Hello
I’m new here
I have a problem when trying to install microsoft edge from AUR.
I got several errors from shell scripts.
Any idea what’s ongoing here?
Reinstalling pacman didn’t help either.
Thank you.
br.ari
moderated - codefence
Remember to use codefence as described below.
=> Retrieving sources...
-> Downloading microsoft-edge-stable_96.0.1054.34-1_amd64.deb...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 112M 100 112M 0 0 2997k 0 0:00:38 0:00:38 --:--:-- 3130k
-> Found microsoft-edge-stable.sh
-> Found Microsoft Standard Application License Terms - Standalone (free) Use Terms.pdf
microsoft-edge-stable_96.0.1054.34-1_amd64.deb ... Passed
microsoft-edge-stable.sh ... Passed
Microsoft Standard Application License Terms - Standalone (free) Use Terms.pdf ... Passed
==> Making package: microsoft-edge-stable-bin 96.0.1054.34-1 (ti 30. marraskuuta 2021 19.57.52)
==> Retrieving sources...
-> Found microsoft-edge-stable_96.0.1054.34-1_amd64.deb
==> Extracting sources...
-> Extracting microsoft-edge-stable_96.0.1054.34-1_amd64.deb with bsdtar
==> Sources are ready.
==> Making package: microsoft-edge-stable-bin 96.0.1054.34-1 (ti 30. marraskuuta 2021 19.57.54)
==> WARNING: Using existing $srcdir/ tree
==> Entering fakeroot environment...
/usr/share/makepkg/util/config.sh: command substitution: line 75: conditional binary operator expected
/usr/share/makepkg/util/config.sh: command substitution: line 75: syntax error near `$var'
/usr/share/makepkg/util/config.sh: command substitution: line 75: ` [[ -v $var ]] && printf '%s=%s\n' "$var" "${!var@Q}"'
==> ERROR: $SRCEXT does not contain a valid package suffix (needs '.src.tar*', got '')
==> ERROR: $PKGEXT does not contain a valid package suffix (needs '.pkg.tar*', got '')
/usr/share/makepkg/util/util.sh: line 49: ${!v@a}: bad substitution
==> ERROR: microsoft-edge-stable-bin is not available for the '' architecture.
==> ERROR: checkdepends is not allowed to be empty.
/usr/bin/makepkg: line 395: local: `-': not a valid identifier
==> Starting package()...
==> Tidying install...
==> Checking for packaging issues...
==> Creating package "microsoft-edge-stable-bin"...
-> Generating .PKGINFO file...
-> Generating .BUILDINFO file...
-> Generating .MTREE file...
-> Compressing package...
==> WARNING: '' is not a valid archive extension.
==> Leaving fakeroot environment.
==> Finished making: microsoft-edge-stable-bin 96.0.1054.34-1 (ti 30. marraskuuta 2021 19.58.07)
==> Cleaning up...
-> the PKGDEST for microsoft-edge-stable-bin is listed by makepkg but does not exist: /home/kumpumak/.cache/yay/microsoft-edge-stable-bin/microsoft-edge-stable-bin-96.0.1054.34-1-x86_64.pkg.tar.zst
Thanks for fast respose.
