Hi Folks, first of all a very happy and healthy new year to all of you.
Having a little leisure time, I was curious whether I should switch to Manjaro from my current Ubuntu/Debian based environment. Thought of it mainly due to the more current driver/kernel support for my MSI Bravo E17FKAMS with the AMD Ryzen 7 4800H and dual graphics. This by the way seems to work very fine, and I want to say congrats to the folks who are doing the hard work getting such a distro together.
Actually I was trying with a live boot, and got pretty far. But where I got stuck is when I want to mount a built in M.2 4TB. I did copy a couple of screenshots (which I am not allowed to attach here), and it appears as if this piece is not found by the OS. GSmartControl says /dev/nvme01n1, Unknown model. And it would not mount anywhere,e.g. to /mnt. Funny this piece works just fine in 20.02 LTS, where it was formatted ext4 with Gparted.
Second issue is even more of a show stopper, and it has to do with truecrypt, which installs just fine from sources, but when you want to mount any file, it stops with: " device-mapper: reload ioctl on truecrypt1_0 (254:0) failed: invalid argument. Command failed." After a little research, I tried -m=nokernelcrypto but it doesnât do any good.
Would be nice if anybody has some ideas and hints.
Hi, thanks very much for your quick reply. No, Truecrypt was not compiled from sources, just installed from the âsourcesâ std repo (software installer) and after it didnât do, I also tried an older version (truecrypt-7.1a-setup-x64), that I would prefer anyways (this build was before âsomeoneâ had a dispute with the developer back then). Installed fine, too, but no change on the mounting.
Thanks for mentioning Veracrypt. Right now all of my containers (~2TB) are double encrypted on Truecrypt and I did have an issue with versioning or mounting yet, thus I havenât felt the need to go that route. I just wanted to try whether I would go better with Manjaro instead of Ubuntu, but the error itself is a showstopper right now, and I was hoping to find a fix for the error described. Besides, the m.2 issue, since it could be somewhat related. LUKS is a little tricky for me as it is not portable. I tend to use the Truecrypt containers to multiple OSes on the same machine and sync to remote clients occasionally as well. Many thanks.
Years before I moved from windows to manjaro I came also up with âtruecryptâ containers. âVeracryptâ gave me the possility to port âtruecryptâ containers to âveracryptâ containers without the need of reformating it.
But be aware this is a âone-way streetâ. âVeracryptâ containers cant (as I know) moved back to âtruecryptâ containers and âtruecryptâ cant handle âveracryptâ containers.
Hope this helps you a little bit for your futher way.
