XM34
June 21, 2022, 12:18pm
#1
Hi everyone,
I’ve been using Manjaro with Cinnamon for two years now and recently upgraded my notebook to a Dell Precision 5560. But unfortunately, the whole system feels laggy and unresponsive. CPU load is at 5% most of the time and RAM never crosses 30%. I also use proprietary drivers.
The issue is most noticable when moving around windows. It feels like the mouse is always half a second behind my actual input.
Could this be a mouse acceleration issue, or just general system lag?
xinput-props for the mouse:
Device 'Dell Computer Corp Dell Universal Receiver Mouse':
Device Enabled (202): 1
Coordinate Transformation Matrix (204): 2.000000, 0.000000, 0.000000, 0.000000, 2.000000, 0.000000, 0.000000, 0.000000, 1.000000
libinput Natural Scrolling Enabled (332): 0
libinput Natural Scrolling Enabled Default (333): 0
libinput Scroll Methods Available (334): 0, 0, 1
libinput Scroll Method Enabled (335): 0, 0, 0
libinput Scroll Method Enabled Default (336): 0, 0, 0
libinput Button Scrolling Button (337): 2
libinput Button Scrolling Button Default (338): 2
libinput Button Scrolling Button Lock Enabled (339): 0
libinput Button Scrolling Button Lock Enabled Default (340): 0
libinput Middle Emulation Enabled (341): 1
libinput Middle Emulation Enabled Default (342): 0
libinput Accel Speed (343): -0.080645
libinput Accel Speed Default (344): 0.000000
libinput Accel Profiles Available (345): 1, 1
libinput Accel Profile Enabled (346): 1, 0
libinput Accel Profile Enabled Default (347): 1, 0
libinput Left Handed Enabled (348): 0
libinput Left Handed Enabled Default (349): 0
libinput Send Events Modes Available (317): 1, 0
libinput Send Events Mode Enabled (318): 0, 0
libinput Send Events Mode Enabled Default (319): 0, 0
Device Node (320): "/dev/input/event7"
Device Product ID (321): 16700, 9492
libinput Drag Lock Buttons (350): <no items>
libinput Horizontal Scroll Enabled (351): 1
libinput Scrolling Pixel Distance (352): 15
libinput Scrolling Pixel Distance Default (353): 15
libinput High Resolution Wheel Scroll Enabled (354): 1
Can you post ```inxi -Fza`` on console ?
An which mouse do you and where it is connected.
XM34
June 21, 2022, 1:08pm
#3
Kernel: 5.18.0-1-rt11-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/vmlinuz-5.18-rt-x86_64
root=UUID=64790711-e1e6-4147-933c-2c561b6974b5 rw quiet
cryptdevice=UUID=c0ca5b90-17ea-4bd2-87f3-ce3ef4918246:luks-c0ca5b90-17ea-4bd2-87f3-ce3ef4918246
root=/dev/mapper/luks-c0ca5b90-17ea-4bd2-87f3-ce3ef4918246 apparmor=1
Desktop: Cinnamon v: 5.2.7 tk: GTK v: 3.24.34 vt: 7 dm: LightDM v: 1.30.0
Type: Laptop System: Dell product: Precision 5560 v: N/A
Mobo: Dell model: 0NG7N9 v: A00 serial: <superuser required> UEFI: Dell
v: 1.6.2 date: 11/13/2021
ID-1: BAT0 charge: 84.3 Wh (100.0%) condition: 84.3/84.3 Wh (100.0%)
volts: 13.0 min: 11.4 model: BYD DELL M59JH1B type: Li-poly
serial: <filter> status: full
Info: model: 11th Gen Intel Core i7-11850H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 built: 2020 process: Intel 10nm family: 6
model-id: 0x8D (141) stepping: 1 microcode: 0x3E
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB desc: 8x1.2 MiB
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1581 high: 2595 min/max: 800/4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 968 2: 970 3: 801
4: 1474 5: 2595 6: 1425 7: 1270 8: 977 9: 1522 10: 1988 11: 1178 12: 1736
13: 2076 14: 2472 15: 2344 16: 1502 bogomips: 79872
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Dell driver: i915
v: kernel arch: Gen12.1 process: Intel 10nm built: 2020-21 ports:
active: DP-3,eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:9a60
class-ID: 0300
Device-2: NVIDIA GA107GLM [RTX A2000 Mobile] vendor: Dell driver: nvidia
