hello, I use malliit virtual keyboards and it works fine in qwerty but is it possible to configure it in azerty (french)?
Thank you
Thank you
A possible alternative is Onboard, plus, it’s available from the official repositories:
sudo pacman -S onboard
I have never used an azerty configuration, but the package is full-featured (from memory). You might have some luck with it.
Cheers.
