s 00:01 [##################] 100%
extra 1999.3 KiB 1968 KiB/s 00:01 [##################] 100%
community 6.3 MiB 3.81 MiB/s 00:02 [##################] 100%
multilib 189.4 KiB 7.71 MiB/s 00:00 [##################] 100%
Removing git-packages from your system
error: target not found: user-manager-git
Installing needed stable packages to your system
resolving dependencies...
:: attica and attica-git are in conflict. Remove attica-git? [y/N]
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
Your system should been fixed now. A reboot is recommended.
So I manually removed attica-git and added attica, with the same commands the script used, and it succeeded that time. I rebooted and still get the same lockup. Looks like I’ll have to re-install with the new ISO.
Man that was unlucky for me, I downloaded the ISO on Dec 6th and it was fixed on Dec 8th. Just spent a whole day setting up with all my software…
“touch support in dolphin”
I’ve been running Nibia for over a week on my Surface Pro 4. Touch support is not working in the Dolphin file manager. My Dolphin version is 20.08.3-1. Is there something special I need to do to enable it?
Edit: Will you folks please fix the announcement for Nibia? Manjaro 20.2 Nibia shipped with KDE Applications 20.08. Touch support was not officially added to the Dolphin file manager by the KDE Plasma Team until KDE Applications 20.12. Since KDE Applications 20.12 is currently in the unstable branch and was not released for Nibia, your announcement is not true.
Dood Do you reinstall the driver ?
Hi,
I had a small issue “removing linux58 broke dependency linux58 required by linux58-nvidia-455xx”
I have : sudo pacman -R linux58 linux58-nvidia-455xx linux58-r8168 before updating.
Take care and happy new year
First, Best wishes to all.
Second, I wish good things for Manjaro, and why not, the 1st place on the distrowatch website.
I switched from Manjaro KDE to Manjaro Gnome for my hybrid PC (Tablet/PC) and I would like to say to you that I made the best choice. Manjaro Gnome is the best thing for this kind of hardware. And the fact that Wayland is set by default is, for me, the good choice. For now, I made some tests but I’m very happy with Manjaro Gnome. Auto screen rotation, touchscreen, virtual keyboard are very good under Wayland. I can open special folders as administrator, edit config files as administrator under nautilus, and many things. The Manjaro Gnome Team, you made a wonderfull work.
Congratulations.
Note: For those who use the virtual keyboard, I recommand to you to install that extension: Improved Onscreen Keyboard - GNOME Shell Extensions
New Nibia release tonight: 20.2.1
A post was merged into an existing topic: [Stable-Update] 2020-12-30: Cannot initialize device-mapper
