I have a second, bigger ssd that i wish to use for media and games. No matter how hard I try to fstab, gparted and otherwise do my own best hard work to find a solution; it simply will not work.
its plugged in, visible and editable in terms of partitions and UUID’s. But nothing I do is allowing me to actually use it.
output of inxi
Kernel: 5.11.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=b5020253-8d75-4ad1-abef-d3d0c07dffe0 ro quiet apparmor=1
security=apparmor resume=UUID=462e5d82-aebf-4886-8a60-8a8afd2cf5d5
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: PRIME B350-PLUS v: Rev X.0x
serial: <filter> UEFI [Legacy]: American Megatrends v: 5220 date: 09/12/2019
RAM: total: 15.63 GiB used: 4.55 GiB (29.1%)
Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D L2 cache: 3 MiB
bogomips: 92264
Speed: 1270 MHz min/max: 1550/3850 MHz boost: disabled Core speeds (MHz):
1: 1270 2: 2489 3: 1533 4: 3079 5: 1416 6: 1455 7: 1316 8: 2652 9: 1603
10: 1372 11: 1280 12: 2183
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: NVIDIA GP104 [GeForce GTX 1060 6GB] vendor: Gigabyte
driver: nvidia v: 460.56 alternate: nouveau,nvidia_drm bus ID: 09:00.0
chip ID: 10de:1b83 class ID: 0300
Display: x11 server: X.Org 1.20.10 driver: loaded: nvidia display ID: :0.0
screens: 1
Screen-1: 0 s-res: 3840x1526 s-dpi: 96 s-size: 1016x404mm (40.0x15.9")
s-diag: 1093mm (43")
Monitor-1: DP-0 res: 1920x1080 dpi: 82 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
Monitor-2: DVI-D-1 res: 1920x1080 hz: 60 dpi: 102
size: 477x268mm (18.8x10.6") diag: 547mm (21.5")
OpenGL: renderer: GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 460.56
direct render: Yes
Device-1: NVIDIA GP104 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 09:00.1 chip ID: 10de:10f0
class ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus ID: 0b:00.3 chip ID: 1022:1457 class ID: 0403
Device-3: Cambridge Silicon Radio FiiO BTR3K type: USB driver: snd-usb-audio
bus ID: 1-2:2 chip ID: 0a12:1004 class ID: 0102 serial: <filter>
Device-4: Logitech Webcam C310 type: USB driver: snd-usb-audio,uvcvideo
bus ID: 1-3:8 chip ID: 046d:081b class ID: 0102 serial: <filter>
Sound Server: ALSA v: k5.11.2-1-MANJARO
vendor: ASUSTeK driver: r8169 v: kernel port: f000 bus ID: 03:00.0
chip ID: 10ec:8168 class ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: f000
bus ID: 08:00.0 chip ID: 8086:2723 class ID: 0280
IF: wlp8s0 state: up mac: <filter>
IP v4: <filter> scope: global
IP v6: <filter> scope: global
IP v6: <filter> virtual: stable-privacy scope: link
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus ID: 1-6:5
chip ID: 8087:0029 class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 350.27 GiB used: 83.56 GiB (23.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Transcend model: TS256GSSD370S
size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 6KB scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD PLUS 120GB
size: 111.8 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 00RL scheme: MBR
ID-1: / raw size: 94.6 GiB size: 92.61 GiB (97.90%) used: 83.56 GiB (90.2%)
fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: b5020253-8d75-4ad1-abef-d3d0c07dffe0
ID-1: swap-1 type: partition size: 17.2 GiB used: 2.2 MiB (0.0%)
priority: -2 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 462e5d82-aebf-4886-8a60-8a8afd2cf5d5
ID-1: /dev/sda1 maj-min: 8:1 size: 238.47 GiB fs: ext4 label: N/A
uuid: 32ff6633-9779-4609-8c9e-d75314c1c423
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Device-1: 1-2:2 info: Cambridge Silicon Radio FiiO BTR3K type: Audio
driver: snd-usb-audio interfaces: 2 rev: 2.0 speed: 12 Mb/s
Device-2: 1-3:8 info: Logitech Webcam C310 type: Video,Audio
Device-3: 1-4:4 info: Microsoft Xbox360 Controller type: <vendor specific>
driver: xpad interfaces: 4 rev: 2.0 speed: 12 Mb/s chip ID: 045e:028e
class ID: ff00 serial: <filter>
Device-4: 1-6:5 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0029 class ID: e001
Device-5: 1-7:6 info: Hoksi DURGOD Taurus K320 type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
chip ID: 2f68:0082 class ID: 0300
Device-6: 1-10:7 info: Razer USA Viper (wired) type: Mouse,Keyboard
chip ID: 1532:0078 class ID: 0301
chip ID: 1d6b:0003 class ID: 0900
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 39.4 C mobo: N/A gpu: nvidia temp: 58 C
Processes: 356 Uptime: 3h 19m wakeups: 0 Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: 1355 pacman: 1351 lib: 427 flatpak: 4 Shell: fish
v: 3.1.2 default: Bash v: 5.1.0 running in: xfce4-terminal inxi: 3.3.01
any help on getting this sorted would be great,
thanks
