I’m trying to use Blu Rays without having to rip them and watching them on a media player like VLC, I’ve been seeing people saying going on MakeMKV then View > Preferences > Integration and checking VLC will make it so that I can use VLC but I can’t see VLC or anything on the check list. I heard installing VLC from flathub fixies it but isntalling from VLC | Flathub did not help, I’m not sure if I used the wrong link.
I suppose this means you specifically need BD+ support?
https://wiki.archlinux.org/title/Blu-ray#BD+_support
Otherwise its simple enough in many media players.
Heres the whole page
The only thing you need to do is install aribb24 and/or aribb25
Vlc will work with makemkv through file open disk menu
