Manjaro 19.0.2 GNOME - Tweaks: missing tabs
hi,
I am using Linux (Manjaro) since a year now, I love it and I start getting some understanding, step by step. So far I have been using KDE.
GNOME is a first for me.
I just installed Manjaro GNOME 19.0.2 (downloaded 3 days ago with GNOME 3.34.4 on a notebook we have here and it works like a charm, beyond expectations. All apps I prefer, I got installed.
I understand further customization can be done with the gnome tweaks tool, but, except for a general tab, no other tabs are visible. Nor can I adjust its windows size either. Screenshot in attachment.
I did a clean install twice, however the issue remains and was there from start. To be complete, I don't think it's related, I did upgrade the kernel since.
Below related error lines while opening and closing apps. Some refer to KDEConnect and my email address, but the issue remains when both are removed.
Hard-/software info added as well.
Any help would be very appreciated. And if any more input is required, please let me know.
thanks,
Alex
[alex@SOMA ~]$ journalctl -f
Mar 23 19:04:12 SOMA bijiben-shell-s[2581]: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Mar 23 19:04:12 SOMA org.gnome.Nautilus[2575]: Traceback (most recent call last):
Mar 23 19:04:12 SOMA org.gnome.Nautilus[2575]:   File "/usr/share/nautilus-python/extensions/kdeconnect-share.py", line 37, in <module>
Mar 23 19:04:12 SOMA org.gnome.Nautilus[2575]:     i18n = gettext.translation('kdeconnect-nautilus-extension')
Mar 23 19:04:12 SOMA org.gnome.Nautilus[2575]:   File "/usr/lib/python3.8/gettext.py", line 588, in translation
Mar 23 19:04:12 SOMA org.gnome.Nautilus[2575]:     raise FileNotFoundError(ENOENT,
Mar 23 19:04:12 SOMA org.gnome.Nautilus[2575]: FileNotFoundError: [Errno 2] No translation file found for domain: 'kdeconnect-nautilus-extension'
Mar 23 19:04:12 SOMA org.gnome.Nautilus[2575]: During handling of the above exception, another exception occurred:
Mar 23 19:04:12 SOMA org.gnome.Nautilus[2575]:   File "/usr/share/nautilus-python/extensions/kdeconnect-share.py", line 40, in <module>
Mar 23 19:04:12 SOMA org.gnome.Nautilus[2575]:     print('kdeconnect-nautilus: {0}'.format(e.strerr))
Mar 23 19:04:12 SOMA org.gnome.Nautilus[2575]: AttributeError: 'FileNotFoundError' object has no attribute 'strerr'
Mar 23 19:04:13 SOMA gnome-calendar[2583]: Link of type "section" missing "id=". Merging will not be possible.
Mar 23 19:04:13 SOMA gnome-calendar[2583]: source_credentials_required_cb: Failed to authenticate 'alex@rebirthrice.com': Data source “alex@rebirthrice.com” does not support OAuth 2.0 authentication
ar 23 19:04:19 SOMA gnome-shell[1958]: Ignoring excess values in shadow definition
Mar 23 19:04:19 SOMA gnome-shell[1958]: Ignoring excess values in shadow definition
[alex@SOMA ~]$ inxi -Fxxxza --no-host
  Kernel: 5.5.7-1-surface x86_64 bits: 64 compiler: gcc v: 9.2.1
  parameters: BOOT_IMAGE=/boot/vmlinuz-linux-surface
  root=UUID=417c304f-b117-4284-8514-1558413bf0ef rw quiet apparmor=1
  security=apparmor resume=UUID=5c36ca7a-190a-4e2c-9ece-c3241826a0fa
  udev.log_priority=3
  Desktop: Gnome 3.34.4 wm: gnome-shell dm: GDM 3.34.1 Distro: Manjaro Linux
  Type: Laptop System: Microsoft product: Surface Go v: 1 serial: <filter>
  Chassis: type: 9 serial: <filter>
  Mobo: Microsoft model: Surface Go serial: <filter> UEFI: Microsoft
  v: 1.0.03 date: 07/04/2018
  ID-1: BAT1 charge: 21.5 Wh condition: 26.1/26.3 Wh (100%) volts: 8.1/7.7
  model: SMP AHA22135001 type: Li-ion serial: <filter> status: Discharging
  cycles: 386
  Topology: Dual Core model: Intel Pentium 4415Y bits: 64 type: MT MCP
  arch: Amber Lake family: 6 model-id: 8E (142) stepping: 9 microcode: CA
  L2 cache: 2048 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 12805
  Speed: 800 MHz min/max: 400/1600 MHz Core speeds (MHz): 1: 800 2: 800
  3: 800 4: 800
  Type: l1tf
  Device-1: Intel HD Graphics 615 vendor: QUANTA driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:591e
  Display: x11 server: X.org 1.20.7 driver: i915 compositor: gnome-shell
  resolution: <xdpyinfo missing>
  OpenGL: renderer: Mesa DRI Intel HD Graphics 615 (Kaby Lake GT2)
  v: 4.6 Mesa 19.3.5 compat-v: 3.0 direct render: Yes
  Device-1: Intel Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Imaging
  Unit
  vendor: QUANTA driver: ipu3-imgu bus ID: 00:05.0 chip ID: 8086:1919
  Device-2: Intel driver: ipu3-cio2 bus ID: 00:14.3 chip ID: 8086:9d32
  Device-3: Intel Sunrise Point-LP HD Audio vendor: QUANTA
  driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:9d71
  Sound Server: ALSA v: k5.5.7-1-surface
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
  driver: ath10k_pci v: kernel port: 3000 bus ID: 01:00.0 chip ID: 168c:003e
  Device-2: Qualcomm Atheros type: USB driver: btusb bus ID: 1-5:2
  chip ID: 0cf3:e302
  Local Storage: total: 119.24 GiB used: 14.02 GiB (11.8%)
  ID-1: /dev/nvme0n1 vendor: Toshiba model: N/A size: 119.24 GiB block size:
  physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 serial: <filter>
  rev: ADMS0101 scheme: GPT
  ID-1: / raw size: 110.15 GiB size: 107.92 GiB (97.98%)
  used: 14.02 GiB (13.0%) fs: ext4 dev: /dev/nvme0n1p2
  ID-2: swap-1 size: 8.80 GiB used: 0 KiB (0.0%) fs: swap
  swappiness: 60 (default) cache pressure: 100 (default) dev: /dev/nvme0n1p3
  System Temperatures: cpu: 41.5 C mobo: N/A
  Processes: 203 Uptime: 8m Memory: 7.68 GiB used: 1.74 GiB (22.7%)
  Init: systemd v: 244 Compilers: gcc: 9.2.1 Shell: bash v: 5.0.16
  running in: gnome-terminal inxi: 3.0.37
Screenshot from 2020-03-23 19-09-03
Hello,
Make sure you update the system.
Can't conclude from your screenshot and information provided what resolution you have on screen, but try to resize the window and all the side menu should become visible. Check the scaling factor too.
You are so right. Resizing did it.
It's a 10" hidpi screen. To make a start I had the display scaled to 200%.
Just scaled the fonts to .8. It looks nice now.
I feel humbled.
Thanks!
Glad it helped. Things are not always perfectly obvious. :slight_smile:
