Hello everyone,
ranger always open files in nano by default I want files to open in neovim.
And also how to make ranger open html files in neovim and not in web browser.It is very annoying when it shoots up the browser instead of html file.
In my .config/ranger folder there is only rc.conf file and plugins folder.
Change the EDITOR variable to point to your preferred editor - depending on how you launch the editor maybe look for the VISUAL variable.
Look at the file ~/.profile
or ~/.bashrc
hello I am new to linux please explain me the answer I don’t uderstand these words like variables yet.
if you are new to Linux then vi and derivatives like neovim is not the editor of choice
there is no editor variable in the .bashrc
no no I know to operate vim I learned it with vscode vim extension back in windows.
Add the following line to your ~/.bashrc
export EDITOR=neovim
Save the file, then log out and log back in.
Edit: Apparently the executable is called nvim
, so the command should be…
export EDITOR=nvim
I did this when I open any file this message flashes on screen/bin/sh : line 1 neovim command not found
should I write export EDITOR=nvim
If that is the name of the executable, then yes ─ of course. I don’t have neovim
installed, so I assumed that the executable would be called that.
No the package I installed was neovim but when It is nvim to open neovim
Depending on the location of the bin file, maybe add /usr/bin/ before nvim
let me try this.
adding export EDITOR=nvim to .bashrc worked
Now how do I change html files to open in neovim instead of browser in ranger.
That’s a different issue and I don’t even have ranger
installed, so please start a separate thread about that subject. Your question as per the title of this thread has been answered.
understood thankYou for helping everyone .
