Hi there.
I have a problem with my Manjaro. Sometimes when booting the laptop it hangs with this log:
The weird thing is that only happens sometimes, not always.
Could you help me?
Hi there.
Could you help me?
Hello there
If you donât often read the man pages (or will remember to manually update them when you do), then you can mask the service using systemctl ( sudo systemctl mask man-db.service
This is weird though, shouldnât be taking so long.
Itâs actually triggered by a timer:
$ systemctl status man-db.timer
You may edit man-db.timer
and set preferred time for man-database update, e.g. I edited it to âdaily 17:00â (or 05:00 PM if you like it).
I donât think that masking this service is a good idea 'cos mans (manuals) may come in very handy when actively using OS.
P.S. Same may be done with updatedb.timer
, altho if you donât use locate to find files itâs not that important and may be removed.
Sorry my ignorance. But, what means âmask the serviceâ? I never used that option with systemctl.
To quote man systemctl
mask UNITâŚ
Mask one or more units, as specified on the command line. This will link these unit files to /dev/null, making it impossible to start them. This is a stronger version of disable,
since it prohibits all kinds of activation of the unit, including enablement and manual activation. Use this option with care. This honors the --runtime option to only mask
temporarily until the next reboot of the system. The --now option may be used to ensure that the units are also stopped. This command expects valid unit names only, it does not
accept unit file paths.