I only have /etc/makepkg.conf
And the used release is: 21.2.0
#!/hint/bash
# /etc/makepkg.conf
# SOURCE ACQUISITION
#-- The download utilities that makepkg should use to acquire sources
# Format: 'protocol::agent'
DLAGENTS=('file::/usr/bin/curl -qgC - -o %o %u'
'ftp::/usr/bin/curl -qgfC - --ftp-pasv --retry 3 --retry-delay 3 -o %o %u'
'http::/usr/bin/curl -qgb "" -fLC - --retry 3 --retry-delay 3 -o %o %u'
'https::/usr/bin/curl -qgb "" -fLC - --retry 3 --retry-delay 3 -o %o %u'
'rsync::/usr/bin/rsync --no-motd -z %u %o'
'scp::/usr/bin/scp -C %u %o')
# Other common tools:
# /usr/bin/snarf
# /usr/bin/lftpget -c
# /usr/bin/wget
#-- The package required by makepkg to download VCS sources
# Format: 'protocol::package'
VCSCLIENTS=('bzr::bzr'
'fossil::fossil'
'git::git'
'hg::mercurial'
'svn::subversion')
# ARCHITECTURE, COMPILE FLAGS
CARCH="x86_64"
CHOST="x86_64-pc-linux-gnu"
#-- Compiler and Linker Flags
#CPPFLAGS=""
CFLAGS="-march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions \
-Wp,-D_FORTIFY_SOURCE=2 -Wformat -Werror=format-security \
-fstack-clash-protection -fcf-protection"
CXXFLAGS="$CFLAGS -Wp,-D_GLIBCXX_ASSERTIONS"
LDFLAGS="-Wl,-O1,--sort-common,--as-needed,-z,relro,-z,now"
#RUSTFLAGS="-C opt-level=2"
#-- Make Flags: change this for DistCC/SMP systems
#MAKEFLAGS="-j2"
#-- Debugging flags
DEBUG_CFLAGS="-g -fvar-tracking-assignments"
DEBUG_CXXFLAGS="-g -fvar-tracking-assignments"
#DEBUG_RUSTFLAGS="-C debuginfo=2"
# BUILD ENVIRONMENT
# Makepkg defaults: BUILDENV=(!distcc !color !ccache check !sign)
# A negated environment option will do the opposite of the comments below.
#-- distcc: Use the Distributed C/C++/ObjC compiler
#-- color: Colorize output messages
#-- ccache: Use ccache to cache compilation
#-- check: Run the check() function if present in the PKGBUILD
#-- sign: Generate PGP signature file
BUILDENV=(!distcc color !ccache check !sign)
#-- If using DistCC, your MAKEFLAGS will also need modification. In addition,
#-- specify a space-delimited list of hosts running in the DistCC cluster.
#DISTCC_HOSTS=""
#-- Specify a directory for package building.
#BUILDDIR=/tmp/makepkg
# GLOBAL PACKAGE OPTIONS
# These are default values for the options=() settings
# Makepkg defaults: OPTIONS=(!strip docs libtool staticlibs emptydirs !zipman !purge !debug !lto)
# A negated option will do the opposite of the comments below.
#-- strip: Strip symbols from binaries/libraries
#-- docs: Save doc directories specified by DOC_DIRS
#-- libtool: Leave libtool (.la) files in packages
#-- staticlibs: Leave static library (.a) files in packages
#-- emptydirs: Leave empty directories in packages
#-- zipman: Compress manual (man and info) pages in MAN_DIRS with gzip
#-- purge: Remove files specified by PURGE_TARGETS
#-- debug: Add debugging flags as specified in DEBUG_* variables
#-- lto: Add compile flags for building with link time optimization
OPTIONS=(strip docs !libtool !staticlibs emptydirs zipman purge !debug !lto)
#-- File integrity checks to use. Valid: md5, sha1, sha224, sha256, sha384, sha512, b2
INTEGRITY_CHECK=(sha256)
#-- Options to be used when stripping binaries. See `man strip' for details.
STRIP_BINARIES="--strip-all"
#-- Options to be used when stripping shared libraries. See `man strip' for details.
STRIP_SHARED="--strip-unneeded"
#-- Options to be used when stripping static libraries. See `man strip' for details.
