Llama
January 1, 2023, 1:17pm
1
Hi,
I’ve been trying to set up IBus as a systemd service on two boxes powered identically with Manjaro KDE (with i3 for a WM) and standalone i3 as an alternative.
The idea is to manage IBus once for any DE.
~ ᐅ cat .config/systemd/user/ibus-custom.service
[Unit]
PartOf=graphical-session.target
Description=IBus Service
After=graphical-session.target
[Service]
Type=exec
ExitType=cgroup
ExecStartPre=/usr/bin/sleep 10
ExecStart=/usr/bin/ibus-daemon -drxR
Restart=no
TimeoutSec=15s
Slice=app.slice
[Install]
WantedBy=graphical-session.target
then
~ ᐅ systemctl enable --user ibus-custom
I have kinda three-fourths success on login:
Box A:
Box B:
On Box B logged into i3:
~ ᐅ systemctl status --user ibus-custom
ibus-custom.service - IBus Service
Loaded: loaded (/home/alexey/.config/systemd/user/ibus-custom.service; enabled; preset: enabled)
Active: inactive (dead)
No trouble starting the service manually:
~ ᐅ systemctl start --user ibus-custom
What do I have to look for?
Llama
January 1, 2023, 2:38pm
2
Oh, it works on Box A no longer! I never touched anything systemd related. It’s a step in the right direction, in a way. I have better output now:
○ ibus-custom.service - IBus Service
Active: inactive (dead) since Sun 2023-01-01 17:31:47 MSK; 45s ago
Duration: 5min 13.817s
Process: 3118 ExecStartPre=/usr/bin/sleep 10 (code=exited, status=0/SUCCESS)
Process: 3120 ExecStart=/usr/bin/ibus-daemon -drxR (code=exited, status=0/SUCCESS)
Main PID: 3120 (code=exited, status=0/SUCCESS)
CPU: 3.843s
Jan 01 17:26:23 gaucho systemd[640]: Starting IBus Service...
Jan 01 17:26:33 gaucho systemd[640]: Started IBus Service.
Jan 01 17:31:47 gaucho systemd[640]: ibus-custom.service: Consumed 3.843s CPU time.
Success through and through, the service is inactive (dead)
. What is it?
Are these flags correct? It seems it starts but finishes. For systemd, it should run in the foreground.
And I’ve never seen Type=exec, are you sure about that?
Llama
January 1, 2023, 3:10pm
4
About /usr/bin/ibus-daemon -drxR
I’m sure. At least, it’s been running fine in different contexts, including systemd (manual start, as I mentioned). About everything else I’m sure not at all.
Would you suggest removing Type=exec
? UPD : It doesn’t make any difference.
