I have an issue with a freshly installed system. I install Mangohud as well as goverlay from spftware manager.The vkcube works fine and i can change the parameters within goverlay. all works.
however, when i start a game with mangohud enabled in Steam (mangohud %command%), the game simply does not start.
same with Heroic, when i try to run a game with mangohude enabled, it drops the following error message:
“Mangohud is enabled, but mangohud executable could not be found on $PATH”.
So you installed the package mangohud (and steam and heroic-games-launcher) from the repos?
I ask because pamac can provide SNAP and Flatpak too, and those might not work as expected.
I have no issues using MangoHud with Steam, Lutris or Heroic.
❯ pacman -Qs mangohud
local/lib32-mangohud 0.7.1-1
32-bit libraries for MangoHud and MangoApp
local/mangohud 0.7.1-1
A Vulkan overlay layer for monitoring FPS, temperatures, CPU/GPU load and more.