STRIP_STATIC="--strip-debug"
#-- Manual (man and info) directories to compress (if zipman is specified)
MAN_DIRS=({usr{,/local}{,/share},opt/*}/{man,info})
#-- Doc directories to remove (if !docs is specified)
DOC_DIRS=(usr/{,local/}{,share/}{doc,gtk-doc} opt/*/{doc,gtk-doc})
#-- Files to be removed from all packages (if purge is specified)
PURGE_TARGETS=(usr/{,share}/info/dir .packlist *.pod)
#-- Directory to store source code in for debug packages
DBGSRCDIR="/usr/src/debug"
# PACKAGE OUTPUT
# Default: put built package and cached source in build directory
#-- Destination: specify a fixed directory where all packages will be placed
#PKGDEST=/home/packages
#-- Source cache: specify a fixed directory where source files will be cached
#SRCDEST=/home/sources
#-- Source packages: specify a fixed directory where all src packages will be placed
#SRCPKGDEST=/home/srcpackages
#-- Log files: specify a fixed directory where all log files will be placed
#LOGDEST=/home/makepkglogs
#-- Packager: name/email of the person or organization building packages
#PACKAGER="John Doe <john@doe.com>"
#-- Specify a key to use for package signing
#GPGKEY=""
# COMPRESSION DEFAULTS
COMPRESSGZ=(gzip -c -f -n)
COMPRESSBZ2=(bzip2 -c -f)
COMPRESSXZ=(xz -c -z -)
COMPRESSZST=(zstd -c -z -q -)
COMPRESSLRZ=(lrzip -q)
COMPRESSLZO=(lzop -q)
COMPRESSZ=(compress -c -f)
COMPRESSLZ4=(lz4 -q)
COMPRESSLZ=(lzip -c -f)
# EXTENSION DEFAULTS
PKGEXT='.pkg.tar.zst'
SRCEXT='.src.tar.gz'
# OTHER
#-- Command used to run pacman as root, instead of trying sudo and su
#PACMAN_AUTH=()
type or paste code here
Hmm…
When I run "pamac build microsoft-edge-stable-bin “, it finished succesfully
But above errors with makepkg I got when I run:
" yay -S microsoft-edge-stable”
cat /usr/share/makepkg/util/config.sh ✔
#!/usr/bin/bash
# config.sh - functions for handling makepkg config files
# Copyright (c) 2006-2021 Pacman Development Team <pacman-dev@archlinux.org>
# Copyright (c) 2002-2006 by Judd Vinet <jvinet@zeroflux.org>
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program. If not, see <http://www.gnu.org/licenses/>.
[[ -n "$LIBMAKEPKG_UTIL_CONFIG_SH" ]] && return
LIBMAKEPKG_UTIL_CONFIG_SH=1
LIBRARY=${LIBRARY:-'/usr/share/makepkg'}
source "$LIBRARY/util/error.sh"
source "$LIBRARY/util/message.sh"
source "$LIBRARY/util/util.sh"
# correctly source makepkg.conf, respecting user precedence and the system conf
source_makepkg_config() {
# $1: override system config file
local MAKEPKG_CONF=${1:-${MAKEPKG_CONF:-/etc/makepkg.conf}}
# Source the config file; fail if it is not found
if [[ -r $MAKEPKG_CONF ]]; then
source_safe "$MAKEPKG_CONF"
else
error "$(gettext "%s not found.")" "$MAKEPKG_CONF"
plainerr "$(gettext "Aborting...")"
exit $E_CONFIG_ERROR
fi
# Source user-specific makepkg.conf overrides, but only if no override config
# file was specified
XDG_PACMAN_DIR="${XDG_CONFIG_HOME:-$HOME/.config}/pacman"
if [[ $MAKEPKG_CONF = "/etc/makepkg.conf" ]]; then
if [[ -r $XDG_PACMAN_DIR/makepkg.conf ]]; then
source_safe "$XDG_PACMAN_DIR/makepkg.conf"
elif [[ -r $HOME/.makepkg.conf ]]; then
source_safe "$HOME/.makepkg.conf"
fi
fi
# load makepkg.conf by sourcing the configuration files, and preserving
# existing environment settings
load_makepkg_config() {
# preserve environment variables to override makepkg.conf
local restore_envvars=$(
for var in PKGDEST SRCDEST SRCPKGDEST LOGDEST BUILDDIR PKGEXT SRCEXT GPGKEY PACKAGER CARCH; do
# the output of 'declare -p' results in locally scoped values when used within a function
done
source_makepkg_config "$MAKEPKG_CONF"
eval "$restore_envvars"
Hi again
An another thing that now when I tried to update Edge via GUI package manager it says: “Failed to prepare transaction”, “target not found: microsoft-edge-stabe-bin”
But I manage to update with: sudo pamac update
Yep, a bit confusing…
