Using XCFE
When connecting to wifi or vpn using the nm-connection-editor the connections seems to be user specific. Is there a way to make these settings apply to all users?
Basically, if one user enters the password for a wifi connection, it shouldn’t be necessary for every other user to do the same.
you can configure system connections in network manager.
but please be aware this stores passwords in plain text in a config file. you will have to work out if this risk is ok for your setup.
Also double check you have noting else trying to configure your network before you enable it as it will break your network if they conflict.
Thanks. Do you know where the “user connections” are stored? (The wiki say where the system connenctions are stored)
