So its pretty simple, install zsh with
tested and working on
XFCE
Kernel 5.10
install zsh first
pacman -S zsh
then go to XFCE Terminal Settings → check “run a custom command instead of my shell” and set that to
zsh
→ Close
or the more effective method is typing in zsh sudo chsh -s $(zsh)
thanks to cjean and papajoke for bringing this up!
and next time opening terminal it will open zsh instead
