is there a way or a solution to disable the tracker when booting/starting (see picture)? Every time I start the laptop this process consumes almost 100% of the CPU and it’s very noisy and annoying.
I saw that I have the Dconf editor on my laptop, can I change something there if necessary? And if so what exactly?
I have no idea what that process is, i never heard of it either.
Maybe you should first try to find out from which package it originates, that way you can decide if you need it or not…
Thanks for the tip, I deactivated the monitor in the tracker module in dconf-editor and now it’s quiet. I’ll have to see how that holds up over the long term.