v: 515.48.07 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Ampere process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:25b8
class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-11:5 chip-ID: 0c45:672e class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 9504x2880 s-dpi: 70
s-size: 3460x1048mm (136.22x41.26") s-diag: 3615mm (142.33")
Monitor-1: DP-3 pos: top-right model: Dell C2722DE serial: <filter>
built: 2021 res: 5120x2880 hz: 60 dpi: 218 gamma: 1.2
size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9 modes:
max: 2560x1440 min: 720x400
Monitor-2: eDP-1 pos: primary,bottom-l model: Sharp 0x1516 built: 2021
res: 4384x2740 hz: 60 dpi: 331 gamma: 1.2 size: 336x210mm (13.23x8.27")
diag: 396mm (15.6") ratio: 16:10 modes: 3840x2400
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Tiger Lake-H HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 3-4.3:6 chip-ID: 413c:c00d
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 class-ID: 0300
chip-ID: 8086:43c8 class-ID: 0403
Device-2: Dell C2722DE type: USB driver: hid-generic,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.18.0-1-rt11-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.0 running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB
driver: r8152 bus-ID: 2-4.2:4 chip-ID: 0bda:8153 class-ID: 0000
serial: <filter>
IF: enp0s13f0u4u2 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-a51ab652e1d6 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: veth3b36a8f state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-4: vethcfd2a3e state: up speed: 10000 Mbps duplex: full
mac: <filter>
bus-ID: 3-14:8 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 953.87 GiB used: 105.54 GiB (11.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: PC711 NVMe 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 41001131
temp: 49.9 C scheme: GPT
ID-1: / raw-size: 950.91 GiB size: 934.91 GiB (98.32%)
used: 105.41 GiB (11.3%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-c0ca5b90-17ea-4bd2-87f3-ce3ef4918246
ID-2: /boot raw-size: 1.95 GiB size: 1.89 GiB (96.54%)
used: 138.5 MiB (7.2%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
ID-3: /boot/efi raw-size: 400 MiB size: 399.2 MiB (99.80%)
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 55.0 C mobo: N/A
Processes: 613 Uptime: 3h 6m wakeups: 88 Memory: 31.09 GiB
used: 20.72 GiB (66.6%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 2316
apt: 1158 lib: 290 pacman: 1158 lib: 290 flatpak: 0 Shell: Zsh v: 5.9
running-in: guake inxi: 3.3.19
The mouse is a wireless dell mouse connected via USB-C hub.
Can you try another kernel. E.g.: kernel 5.15.
You are using a realtime kernel, is this nessecary ?
XM34
June 21, 2022, 2:27pm
#5
I’m just using thee newest stable Kernel. Real time is not really a requirement. Will let you know as soon as I can test another kernel.
XM34
June 22, 2022, 8:01am
#6
Switching Kernels caused no noticeable improvement. It still feels like all of cinnamon (most noticably the mouse pointer) gets slower the moment I open any window.
Not sure if it helps with any system lag but you can alter mouse sensivity and speed in system settings on cinnamon
XM34
June 23, 2022, 9:19am
#8
I think, I kind of solved it.
I basically did two things:
First, I changed the mouse acceleration profile to “flat” using this post in the Mint forums . This helped a lot with the mouse pointer not moving in sync with my physical mouse
Second, I gave the Cinnamon process the priority “very high” in the system monitor. This probably helped the most.
I still get the lags when I do extremely demanding tasks like rendering stuff on the CPU or during benchmarks, but other than that it works fine. I have no idea, why the cinnamon process got started with “normal” scheduling priority, but now it all works as intended.
