Hello guys! I bought an Alfa AWUS036NH network adapter and would like to check if it is genuine, but without having to open it and look inside. I have little time for that.
So, one of my goals, is to test the 2000mW (33dbm) and see if it works correctly, but I have a problem with the make of crda, it is probably a requirement / package that I don’t have (maybe libgcrypt or libssl (openssl) header files ? I know i need that). Can someone help me?
the pre-requisites are in the regulatory of crda (i can’t post links here Search for wireless wiki kernel org)
The error:
[pedroegg@Manjaro-Egg crda-3.18]$ make
CC libreg.so
reglib.c: In function ‘reglib_verify_db_signature’:
reglib.c:168:26: error: ‘keys’ undeclared (first use in this function)
168 | for (i = 0; (i < sizeof(keys)/sizeof(keys[0])) && (!ok); i++) {
reglib.c:168:26: note: each undeclared identifier is reported only once for each function it appears in
keys-gcrypt.c:49:22: warning: ‘n_1’ defined but not used [-Wunused-const-variable=]
49 | static const uint8_t n_1[257] = {
keys-gcrypt.c:44:22: warning: ‘e_1’ defined but not used [-Wunused-const-variable=]
44 | static const uint8_t e_1[3] = {
keys-gcrypt.c:7:22: warning: ‘n_0’ defined but not used [-Wunused-const-variable=]
7 | static const uint8_t n_0[257] = {
keys-gcrypt.c:2:22: warning: ‘e_0’ defined but not used [-Wunused-const-variable=]
2 | static const uint8_t e_0[3] = {
make: *** [Makefile:119: libreg.so] Erro 1
I already tried to delete libreg.so and removed the -Werror from the make file, and run make again, but… The same!
Off-topic: I also tested to check your MAC ADDRESS without installing its driver, and it is different from the MAC of a genuine Alfa AWUS036NH. However, as I have not yet installed your driver, can anyone tell me if the MAC would be correct only after installing the driver?
Another thing is that everytime that i reconnect the USB, its MAC Address changes.
Thank you!
